O-320 way rich after Major + 160HP conversion + Powerflow
Old April 2nd 04, 02:18 AM
Ron Rosenfeld
On Thu, 1 Apr 2004 18:42:17 -0500, "Dave Gribble"
This is the exact procedure we've used to set the mixture. The idle is 650
rpm and the increase when you move to cut-off is only about 25 rpm.
The problem is that it still seems too rich, especially in the pattern with
carb heat on.
Then there is something else going on besides the mixture adjustment. Have
you checked with the folk that hold the STC for the engine and exhaust
mods?
Old April 2nd 04, 02:52 AM
On 1-Apr-2004, Ron Rosenfeld wrote:
No experience with the O320, but with the Lycoming O360's, the procedure
to
set proper mixture should be doable on the ground.
1. Start engine and warm up until CHT's and oil temps are normal.
2. Mag check -- if normal, proceed.
3. Set throttle set screw so idle is per airframe mfg recommendation.
4. Slowly move mixture control towards idle cut-off and observe rpm. An
increase of more than 50 RPM indicates the mixture is too rich. (An
immediate decrease, if not preceded by a momentary increase, indicates the
mixture is too lean).
5. When performing step 4, don't let the engine cut out.
6. Adjust the mixture control in the proper direction; run up to 2000 RPM
to "clear" the engine, and repeat the above as necessary. If the mixture
change has changed the idling RPM, that should be re-adjusted as needed.
7. If the setting does not remain stable, check the idle linkage for
looseness.
If the goal here is to set the mixture control linkage so that "proper"
mixture occurs with the control at the full lean position, then this had
better be done at or near sea level density altitude. How is the procedure
done on the ground in Denver?
-Elliott Drucker
Old April 2nd 04, 04:15 AM
Dave Gribble
No, that will be next. I think there are actually 2 STCs, one for the
exhaust (Powerflow) and one for the 160 HP conversion (Superior Air Parts, I
think). I wonder if the problem is in combining these 2 STCs?
"Ron Rosenfeld" wrote in message
650
with
carb heat on.
Have
mods?
Old April 2nd 04, 11:38 AM
Ron Rosenfeld
On Thu, 1 Apr 2004 22:15:16 -0500, "Dave Gribble"
I suppose it could be. But the 160HP converted engine should be listed as
an allowable engine for the Powerflo system. Or vice versa.
Old April 3rd 04, 05:04 AM
On Fri, 2 Apr 2004 13:59:49 +0000 (UTC),
OK... I'll concede that I oversimplified a bit.... The air/fuel ratio (as
in mass-air/fuel, like 12.5:1, 14:1, etc) does change when the throttle is moved.
Even without changing altitude, if the mixture is set to peak EGT, for example,
increasing MP by an inch will lean the engine (unless it's starting to enter the
full-throttle fuel enrichment regime). It's probably somewhere between the two
extremes (absolute fuel vs. relative fuel).
Actually, you hit it pretty close. You do need to remember that aside
from the mixture control (and probably a crude economizer circuit), we
are talking about a one-barrel gasoline tractor carburetor.
On a MS carb, the "mixture control" is a chunk of brass on the end of
a two inch piece of flex cable (similiar to a tach cable). The mixture
knob rotates an arm clamped onto the top of the cable, rotating the
piece of brass on the bottom.
This piece of brass is stuck inside a brass cup on the bottom of the
fuel bowl with a "window" in it. At ICO, the window is "shut", at full
rich, the window is wide open.
The fuel gets sucked by the venturi out of the bottom of the bowl,
through the window, and out the main metering nozzle on the carb into
the induction airstream. The combination of the venturi type and the
main metering nozzle determines how much suction (relative to the
ambient pressure in the fuel bowl and the float/fuel level) is
generated "through" the valve.
Throttle plate position/engine rpm will indeed vary airflow through
the venturi, and consequently will affect the amount of suction. But
as you've indicated, the mixture control is a manually variable (with
the mixture knob) mechanical restriction to this suction. There is no
mechanical interconnect between the mixture valve and the throttle.
TC
Japanese firm sold Libya uranium conversion plant Dav1936531 Military Aviation 2 March 17th 04 03:47 PM
Help Me Get Rich Please 7865 Andy McKenzie Home Built 9 March 14th 04 11:53 PM
Please Help Me Get Rich 8685 Ray Andraka Owning 2 March 12th 04 01:16 PM
Auto conversion cost post Richard Riley Home Built 13 December 28th 03 12:52 PM
Thanks for the Spins Rich David B. Cole Aerobatics 17 October 26th 03 08:37 AM
