I purchased a C0 Experts Model 2002 about 1 month ago (it is quite
precise and I am generally pleased with it). When I am climbing out from take-off, I am experiencing relatively high readings of CO, on the order of 30 Parts Per Million (PPM). This only lasts about 20 minutes or so. At cruise, it drops to below 10 PPM (considered normal). (a) Does anyone else have any hard data about their CO concentration levels in various phases of flight? (b) I have read that anything above 10 PPM should be checked by an A&P, but I have read elsewhere that something like 30PPM for short periods is not a big deal. Are there any medical-types out there that can weigh in on this issue? |
On Thu, 01 Apr 2004 23:31:51 -0600, "O. Sami Saydjari"
wrote: I purchased a C0 Experts Model 2002 about 1 month ago (it is quite precise and I am generally pleased with it). When I am climbing out from take-off, I am experiencing relatively high readings of CO, on the order of 30 Parts Per Million (PPM). This only lasts about 20 minutes or so. At cruise, it drops to below 10 PPM (considered normal). (a) Does anyone else have any hard data about their CO concentration levels in various phases of flight? (b) I have read that anything above 10 PPM should be checked by an A&P, but I have read elsewhere that something like 30PPM for short periods is not a big deal. Are there any medical-types out there that can weigh in on this issue? I had a home type CO monitor supposedly sensitive to 1-3ppm. It would occasionally read 25ppm if I was on the ground and behind another a/c. It would rarely alarm on the ground when I was not behind another a/c. I suspected that had to do with wind blowing exhaust in a particular direction. It always dropped to undetectable levels during the takeoff roll. 30ppm for a few minutes won't damage you, but I'd sure have your exhaust system checked by a competent technician. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
wrote: I purchased a C0 Experts Model 2002 about 1 month ago (it is quite precise and I am generally pleased with it). When I am climbing out from take-off, I am experiencing relatively high readings of CO, on the order of 30 Parts Per Million (PPM). This only lasts about 20 minutes or so. At cruise, it drops to below 10 PPM (considered normal). (a) Does anyone else have any hard data about their CO concentration levels in various phases of flight? (b) I have read that anything above 10 PPM should be checked by an A&P, but I have read elsewhere that something like 30PPM for short periods is not a big deal. Are there any medical-types out there that can weigh in on this issue? If you haven't already, it might be interesting to try a couple of test climbs with cabin heat & defrost on and off. If the PPM went up when using the heat, I would definitely have an A&P look at your exhaust/heating exchange system. |
On the ground, at 70PPM for 20 minutes you will start to experience a
headache. 30PPM @ 20 minutes should not be a problem unless you're climbing to ~ 8000 or are a smoker or suffer from some respiratory malady or are in a constant state of inactivity (a lazy *******) . I would first look real hard for any openings in your firewall to seal and from there go to any exhaust compromise. I would then have the ignition and carburetion systems checked to determine why you're burning so dirty. For those who aren't able to think, although 30 ppm at the exhaust pipe isn't high, that much leak into the cabin indicates a bigger problem at the dump. And as CO is a byproduct of the incomplete combustion of a fossil fuel, it indicates something amiss in the cylinders. On Thu, 01 Apr 2004 23:31:51 -0600, "O. Sami Saydjari" wrote: I purchased a C0 Experts Model 2002 about 1 month ago (it is quite precise and I am generally pleased with it). When I am climbing out from take-off, I am experiencing relatively high readings of CO, on the order of 30 Parts Per Million (PPM). This only lasts about 20 minutes or so. At cruise, it drops to below 10 PPM (considered normal). (a) Does anyone else have any hard data about their CO concentration levels in various phases of flight? (b) I have read that anything above 10 PPM should be checked by an A&P, but I have read elsewhere that something like 30PPM for short periods is not a big deal. Are there any medical-types out there that can weigh in on this issue? |
I've used one of the digitals for a long time and they really help
keep an eye on whats going on. It's helped me spot exhaust problems I would have otherwise missed. Some observations based on my experience: * I typically see it in the 20s on the ground .. maybe a tad higher if I'm positioned such that the exhaust is entering the outside air vent. In the air seldom more than 10ppm. * When I was having some trouble with cracked risers I'd see it in the upper 30s to 40s.. on the ground and in the air. While a higher reading isn't always alarming on the ground if it stays that way in the air there's a leak somewhere. * If it goes up when you turn on the cabin heat have the muffler checked inside the shroud. * Sometimes getting the seam between the muffler and risers to seal can be a challenge. I've found in those instances I'd see a reading in the teens in the air from it seeping into the cabin from the engine compartment. As a comparison .. in the winter I often use a propane construction heater in the hangar if I have something to do on the plane. When I do I also keep the CO meter handy. I'll see consistent readings in the 30s. While I've never had any headaches or anything doing this after a couple hours my eyes will start to burn a little and I generally limit this to a couple hours at a time. These meters when used regularly will really help you spot trends that are out of the ordinary for your plane that you wouldn't otherwise catch. "Stu Gotts" wrote in message ... On the ground, at 70PPM for 20 minutes you will start to experience a headache. 30PPM @ 20 minutes should not be a problem unless you're climbing to ~ 8000 or are a smoker or suffer from some respiratory malady or are in a constant state of inactivity (a lazy *******) . I would first look real hard for any openings in your firewall to seal and from there go to any exhaust compromise. I would then have the ignition and carburetion systems checked to determine why you're burning so dirty. For those who aren't able to think, although 30 ppm at the exhaust pipe isn't high, that much leak into the cabin indicates a bigger problem at the dump. And as CO is a byproduct of the incomplete combustion of a fossil fuel, it indicates something amiss in the cylinders. On Thu, 01 Apr 2004 23:31:51 -0600, "O. Sami Saydjari" wrote: I purchased a C0 Experts Model 2002 about 1 month ago (it is quite precise and I am generally pleased with it). When I am climbing out from take-off, I am experiencing relatively high readings of CO, on the order of 30 Parts Per Million (PPM). This only lasts about 20 minutes or so. At cruise, it drops to below 10 PPM (considered normal). (a) Does anyone else have any hard data about their CO concentration levels in various phases of flight? (b) I have read that anything above 10 PPM should be checked by an A&P, but I have read elsewhere that something like 30PPM for short periods is not a big deal. Are there any medical-types out there that can weigh in on this issue? |
![]() If you haven't already, it might be interesting to try a couple of test climbs with cabin heat & defrost on and off. If the PPM went up when using the heat, I would definitely have an A&P look at your exhaust/heating exchange system. Good suggestion. I should have mentioned that I tried that and that it seems independent of heating and defronsting settings. -Sami |
wrote: I purchased a C0 Experts Model 2002 about 1 month ago (it is quite precise and I am generally pleased with it). When I am climbing out from take-off, I am experiencing relatively high readings of CO, on the order of 30 Parts Per Million (PPM). This only lasts about 20 minutes or so. At cruise, it drops to below 10 PPM (considered normal). (a) Does anyone else have any hard data about their CO concentration levels in various phases of flight? (b) I have read that anything above 10 PPM should be checked by an A&P, but I have read elsewhere that something like 30PPM for short periods is not a big deal. Are there any medical-types out there that can weigh in on this issue? In Canada you can work in up to 35ppm for 8hours. 30 ppm isn't a big deal for a short time but you might want to check your firewall for leaks. |
On Sat, 03 Apr 2004 00:58:01 GMT, (Drew
Dalgleish) wrote: In Canada you can work in up to 35ppm for 8hours. 30 ppm isn't a big deal for a short time but you might want to check your firewall for leaks. Remember, that's at ground level! |
On my Arrow, normal cabin airflow is through heat or ventilation ducts
in front of the cabin, exiting underneath the plane. If the heat and vents are off, there can be enough air leaks around the door, etc to reverse that flow, which can pick up exhaust underneath the airplane. This situation has been improved a lot with the new door seals from Dick Russ. |
Cabin Led Lights | fly low | Aviation Marketplace | 0 | December 19th 04 03:03 AM |
Piper Warrior Cabin Heat Box | Piperflyer | Owning | 2 | February 16th 04 03:20 AM |
FS: Cessna 172 Cabin Cover | Jon Hicks | Aviation Marketplace | 0 | December 28th 03 01:44 PM |
cabin noise locations & dogs | [email protected] | Owning | 9 | August 30th 03 09:26 PM |
Cabin pressurization | Mike Borgelt | Home Built | 1 | July 5th 03 04:25 AM |
