#21
"mikem" wrote in message
... Last time I had it done by an on-field business, it cost about $150. Call around. Btw, the standard practice seems to be not to actually drain all of the fluids; rather, the fluids are "backed out" of the calculations to get the "empty weight and moment". That's how I got into this conversation in the first place, and why I think my existing W&B is out! |
Tony Cox wrote:
That's how I got into this conversation in the first place, and why I think my existing W&B is out! I thought that your point was that the AP who did the last W&B weighed it with the fluids in place, but then subtracted the "consumable fluids", but forgot to account for the "unusable" fluids? The differences in weighing proceedures shown for various models on the 182 TCDS either call for computing a "dry" weight, or a "wet" weight where the aircraft is ready to fly, but contains only the "unusable fluids". I cannot conceive a situation where the capacity of your fuel tanks could change by ~ 10 gallons unless some major mods were done to the fuel system, i. e. plastic liners inplace of bladders, etc. The "unusable" fuel in my 182 is only 3 gal (79 usable, 82 total), so even if the AP did the calc wrong, we would be quibling about only ~ 18lbs. How you think you got screwed out of 60lb? MikeM |
"MikeM" wrote in message
... The "unusable" fuel in my 182 is only 3 gal (79 usable, 82 total), so even if the AP did the calc wrong, we would be quibling about only ~ 18lbs. How you think you got screwed out of 60lb? I added all the mods that had happened over the years to the data sheet W&B (with the exception of a paint job, which I assumed ended up being a wash). There was a 60lb difference, which I attribute to the A&P mathematically subtracting 79 gals of fuel when there was actually more). I assume that the 10 gals difference that this represents is made up of some unusable (which the A&P forgot to account for) and some extra buffer courtesy of Cessna. The POH claims 5 gals unusable. Also, I drained the tanks once for an SB (and for fun) when the 'stick' indicated 20 gals. I drained nearly 7 5gallon drums worth. |
How long to keep VOR check records? | Ross Oliver | Instrument Flight Rules | 27 | April 10th 04 06:57 PM |
F-22 Lies | robert arndt | Military Aviation | 59 | January 18th 04 05:43 AM |
D'Amato's Role Investigated in La Guardia Airport Deal | Roy Smith | General Aviation | 0 | December 25th 03 05:47 AM |
Flyong from Toronto (Ontario) to Pitsburg Intl | Anthony Acri | Instrument Flight Rules | 3 | July 26th 03 05:28 PM |
