Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve
Old January 26th 04, 08:48 AM
Bill Berle
Default Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve
Friends, Airplane Tinkerers, Cheapskate Builders, Impoverished Owners…
My recent ebay auctions were a great success, and so I have slithered
once again through my secret vaults of airplane parts for more
treasures to be auctioned off. Please check my ebay auctions for one
or more of the following, which are the titles of the auctions. They
are all in ebay motors, parts, aircraft category. Or browse the
auctions under my username victorbravo
Airborne Vacuum Regulator valve, model 2H3-2 , number 8A ,
manufactured 3Q 75.
BTH Magneto Case Tiger Moth Gipsy Major
Cessna 172 NEW Finger Screen
Fuel Level Float Sender Unit Mfg. By AC
Continental Fuel Injection Valve Control Unit
Fuel Level Float Sender Unit New (Long)
Fuel Float Level Sender Unit (Short)
Continental 65 Thru O-200 Intake Spider
Absolute Pressure Gauge Manifold Pressure WW2
Lycoming Piston Ring Set SL-5401-A1 (Chrome)
Stall Warning Indicator Switch NEW SafeFlight
Aircraft Suction Gauge WW2 Vintage US Gauge Co.
Aircraft Tachometer NEW
Navy AN 5828-2 Vacuum Regulator Valve Schwein
Used Single Venturi for Gyro Instrument
US Navy Volt Ammeter New 30 Volts 60 Amps
Cessna Voltage Regulator 14V C611001-0101
ALSO, in a day or two I will be adding one large and two small pair of
Cessna Spring Steel main landing gear legs, as well as one Cessna
tubular gear leg. Condition varies from "bolt on and fly away to
"remove some amount of corrosion, blast, and paint" before flight.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Hot weather and autogas? Rich S. Home Built 33 July 31st 03 12:25 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
