Grumman info
Old March 5th 04, 03:46 AM
eddie
Default Grumman info
Does anybody know, or know how to find out what the factory "standard"
avionics package was on a 1978 Grumman AA5B "Tiger"?
Eddie
Old March 6th 04, 04:24 AM
Dude
You may try asking one of the old dealers, but you better have a good reason
if you really want them to look it up.
www.fletchair.com
"eddie" wrote in message
. com...
Eddie
Old March 6th 04, 04:38 PM
eddie
Fletcher's down here at HOU. I'll stop by and see if I can pick their brain.
Thanks for the suggestion.
I found a used one and the sellers representative can only tell me that it
is all original avionics. I need more information.
Thanks,
Eddie
"Dude" wrote in message
reason
www.fletchair.com
. com...
Eddie
Old March 6th 04, 09:57 PM
Dave Butler
If they're not original, there will be logbook entries indicating the
installation. Do you not trust the logs?
Dave
Remove SHIRT to reply directly.
Old March 6th 04, 11:15 PM
eddie
Haven't seen the logs yet... Rep says they are "original"... Just don't
know what "original" means.
Deal seems too shady to be legitimate. I'll probably just walk away. 1978
Tiger with 522 hrs TTAF&E but still flown regularly, just not much. Problem
is, its located in Argentina. There are red flags all over this deal.
Eddie
"Dave Butler" wrote in message
brain.
it
Dave
Old March 7th 04, 04:12 AM
Jim Carter
I'm pretty sure the ones we flew circa 1974 had King KX-170s in them. They
were single radio because we didn't use them for anything other than pretty
basic stuff.
Jim Carter
Seen on a bumper sticker:
If you can read this, thank a teacher
If you can read this in English, thank a soldier.
. com...
Eddie
Old March 7th 04, 04:14 AM
Jim Carter
That's not even 2 hours per month average since new. And, how in the world
are you going to do a pre-buy in Argentina?
Jim Carter
m...
...1978
Problem
Eddie
Old March 7th 04, 06:03 AM
eddie
My point exactly. I don't think its worth the risk even if the price is way
below market.
Eddie
"Jim Carter" wrote in message
y.com...
Jim Carter
m...
...1978
Problem
Eddie
Old March 7th 04, 05:11 PM
Doug
Importing an airplane is not trivial. First of all, no one will
finance it, so you can forget using it as collateral. This is BEFORE
it is imported. Once you get it US registered this is no longer true.
Then you have to have it inspected. If it has had any modifications
that are not USA approved (like a Canadian STC that is not an STC in
the USA), you have to fix that. All of this has to be done by a DER,
an IA wont do. It helps if the airplane was originally certified as a
USA aircraft. You also have to repaint the N Numbers. A rough estimate
is that it takes about $10,000 to inspect, deliver, re-certify, paint
and whatever else you run into. But you never know how much it will
cost, could be less, could be more.
In your case, Argentina is a long way away. Expensive and risky
delivery. For a while they were importing aircraft from South Africa.
You could buy a Baron for 1/2 the price of a USA one. Canadian 185's
seem to go for about $20K less than US ones. So it can make sense. The
less expensive the aircraft, the lesss sense it makes. Proabably just
as expensive to import a 200k aircraft as a 50k one.
If I were to import one, I'd call a big dealer in Canada and see if I
could get the name of a USA DER that specializes in these issues. Talk
to him and see how much it would cost. I suspect there are some near
the Canadian border.
Old March 28th 04, 04:10 PM
marc
There are Tigers available for sale in the US, if you want one and are
patient you can find a good one. Spend some time with the grumman owners
group (Grumman Gang, etc) and you'll get a lot of information and offers of
planes for sale. It took me about 6 months to find a good well-maintaned
Tiger.
-Marc
m...
1978
Problem
Eddie
brain.
that
it
Dave
Grumman FAAV? Charles Gray Military Aviation 1 July 19th 04 06:55 AM
POSA Carb Info and HAPI Engine Info Bill Home Built 0 March 8th 04 08:23 PM
Looking for info on Flyins Chris Whitley Home Built 21 February 11th 04 09:21 PM
150HP Grumman Super Yankee FS Price Reduced! Bill Berle Home Built 6 December 2nd 03 12:55 AM
150HP Grumman Super Yankee FS Price Reduced! Bill Berle Aviation Marketplace 5 December 2nd 03 12:55 AM
