Kitplanes Columns
Old April 6th 04, 08:26 PM
G.R. Patterson III
Jim Weir wrote:
First person to post here that they looked at the files, they understand (more
or less) the task at hand, and are willing to take a crack at the first one has
it.
Ok, Jim. I looked at the files and put together the pages for August from the files
you provided. I did have to change the "oopsie" page from a pdf download to an html
file, since I can't create pdfs. I will send you a zip file shortly.
What's next?
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
a'drinkin' with lovin' on your mind".
Old April 7th 04, 04:54 PM
EDR
In article , G.R. Patterson III
(more
has
it.
files
an html
George, forward whatever you want converted to PDF to me. I have a full
version of Acrobat.
Old April 8th 04, 04:16 AM
G.R. Patterson III
version of Acrobat.
Thanks for the offer. I found a free program on the web that converts Word files to
pdf using the print option. Seems to work pretty well. Jim now has to copy or move
the zip files to a directory where I can download them. That takes time, and his
business comes first, of course. I suppose email could also be used, but I don't know
how many issues he could send before my mailbox fills up.
George Patterson
Old April 8th 04, 04:40 PM
Jim Weir
George Patterson took the task on and has done an absolutely splendid job
translating the first article.
To have a looksee a George's handiwork, www.rstengineering.com/kitplanes and go
to the bottom article (July '02).
George, the gang owes you one, and so do I.
The August '02 raw data is posted in the usual place.
-Again I ask...is anybody fool enough to take my Kitplanes column raw data and
-put it into downloadable format for the rest of the gang?
http://www.rst-engr.com
Old April 8th 04, 06:32 PM
Dave Butler
Not Found
The requested URL /kitplanes/KP0207/KPtext.pdf was not found on this server.
Apache/1.3.20 Server at www.rst-engr.com Port 80
Dave
Old April 8th 04, 06:34 PM
Jim Weir
George...
In terms that any competent history major can understand, can you tell me how
you want me to fix this type mismatch?
-There's two mismatches between the KP0207.htm file and the other files: the
parts
-list file and full test PDF are Kpparts.pdf and Kptext.pdf on the webserver,
but are
-KPparts.pdf and KPText.pdf in the URLs in the KP0207.htm file (note the case
-difference in the "P"s). So the real URLs to the full text and parts list
a
-http://www.rst-engr.com/kitplanes/KP0207/Kpparts.pdf
-http://www.rst-engr.com/kitplanes/KP0207/Kptext.pdf
-I imagine that the above to references will break here shortly when Jim fixes
-KP0207.htm file or renames the PDFs.
-Russell Kent
Old April 8th 04, 06:42 PM
frank
Works in Texas...
"Dave Butler" wrote in message
and go
Not Found
server.
Dave
Old April 8th 04, 06:59 PM
Russell Kent
Not Found
Dave
There's two mismatches between the KP0207.htm file and the other files: the parts
list file and full test PDF are Kpparts.pdf and Kptext.pdf on the webserver, but are
difference in the "P"s). So the real URLs to the full text and parts list a
I imagine that the above to references will break here shortly when Jim fixes the
Russell Kent
Old April 8th 04, 09:33 PM
G.R. Patterson III
Well, the fastest way to fix it is to rename the two files to match the URLs.
Alternately, I can change the URLs in the html file and resend that. If you go the
first route, rename "Kpparts.pdf" to "KPparts.pdf" and rename "Kptext.pdf" to
"KPText.pdf". The difference in names also exists on my computer; the reason I didn't
catch it is that the link still works for me. It didn't show up in testing.
I'll double-check for that sort of thing with August.
George Patterson
Old April 8th 04, 10:38 PM
Jim Weir
Renamed both the files with the KP prefix. Try to break it again, if you would
please.
parts
Does anyone have Kitplanes Mag's from 1986? Nunya Home Built 10 June 21st 11 07:22 AM
unfair cartoon in October 2004 issue of KITPLANES Bob Kaplow Home Built 31 August 29th 04 02:00 PM
Columns by a Canadian centre controller David Megginson Instrument Flight Rules 1 August 9th 04 10:05 PM
Kitplanes August Issue Badwater Bill Home Built 28 July 6th 04 08:26 PM
Kitplanes Columns Jim Weir Home Built 30 April 14th 04 08:23 PM
