My 1973 Skyhawk has the 360/180 hp engine carburated.
When the engine is hot it is difficult to start. My procedure is master switch battery side on, fuel pump on. Prime throttle 3 times. Fuel pump off, turn starter while advancing the throttle. Today she would not fire and the battery went south. Any recommendations, suggestions. Will check timing and Magnetos tomorrow. Hank N1441P |
My 1973 Skyhawk has the 360/180 hp engine carburated. When the engine is hot it is difficult to start. My procedure is master switch battery side on, fuel pump on. Prime throttle 3 times. Fuel pump off, turn starter while advancing the throttle. Today she would not fire and the battery went south. Any recommendations, suggestions. Will check timing and Magnetos tomorrow. Hank N1441P On my O-360, when hot, I don't prime at all. Pump throttle once, crack 1/4" and crank. Starts every time. This on a Husky - no fuel pump. No Spam |
When the engine is hot it is difficult to start. My procedure is master switch battery side on, fuel pump on. Prime throttle 3 times. Fuel pump off, turn starter while advancing the throttle. Today she would not fire and the battery went south. Any recommendations, suggestions. Will check timing and Magnetos tomorrow. Hank N1441P On my O-360, when hot, I don't prime at all. Pump throttle once, crack 1/4" and crank. Starts every time. This on a Husky - no fuel pump. Same here on my 360/180 powered Maule. In warm weather, cold starts are easy with 3 pumps of throttle, when engine is already hot, 1 pump does it. No primer except with temp is 55F or less. Never use the fuel pump. |
Put a carburetor on the bench from a 180hp Lycoming and fill it with fuel.
Pump the throttle(once) and watch the fuel hit the ceiling. You'll never pump the throttle again when the engine is hot!!! It's best just to go rich( a hot start, not fuel injected) and crack the throttle, crank a half a dozen blades, should start if engine is OK. I believe there is more fuel thrown to the engine with the throttle than the primer. Remember, the primer only adds fuel to three of the cylinders and not the fourth, so that helps on a hot start is one pump is needed from the primer. John Prince From: "Nathan Young" Subject: HOT start 180HP engine Date: Monday, March 29, 2004 8:14 AM On 28 Mar 2004 22:32:48 GMT, (Hankal) wrote: My 1973 Skyhawk has the 360/180 hp engine carburated. When the engine is hot it is difficult to start. My procedure is master switch battery side on, fuel pump on. Prime throttle 3 times. Fuel pump off, turn starter while advancing the throttle. Today she would not fire and the battery went south. Master, fuel pump, no primer, mixture rich, crack throttle. Crank. After 2 tries, if it will not start in this manner, then I assume it is not longer 'hot' and prime regularly. This is on a Cherokee 180... I believe it is easier to start than most when hot. -Nathan |
Quite correct. If you think about the rather large *quantity* of fuel
squirted out of the updraft carb with the accelerator pump, you won't want to use it to prime again... *especially* on a hot engine. Since it can take a bit to get fuel through the intake runners (since it was shut down with the cutoff), I will sometimes give it 1/2 to 1 squirt with the throttle, but only while already cranking. If you do it before you're cranking, you're guaranteeing fuel pooling up on the intake ducting to the carb... you know, right by the fuzzy oil-soaked air filter material. ![]() -Cory John P wrote: : Put a carburetor on the bench from a 180hp Lycoming and fill it with fuel. : Pump the : throttle(once) and watch the fuel hit the ceiling. You'll never pump the : throttle again when : the engine is hot!!! It's best just to go rich( a hot start, not fuel : injected) and crack the throttle, : crank a half a dozen blades, should start if engine is OK. I believe there : is more fuel thrown to the engine : with the throttle than the primer. Remember, the primer only adds fuel to : three of the cylinders and : not the fourth, so that helps on a hot start is one pump is needed from the : primer. : John Prince : From: "Nathan Young" : Subject: HOT start 180HP engine : Date: Monday, March 29, 2004 8:14 AM : On 28 Mar 2004 22:32:48 GMT, (Hankal) wrote: :My 1973 Skyhawk has the 360/180 hp engine carburated. :When the engine is hot it is difficult to start. :My procedure is master switch battery side on, fuel pump on. Prime throttle : 3 :times. Fuel pump off, turn starter while advancing the throttle. :Today she would not fire and the battery went south. : Master, fuel pump, no primer, mixture rich, crack throttle. Crank. : After 2 tries, if it will not start in this manner, then I assume it : is not longer 'hot' and prime regularly. : This is on a Cherokee 180... I believe it is easier to start than : most when hot. : -Nathan -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
I have the same engine in my C-172F. If the engine is hot, why are you
priming? You only need to do that the first thing, sometimes. When hot the only thing I do is hit the fuel pump to bring up the pressure, turn it off, then crank. If it doens't catch right away, I will pump the throttle once while cranking. I generrally start quickly every time. Now, when I do flood it; mixture cut-off and thottle full open and crank til start. Then mixture full rich and throttle 1/4" set. Ross Hankal wrote: My 1973 Skyhawk has the 360/180 hp engine carburated. When the engine is hot it is difficult to start. My procedure is master switch battery side on, fuel pump on. Prime throttle 3 times. Fuel pump off, turn starter while advancing the throttle. Today she would not fire and the battery went south. Any recommendations, suggestions. Will check timing and Magnetos tomorrow. Hank N1441P |
I have a stupid unrelated question.
Why do you have a fuel pump on a '73 carbed 'Hawk? I assume it is related to the 180 upgrade and I ask because I have that in the back of my mind for overhaul time. Mike Z "Hankal" wrote in message ... My 1973 Skyhawk has the 360/180 hp engine carburated. When the engine is hot it is difficult to start. My procedure is master switch battery side on, fuel pump on. Prime throttle 3 times. Fuel pump off, turn starter while advancing the throttle. Today she would not fire and the battery went south. Any recommendations, suggestions. Will check timing and Magnetos tomorrow. Hank N1441P |
My '65 C-172 with the 180 conversion also has a fuel pump installed.
Ross "Mike Z." wrote: I have a stupid unrelated question. Why do you have a fuel pump on a '73 carbed 'Hawk? I assume it is related to the 180 upgrade and I ask because I have that in the back of my mind for overhaul time. Mike Z "Hankal" wrote in message ... My 1973 Skyhawk has the 360/180 hp engine carburated. When the engine is hot it is difficult to start. My procedure is master switch battery side on, fuel pump on. Prime throttle 3 times. Fuel pump off, turn starter while advancing the throttle. Today she would not fire and the battery went south. Any recommendations, suggestions. Will check timing and Magnetos tomorrow. Hank N1441P |
| Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 07:42 PM |
| Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 04:03 PM |
| What if the germans... | Charles Gray | Military Aviation | 119 | January 27th 04 12:20 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
