#21
"G.R. Patterson III" wrote in message
... Jim Weir wrote: In terms that any competent history major can understand, can you tell me how you want me to fix this type mismatch? Well, the fastest way to fix it is to rename the two files to match the URLs. Alternately, I can change the URLs in the html file and resend that. If you go the first route, rename "Kpparts.pdf" to "KPparts.pdf" and rename "Kptext.pdf" to "KPText.pdf". The difference in names also exists on my computer; the reason I didn't catch it is that the link still works for me. It didn't show up in testing. I'll double-check for that sort of thing with August. George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". Easiest in the future to use all lowercase for filenames and URLs. It avoids problems with Win/DOS being case insensitive. |
Some web authouring software (Windoze based) will use upper/lower case in
the program and html files then safe the respective files in all lowercase which works ok if your ISP uses a Windows based web server, but with a lot of servers running Linux OS and Apache web server it will not work if you use FTP to upload your files but probably will work if you use their program to "publish to the web". I have 3 web sites I maintain and I have to manually edit the HTML files each time I update to correct the case problem. John G.R. Patterson III wrote: Jim Weir wrote: In terms that any competent history major can understand, can you tell me how you want me to fix this type mismatch? Well, the fastest way to fix it is to rename the two files to match the URLs. Alternately, I can change the URLs in the html file and resend that. If you go the first route, rename "Kpparts.pdf" to "KPparts.pdf" and rename "Kptext.pdf" to "KPText.pdf". The difference in names also exists on my computer; the reason I didn't catch it is that the link still works for me. It didn't show up in testing. I'll double-check for that sort of thing with August. George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
"G.R. Patterson III" writes:
Jim Weir wrote: In terms that any competent history major can understand, can you tell me how you want me to fix this type mismatch? Well, the fastest way to fix it is to rename the two files to match the URLs. Alternately, I can change the URLs in the html file and resend that. If you go the first route, rename "Kpparts.pdf" to "KPparts.pdf" and rename "Kptext.pdf" to "KPText.pdf". The difference in names also exists on my computer; the reason I didn't catch it is that the link still works for me. It didn't show up in testing. Please... keep all file names lower case. Also, please, please be really pedantic on URL filesnames: Only: 0-9, a-z, _ - . No other characters. No !@#$:;%^&*()+|\/ {I swear I must have seen each one in some URL sometime.} Yea, you may get away with it for a while, until you start getting into cross-platform situations. Then you have a mess. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
#24
Jim Weir wrote:
Renamed both the files with the KP prefix. Try to break it again, if you would please. Seems fine now. Dave |
#25
![]() FUji wrote: Easiest in the future to use all lowercase for filenames and URLs. It avoids problems with Win/DOS being case insensitive. I am now FTPing the files up to a directory on my web site for testing. Since most web servers are UNIX boxes, I expect that any problems in this regard will pop up immediately. George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
#26
On Thu, 08 Apr 2004 03:16:28 +0000, G.R. Patterson III wrote:
EDR wrote: George, forward whatever you want converted to PDF to me. I have a full version of Acrobat. Thanks for the offer. I found a free program on the web that converts Word files to pdf using the print option. Seems to work pretty well. Jim now has to copy or move the zip files to a directory where I can download them. That takes time, and his business comes first, of course. I suppose email could also be used, but I don't know how many issues he could send before my mailbox fills up. Worth offering that Open Office has excellent support for directly exporting to PDF format. No extra plugins required. Open Office is completely free. If you're curious, take a look at http://www.openoffice.org. |
Does anyone have Kitplanes Mag's from 1986? | Nunya | Home Built | 10 | June 21st 11 07:22 AM |
unfair cartoon in October 2004 issue of KITPLANES | Bob Kaplow | Home Built | 31 | August 29th 04 02:00 PM |
Columns by a Canadian centre controller | David Megginson | Instrument Flight Rules | 1 | August 9th 04 10:05 PM |
Kitplanes August Issue | Badwater Bill | Home Built | 28 | July 6th 04 08:26 PM |
Kitplanes Columns | Jim Weir | Home Built | 30 | April 14th 04 08:23 PM |
