My Trip To The Avionics Shop $$$$$
Old March 28th 04, 05:14 AM
MRQB
Default My Trip To The Avionics Shop $$$$$
Well my bird spent 6 hours at the avionics/instrument shop today getting a
pito static & transponder encoder check now the results
Transponder/Encoder Working 100% To 20,000 feet
Altimeter Working 100% Well With in Specs To 14,000 feet did not go higher
then aircraft service ceiling
VSI Working 100%
Static System Pass
Pito System Fail Has Leak In System = Traced To Airspeed Indicator Leak on
Pito Side Needs Rebuilt Anyone know of a good place to a rebuild have
done or a decent replacement?
Turn Coordinator Bad = Barings Making Noise Needs Rebuilt Anyone know
of a good place to have a rebuild done or a decent replacement?
1 Vor Head OK
1 Vor Head W/ Glide Slope Bad = Localizer Works Great, Vor Is Off 8 Degrees,
Glide Slope don't go to full deflection Non serviceable needs replaced.
Other than my first bill in owning was a fun exciting day in the shop they
were very friendly and explained everything that they were doing and answerd
all my questions i really learned how all the insturments work kinda cool if
i decide to replace instrad of rebuild ill have some that i can take apart
and play with.
Old March 28th 04, 02:45 PM
Dennis O'Connor
Never, never, never, rebuild a gyro instrument that your life depends
upon... Always replace with new...
If the GS head is your only one, then it has to be new... If you have a
backup, then overhaul is OK - in your case it is not capable of an OH and
you don't have a backup GS, so moot point...
On the airspeed, I personally would replace it with new, but since a non
functioning airspeed won't kill you, overhaul is an option...
denny
"MRQB" wrote in message
Old March 28th 04, 03:08 PM
Ray Andraka
I disagree. A good overhaul is just as good as brand new, and may even be
better if you have one of the older units. The overhaul gets all the
bearings replaced and is cleaned up. Gyros are pretty simple mechanical
devices. It is just as likely to have a new one fail as it is an overhauled
unit. Why pay for new for the pieces that don't wear?
denny
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old March 28th 04, 04:48 PM
Newps
Drivel.
Old March 28th 04, 05:47 PM
Jim Weir
The Gyro House
Auburn CA
Possibly the most competent and trustworthy instrument overhaul shop in
existence, certainly in Northern California.
-Pito System Fail Has Leak In System = Traced To Airspeed Indicator Leak on
-Pito Side Needs Rebuilt Anyone know of a good place to a rebuild have
-done or a decent replacement?
-Turn Coordinator Bad = Barings Making Noise Needs Rebuilt Anyone know
-of a good place to have a rebuild done or a decent replacement?
http://www.rst-engr.com
Old March 28th 04, 05:57 PM
G.R. Patterson III
I recommend Bernie Ducasse for instrument repair in the northeast. 215-673-5050.
Ducasse Instrument Service
Northeast Philadelphia Airport
Philadelphia, PA 19114
Here are a few links to outlets for new stuff.
http://www.avionix.com
http://www.gulf-coast-avionics.com
http://www.chiefaircraft.com
http://www.aircraft-spruce.com
http://store.wagaero.com
Wentworth Salvage is a good source for used parts. Also check the front section
of Trade-A-Plane. You might pick up a good deal on a used GS indicator there.
I avoid Century rebuilt instruments. I bought one once. YMMV.
George Patterson
Battle, n; A method of untying with the teeth a political knot that would
not yield to the tongue.
Old March 28th 04, 06:18 PM
Frank Stutzman
Jim Weir wrote:
The Gyro House
Auburn CA
Seconded, even if they didn't get my T&B overhaul right the first time.
They got it the second time and gave me no hassel about sending it back to
them.
They didn't seem to understand me when I said I wanted some extra hummus
to go with my gyro, though.
Frank Stutzman
Bonanza N494B "Hula Girl"
Hood River, OR
Old March 28th 04, 09:08 PM
jsmith
Must be your accent and pronunciation.
Old March 28th 04, 11:31 PM
MRQB
What is the cost differance in a overhauled turn cordinator Vs. a new? if it
is only a little ill buy new
"Frank Stutzman" wrote in message
Jim Weir wrote:
The Gyro House
Auburn CA
them.
Frank Stutzman
Hood River, OR
Old March 28th 04, 11:41 PM
MRQB
Do you have contact info for The Gyro House
"Jim Weir" wrote in message
The Gyro House
Auburn CA
on
have
know
Good Avionincs Shop in Maryland/Northern Virginia Area ?? Jay Somerset Owning 4 February 4th 04 02:49 AM
avionics shop - NJ, Eastern PA, IFR GPS Ken Owning 11 January 22nd 04 06:36 PM
8th-grader wins trip to military jet flight camp Otis Willie Military Aviation 0 January 16th 04 08:40 PM
Used Avionics O. Sami Saydjari Instrument Flight Rules 40 December 2nd 03 02:53 PM
Reflections on first trip to Canada from US Mike & Janet Larke Instrument Flight Rules 1 August 9th 03 12:57 AM
