Kitplanes Columns
Old April 8th 04, 10:49 PM
FUji
"G.R. Patterson III" wrote in message
Jim Weir wrote:
In terms that any competent history major can understand, can you tell
me how
you want me to fix this type mismatch?
Well, the fastest way to fix it is to rename the two files to match the
URLs.
Alternately, I can change the URLs in the html file and resend that. If
you go the
first route, rename "Kpparts.pdf" to "KPparts.pdf" and rename "Kptext.pdf"
to
"KPText.pdf". The difference in names also exists on my computer; the
reason I didn't
catch it is that the link still works for me. It didn't show up in
testing.
I'll double-check for that sort of thing with August.
George Patterson
This marriage is off to a shaky start. The groom just asked the band
to
play "Your cheatin' heart", and the bride just requested "Don't come
home
a'drinkin' with lovin' on your mind".
Easiest in the future to use all lowercase for filenames and URLs. It
avoids problems with Win/DOS being case insensitive.
Old April 9th 04, 02:32 AM
UltraJohn
Some web authouring software (Windoze based) will use upper/lower case in
the program and html files then safe the respective files in all lowercase
which works ok if your ISP uses a Windows based web server, but with a lot
of servers running Linux OS and Apache web server it will not work if you
use FTP to upload your files but probably will work if you use their
program to "publish to the web".
I have 3 web sites I maintain and I have to manually edit the HTML files
each time I update to correct the case problem.
John
G.R. Patterson III wrote:
Jim Weir wrote:
In terms that any competent history major can understand, can you tell me
how you want me to fix this type mismatch?
URLs. Alternately, I can change the URLs in the html file and resend that.
If you go the first route, rename "Kpparts.pdf" to "KPparts.pdf" and
rename "Kptext.pdf" to "KPText.pdf". The difference in names also exists
on my computer; the reason I didn't catch it is that the link still works
for me. It didn't show up in testing.
George Patterson
to play "Your cheatin' heart", and the bride just requested "Don't
come home a'drinkin' with lovin' on your mind".
Old April 9th 04, 05:33 AM
David Lesher
"G.R. Patterson III" writes:
Jim Weir wrote:
In terms that any competent history major can understand, can you tell me how
Well, the fastest way to fix it is to rename the two files to match the URLs.
Alternately, I can change the URLs in the html file and resend that. If you go the
first route, rename "Kpparts.pdf" to "KPparts.pdf" and rename "Kptext.pdf" to
"KPText.pdf". The difference in names also exists on my computer; the reason I didn't
catch it is that the link still works for me. It didn't show up in testing.
Please... keep all file names lower case. Also, please, please be really
pedantic on URL filesnames:
Only:
0-9, a-z, _ - .
No other characters. No !@#$:;%^&*()+|\/ {I swear I must have seen
each one in some URL sometime.}
Yea, you may get away with it for a while, until you start getting
into cross-platform situations. Then you have a mess.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old April 9th 04, 02:04 PM
Dave Butler
Jim Weir wrote:
Renamed both the files with the KP prefix. Try to break it again, if you would
please.
Seems fine now. Dave
Old April 10th 04, 03:23 AM
G.R. Patterson III
I am now FTPing the files up to a directory on my web site for testing. Since most
web servers are UNIX boxes, I expect that any problems in this regard will pop up
immediately.
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
Old April 14th 04, 08:23 PM
Greg Copeland
On Thu, 08 Apr 2004 03:16:28 +0000, G.R. Patterson III wrote:
EDR wrote:
George, forward whatever you want converted to PDF to me. I have a full
version of Acrobat.
Thanks for the offer. I found a free program on the web that converts Word files to
pdf using the print option. Seems to work pretty well. Jim now has to copy or move
the zip files to a directory where I can download them. That takes time, and his
business comes first, of course. I suppose email could also be used, but I don't know
how many issues he could send before my mailbox fills up.
Worth offering that Open Office has excellent support for directly
exporting to PDF format. No extra plugins required. Open Office is
completely free. If you're curious, take a look
at http://www.openoffice.org.
Does anyone have Kitplanes Mag's from 1986? Nunya Home Built 10 June 21st 11 07:22 AM
unfair cartoon in October 2004 issue of KITPLANES Bob Kaplow Home Built 31 August 29th 04 02:00 PM
Columns by a Canadian centre controller David Megginson Instrument Flight Rules 1 August 9th 04 10:05 PM
Kitplanes August Issue Badwater Bill Home Built 28 July 6th 04 08:26 PM
Kitplanes Columns Jim Weir Home Built 30 April 14th 04 08:23 PM
