KT-76A frequency
Old March 11th 04, 12:49 AM
Ray Godwin
Default KT-76A frequency
I just had a VFR Cert. done and the avionics shop said that the antenna
of coax was causting the frequency of the transponder to be out of
limits. Of coarse they had to bench adjust the frequency of the
transponder to compensate. Has anyone ever had this problem before?
Thanks,
Ray
Old March 11th 04, 03:26 AM
dave
Ray,
I have seen this multiple times. I've seen very large swings in freq and
when the problem was fixed, the xponder was back where it needed to be.
The cause of the frequency shift should be fixed, not adjusting the
radio to compensate for it.
It could be a bad connector or a corroded antenna mount.
If you fix it right, then you should be trouble free for the next
inspection.
Dave
Thanks,
Ray
Old March 11th 04, 04:41 PM
mikem
Unfortunately, the frequency that the transponder transmits on is
determined by a vacuum tube in a cavity resonator. Anything that
changes the physical dimensions or impedance of the cavity detunes
it, causing a frequency error.
Changing the coax/antenna shouldn't be enough to mistune the
cavity, but if it was off to one side already, then a changed
load impedance could send it off far enough to fail the test.
A good transponder check measures the center frequency of the
transponder pulse while the transponder is in the aircraft...
MikeM
Thanks,
Ray
Old March 12th 04, 03:42 AM
John
I would be looking for rust or water in the RF connectors and the
antenna ground connections of the transponder antenna. The tube that
is used for the older transponders is affected by the load impedance
of the coax and antenna. If the impedance changes then the TX
frequency changes. Mine is still on frequency even after 27 years
without adjustment.
John
On Thu, 11 Mar 2004 00:49:41 GMT, Ray Godwin
Thanks,
Ray
Idents on VOR+DME if one of them is inop Robert M. Gary Instrument Flight Rules 14 January 24th 05 10:10 AM
Optimal Frequency of Lessons David B. Cole Aerobatics 18 October 28th 04 12:50 AM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 12:18 AM
[FA] - New Hampshire NH Frequency Guide 7th Edition (Coburn) Ken Aviation Marketplace 0 January 19th 04 05:58 PM
