Car engine FAA certified for airplane use
Old January 26th 04, 05:21 AM
Cy Galley
Default Car engine FAA certified for airplane use
Hans Conser wrote:
Page 18 Feb issue of Flying:
"FAA Certifies Auto Engine Conversion
In November the FAA granted type certification to the Thielert
Aircraft
Engines (TAE) TAE 125-01 four cylinder aviation diesel engine. The
model is a diesel automotive engine, made by DaimlerChrysler, which
TAE
converts for airplane use by adding a gearbox and other aviation
specific parts.
The certification for the engine, known as the Centurion 1.7, is the
first of its kind for the FAA. The approval surprised many industry
observers because it entailed producing an engine with parts that the
manufacturer (DaimlerChrysler) would not verify. But the FAA was
surprisingly willing to work within this restriction and allowed
Thielert to verify, through a combination of component testing, parts
validation, test stand runs, and ongoing testing that the engine, and
the parts that make it up, meet an acceptable level of safety.
To our knowledge, the certification of the engine also entails
another
first, the approval of a powerplant with a timer before before
replacement (TBR) limit--1000 hours or 12 years, whichever is
first--with no overhaul allowed. When the engine reaches one of
those
milestones the owner must replace it with a new engine. The company
is
working toward a 2,400 hour TBR, and will pro-rate replacement
engines
from the beginning at the 2400 hour figure.
Thielert plans to offer an STC for retrofit installations of the
engine
in Cessna Skyhawks. Diamond is developing its Twin-Star light twin
around the Centurion 1.7 engine, and OMF is working on a diesel
version
of its two-place Symphony."
Perhaps it is time to certify the 13B.
Hans
Al Gietzen wrote:
Hum-m-m; kind of puts Lycoming and Continental on notice, doesn't it?
Old January 28th 04, 02:50 AM
Dan Thomas
Thielert already has a 2400 hour TBR in hand for this engine. And they
have an STC for the 172 N and P series airplanes, as well as some
Piper models, but last I heard they were having some troubles with a
shortage of vendor-supplied items. They didn't specify what those
items were, but I imagine it has to do with engine mounts or radiators
or something. I hope it isn't the engine manufacturer being stubborn.
The 1.7 is a 135 HP engine. It produces more static thrust than
the original Lycoming it replaces, although that's through a CS prop.
The HP is rated at 2300 RPM, which is why the airplane's performance
isn't affected by the lower HP. At the 2700 RPM of the Lyc so much
power is lost to the much higher propeller drag that the 135 at 2300
is able to match it.
It burns a bit over 4 GPH of diesel or Jet A, and fuel savings
over the life of the engine we have figured at about $40,000 CDN. The
engine's cost is about the same as a factory reman Lyc O-320, but I
imagine the initial installation would add considerably to that.
Go to http://www.centurion-engines.com/
Dan
"Cy Galley" wrote in message news:UA0Rb.22152$U%5.168426@attbi_s03...
Aircraft
TAE
specific parts.
another
those
is
engines
engine
version
Hans
Old January 28th 04, 03:34 AM
Big John
Cy
Wonder how they are going to prevent miss-fueling 172's with two types
of engines? Have different nozzles like used for unleaded gas in
automobiles or???????????
If I had a 172 with a Lyc or Con, I'd stand and watch each fueling to
be sure I got the correct fuel when the Centurions start showing up..
Big John
On Mon, 26 Jan 2004 04:21:08 GMT, "Cy Galley"
----clip----
Old January 28th 04, 04:11 AM
Kevin Horton
have an STC for the 172 N and P series airplanes, as well as some Piper
models, but last I heard they were having some troubles with a shortage of
vendor-supplied items. They didn't specify what those items were, but I
imagine it has to do with engine mounts or radiators or something. I hope
the original Lycoming it replaces, although that's through a CS prop. The
HP is rated at 2300 RPM, which is why the airplane's performance isn't
affected by the lower HP. At the 2700 RPM of the Lyc so much power is lost
to the much higher propeller drag that the 135 at 2300 is able to match
it.
Dan
It is interesting that they think static thrust is so important. Static
thrust is only important if you are using the aircraft to pull out stumps.
The thrust changes as soon as you start rolling ahead and then the
comparisons of static thrust become meaningless.
There is an FAQ on their web site "In a PA28 or a C172 with a CENTURION
1.7, can I expect the same or better take off, climb and cruise?" They
admit that the climb performance with the Centurion engine will be lower
(due to the lower power output - even with the constant speed prop). And
they carefully don't mention cruise speed at all. I wonder why?
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://go.phpwebhosting.com/~khorton/rv8/
e-mail: khorton02(_at_)rogers(_dot_)com
Old January 28th 04, 08:58 AM
Craig
"Cy Galley" wrote in message news:W9GRb.167062$I06.1661204@attbi_s01...
Jet fuel has a larger nozzle. I don't know whether you can fuel a gas 172
with the larger nozzle. I know at one time Beech was trying to get
restrictors in the openings of Bonanzas.
Make it even easier to prevent misfueling....go to single point refueling...
Craig C.
Old January 28th 04, 10:03 PM
Cy Galley
I don't understand how single point fueling will do a better job of
preventing using the wrong fuel.
"Craig" wrote in message
om...
172
refueling...
Craig C.
Old January 29th 04, 04:28 AM
Craig
"Cy Galley" wrote in message news:msVRb.177072$na.286827@attbi_s04...
Going to a single point system requires the use of a special pressure
feed nozzle. The nozzle locks onto a mating recepticle on the a/c.
With this system, all tanks are filled through the single connection.
The system is a bit of overkill ( to put it mildly ) for small a/c,
but we are going to start seeing it soon with the practicality of the
personal jet ever closer.
Craig C.
Old January 30th 04, 02:15 AM
Charlie England
Big John wrote:
Cy
Big John
snipped
I have an RV-4 with a Lyc & I stand and watch each fueling to be sure I
got the correct fuel (type & quantity). Now. Centurion powered 172's or not.
Charlie
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 06:36 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
