Ack! My ACK!
Old July 10th 03, 04:26 PM
Fastglasair
Default Ack! My ACK!
"Well done, good and faithful servant" Mike, you handled this newsgroup
"situation" admirablely in my opinion (no doubt not worth much here). This web
board is in desperate need of a modicum of civility (a large dose is probably
to much to ask). It goes way beyond normal or reasonable bantering (the dialoge
your posting provoked was mild by comparison to many others I've seen). Some
here need to "get a life" and not find some sick gratification in insulting
others just so they can be a "legend in their own minds". I'm sure I've said to
much and the firestorm of insults will ensue. Fire away, There is only one
opinion I care about and that is "HIS". If you dont agree with "HIM" its of
absoluteley no consequence.
Glasair 1-RG (240HP)
Old July 10th 03, 05:27 PM
Barnyard BOb --
Hey, Goody Two Shoes...
Yes, you have said too much. However...
hope you feel better now that you've vented
your 'holier than thou' spleen.
FWIW...
When I want your OT personal religious input, I will ask.
Until then, civility and political correctness would deem that you
save such remarks for the appropriate forum. No need to chance
offending atheists, Muslims, Jews, Buddhists, etcetera with public
pronouncements of pompous, personal, self serving religious dogma.
BTW...
Time to hold your tongue and practice tolerance of those that you are
so loath to tolerate. Religious hypocrisy really ****es people off !!
Barnyard BOb -- I'm soooo sensitive.
Old July 10th 03, 09:11 PM
Fastglasair
What kind of engine do you have on your glassair? An O-470? I just can't
think
of anything that gives 240 hp.
I have an Angle valve Lyc. IO-360-C1D6, (forward facing injector) Stock it
would put out 200HP. Its not stock, on the test stand/ Dyno it put out 241HP
@2700 rpm. It has 10:1 compression (helicopter) pistons, its balanced,
blueprinted, flowed and ported. It also has an modified cam profile to improve
valve timing and one LSE electronic ignition. I am also using ram air. At max
cruise of 225 knotts I expect to gain an inch or 2 of mp. I expect to do my
first flight in 3 to 5 weeks. I started this project over 18 years ago. I took
a 10 year hiatus since I was lacking time and money to finish it. I will have
about 4,500 hours in it when finished.
Old July 10th 03, 10:26 PM
Russell Kent
@2700 rpm.
On the dyno was it driving all of the accessories? Stated a different way: Is
that 241 an expected prop HP number when installed?
It has 10:1 compression (helicopter) pistons, its balanced, blueprinted, flowed
and ported. It also has an modified cam profile to improve valve timing and one
LSE electronic ignition. I am also using ram air. At max cruise of 225 knotts I
An inch or two of mercury from ram air at 225 kts? I think you're dreaming.
Ideally speaking, dynamic pressure at 200 MPH is 104 pounds per square foot or
about .722 psi. Each inch of mercury is 2.04 psi, so I'd expect just slightly less
than one inch of MP *if* you had a perfect intake diffuser. Since a perfect
intake diffuser is somewhat unlikely, I'd limit my expectations to about 0.5 inch
MP.
I expect to do my first flight in 3 to 5 weeks. I started this project over 18
years ago. I took
Oy, that's a lot of persistence.
Russell Kent
Old July 10th 03, 10:43 PM
Fastglasair
FWIW...
Everybody that has been here any length of time accepts the
fact I am an intolerant curmudgeon among other undesirable
traits and qualities.
Presumptuous statement, I and probably we just "tolerate" you, except when you
have something significant to say.
P.C. & Civility Maybe you can separate them, but the US Govt and I cannot.
P.C. pertains to actual attitudes(opinions, beliefs etc.) which others have
deemed appropriate or inappropriate. Civility pertains to how you communicate.
If you don't agree with "HIM" its of absolutely no consequence. "
I should have added the implied words, no consequence (to me).
Judge not, lest ye be judged... comes to mind
Granted, I can't judge your motives but it is reasonable to make judgments on
actions or statements.
I guess you could call it baiting, however, I just hoped the normal dialogue
might get better.
Best you look up how to spell all these many words before you
get on your high horse requesting me to look up anything.
You're coming off pretty damn lame and stupid.
My only "sin" here is typing too fast and not doing a good proofread, since
there is no spell check.
Bob, I don't know how you carry such a heavy chip on your shoulder. You must be
starting to look like the proverbial Hunch back of...
Old July 10th 03, 11:13 PM
wmbjk
"Russell Kent" wrote in message
Otherwise, pretty good BOb. I'd give it an A. :-)
I'll up that to A+ Bob, since I don't want to judje your spelling lest
mine be judjed. Anyway, you might cut Mr. goody port-and-polished a
little slack. After all, his first flight is coming up soon, and you can
hardly blame him for currying favor if he thinks that might help. Plus,
he claims to know the opinion of HIM, so I'm hoping he'll tell the rest
of us the answer to that SUV thing. :-)
Wayne (affiliated with the Church of the
Get-a-Friend-to-Stand-by-with-an-Axe-and-Fire-Extinguisher)
Old July 11th 03, 06:40 PM
Russell Kent
The only item missing was my 60 amp B&C alternator. I'll loose a little from
that.
Yeah, about 1.5 to 2 HP, depending on how much electrical load you have.
BTW I am using a Whirlwind graphite wrapped hardwood laminate core 3 blade C.S.
prop. 73 inch blades with a S.S. leading edge. It uses a McCauley hub.
While the 3 blade props are generally more aesthetically pleasing, a coarser
pitched 2 bladed prop will always be more efficient (i.e. faster for the same HP).
DBlumel replied:
How about compared to the normal Glasair filter box arrangement? I am going
straight in without a filter and did make a very nice flowed custom diffuser
out of billet aluminum.
Well, if you followed Kuchemann & Weber on the shape of the diffuser then you'll
possibly get close to the ideal pressure recovery. But that's still only slightly
less than 1" MP. I haven't any data on the existing Glasair filter box
arrangement, so I cannot comment on how your intake may perform relative to the
Glasair filter box. It's entirely possible that there is a 2" MP difference
between them.
Do you think operating that carefully built ("customized", perhaps?) IO-360 without
an air filter is really a wise choice? I'd be concerned about dust and debris
damaging the engine.
Russell Kent
Old July 11th 03, 07:14 PM
Fastglasair
HP).
I had other concerns which provoked me to go 3 blade. With a max prop diam. of
73 inches (ground clearance) I felt a 2 blade prop of that diameter would not
effectively handle all the horsepower.
without
debris
It's not my preference, no room to put in a filter and still have room for the
ram also. I intend to change oil very frequently. and I do have a S.S. screen
in the intake to stop large stuff (more than 1/16th inch). I also plan to be
very careful about dust conditions etc.
Old July 11th 03, 07:26 PM
Corrie
"Rude, crude, and socially unacceptable - and those are his good
points," as my uncle the oilman used to say.
Warren & Nancy wrote in message ...
Barnyard BOb -- wrote:
FWIW...
Now that is the understatement of the millenium!
Old July 14th 03, 05:05 PM
Russell Kent
MP.
Richard Tasker replied:
On the planet where I live it is more like each inch of mercury is 0.5 psi (.4912 to be specific). That means your stated .722 psi is in fact approximately 1.47 inches of mercury - certainly within his estimated inch or 2.
Hmmm. Maybe I'm wrong. I figured that a standard day was 29.92 " Hg = 14.7 psi. Therefore 1" Hg = 2.04 psi. And there's where I went wrong. It's the other way around: 2.04 " Hg = 1 psi. So Dick's 1.47 " Hg is correct.
Again, that's predicated on a perfect diffuser, which is doubtful. As a SWAG, 1" Hg (70% of ideal) is probably a reasonable goal (at 200 mph); at 225kts I'd use a linear extrapolation of 1.3" Hg. 2" Hg at 225 kts is still a
dream, however. :-)
Russell "always willing to learn" Kent
