Cirrus SR22 Purchase advice needed.
Old April 28th 04, 04:39 AM
Dave Stadt
"C J Campbell" wrote in message
"Vaughn Simon" wrote in message
"Michael" wrote in message
om...
Therefore, the Cirrus cannot
recover from a spin when below 900' AGL. Many other aircraft can.
Name one aircraft that can cruise better than 170 kts, carry four
people, and can recover from a spin at 900 AGL.
The occupants of a Cirrus can hope to "survive" a spin from 900 AGL
How so, if the Cirrus cannot recover from a spin and the parachute needs
more than 900 feet to deploy?
Not to mention reaction time which would add hundreds of feet to the
equation.
  #142
Old April 28th 04, 07:38 AM
C J Campbell
"Greg Copeland" wrote in message
news
AGL
Ya, that's the point I brought up in another subthread here, which went
unanswered. Maybe you can help.
If the deployment requires 920, does that mean after 920 you can safely
touchdown or does that mean it requires 920 + however long it takes to
slow your velocity to proper touchdown velocity? I ask because, I don't
think a chute opening 10 AGL is going to help much.
I believe the POH says that is the altitude necessary to safely touch down.
Whether it could be of any help before that I don't know. Even partially
opened the parachute is going to add some drag, but what happens is that the
parachute is pulled out by a rocket. Instead of opening instantly (which
would destroy the chute) a Teflon coated ring slides down the shroud lines
to allow the chute to open in a controlled manner. The airplane continues
moving forward during all this process. Once the chute is opened, the
airplane swings down under the canopy. So dropping that last few feet just
as the parachute opens the airplane's rate of descent might not be slowed at
all.
All of that assumes that the airplane is in normal forward flight. The
Cirrus spins in a flat attitude and it might not have all that much forward
motion. I guess the actual altitude needed would vary some depending on just
what the airplane is doing at the time the CAPS system is deployed.
  #143
Old April 28th 04, 11:29 AM
Vaughn
OK, perhaps it is 920 feet; my point was that use of the BRS to "survive" a
spin is hardly the same as "recovering" from a spin as we have always understood
it. After a normal spin recovery in a normal airplane, there is typically no
reason to ring up the insurance company.
To respond to another point, the minimum BRS recovery altitude would also
depend somewhat on density altitude. For example; given the same low AGL, you
might not get the same happy results in Denver that you previously got in Miami.
Vaughn
  #144
Old April 28th 04, 02:28 PM
Greg Copeland
equation.
And that assumes you didn't waste time trying to recover in the first
place.
  #145
Old April 28th 04, 02:49 PM
Bill Denton
So now we come back to some of the points I made early on in this thread...
One of the problems is getting the pilot to absolutely ignore both human
nature and his training and immediately deploy the BRS with no attempt at
recovery from the spin.
Because if the pilot doesn't follow this procedure, no questions asked, the
delay resulting from going through a recovery process and the associated
thought processes may well put the pilot below the effective altitude of the
BRS.
You're working against both existing training and instincts, and
Cirrus-specific training that simply tells a pilot about the specific
characteristics of the airplane is useless. The training needs to absolutely
pound these differences into the pilot's head. And until that type of
training is done the Cirrus will continue to have a less-than-stellar
accident record...
news
equation.
place.
  #146
Old April 28th 04, 03:28 PM
Dude
I will look for the dates for you.
I do not recall the words "cylinder failure" anywhere, just that there was
major engine work, top overhauls, and fears of needing rebuilds in the near
future.
I see someone
"Mike Murdock" wrote in message
Dude,
I am a COPA member, and I read the members forum regularly, and I don't
remember seeing anything about premature cylinder failure. However, since
there are over 50,000 posts there, I'm willing to admit that I might have
missed one or two
Do you still have the COPA posts you were forwarded? If you can give me
date they were posted, or the name of the person who posted them, or any
unique keywords from the post, I'd be happy to look them up and post a
synopsis here. I've already searched for "shock cooling" without finding
the posts you mentioned.
I'm sincerely interested since I own an SR22, and if the engine is going
to
go Tango Uniform at 700 hours, I'd like to know. I do know that several
have flown past that mark with no problem, although the sample size is
still
small since the fleet is still young.
Thanks,
-Mike
"Dude" wrote in message
Are you a COPA member Peter?
I was forwarded some rather ugly COPA posts (I think its funny that all
bad news is in the "members only" section as if it won't get out, and
then
you let anyone buy a membership). The root of the problem is suspected
to
be that pilots are killing the throttle to descend. They give the
reason
for having to kill the throttle as not having the option to reduce power
sufficiently because of the limited settings available to them.
I am not trying to claim that anyone has been advertising the Cirrus
prop
controls as FADEC or even FADEC like. However, they have commented on
how
"simple" the operation of this system is for the pilot. The unintended
consequence of this system is that the pilots are not able to let the
engine
and prop combo run in its sweet spot, and vertical planning becomes more
problematic.
Of course, no one forwards me notes from happy Cirrus customers. If
your
level of positive thinking and optimism is bothered by the subject, you
should not log on. Even I quit watching the local news, and I suggest
you
do the same.
I reduce throttle in my plane, and I can increase rpm. The
combination
will
slow my plane
Reducing throttle in a Cirrus slows the plane down too.
without over cooling the engine. I DO NOT want to get into an
argument about shock cooling.
Then stop making statements that rely on the assumption that shock
cooling
exists.
Whether shock cooling occurs or not does not
change the fact that many pilots fly in ways to avoid it.
So what? First of all, your assumption that high RPM, low throttle
power
settings avoid shock cooling is simply wrong. If there is such a
thing
as
shock cooling, then reducing power will cause shock cooling,
regardless
of
what mix of RPM and MP you use. Additionally, at low throttle, high
RPM
settings, the engine is windmilling, being driven by the airflow
through
prop, and is considered by many to be at least as damaging to an
engine
as
shock cooling, if not more so.
Secondly, the fact that "many pilots" fly in a way to try to avoid
something
that does not happen isn't relevant to any rational discussion. Why
would
an aircraft designer install speed brakes just to address some
psychological
need for a pilot to use them, even if there is no practical advantage
to
doing so?
In other words, if you want to play the "avoid shock cooling card",
you'd
better darn well be prepared to argue that "shock cooling" is real.
The Cirrus does
not allow full control over prop and throttle (aka phony fadec)
It's not a FADEC. It's not advertised as a FADEC. It cannot possibly
be
a
"phony fadec [sic]", since no one's called it a FADEC in the first
place.
Well, the ones that have engines dying at 700 hours are a lot
frigging
louder than the ones that think it works just fine.
I haven't seen any evidence to even buttress that statement. But even
if
it's true, how's that anything other than basic human nature? Why
would
someone for whom everything's going fine invest a huge effort
complaining
about that? Who do you expect to hear from, if not from the few folks
who
have had engine problems?
Pete
  #147
Old April 28th 04, 05:11 PM
Vaughn Simon
"Bill Denton" wrote in message
thread...
recovery from the spin. snip...And until that type of
accident record...
And to come back to a point I made earlier in the thread, the result of
pulling the BRS *is* an accident. You will end up with bent metal and
possibly injuries every time you deploy the rescue system, and this reality
will be reflected in the Cirrus's insurance rates. Hopefully, the Cirrus
will some day have a low fatality rate, but I doubt if it will ever be known
for a low accident rate.
Vaughn
  #148
Old April 28th 04, 05:20 PM
Richard Kaplan
"Aaron Coolidge" wrote in message
I would say that the two airplanes are very comparable in terms of power,
speed, range, price, payload flexability, etc.
A huge difference is that the Mooney can be equipped to be known-ice
certified.
For anyone spending $300K on a serious IFR airplane, it is hard for me to
imagine how/why this is not a dealbreaker for Cirrus.
Richard Kaplan, CFII
www.flyimc.com
  #149
Old April 28th 04, 10:47 PM
Dave Stadt
thread...
BRS.
absolutely
accident record...
Can you imagine what a pilot that flies a Cirrus and other planes would do
in a crisis situation. Two totally different emergency procedures would vie
for top priority. Scary.
  #150
Old May 5th 04, 04:28 AM
Greg
"Dude" person,
I have really been reluctant to add a post to this thread because I
don't think I have seen so much misinformation in my life, but I feel
an obligation to correct patently false statements which I can refute
from a position of knowledge. I have been flying an SR22 for 2 1/2
years and have been a COPA member for 3 years.
You said that there are problems with the engines needing work at 700
hours. This is absolutely false. If this were happening, it would be
all over the COPA forums and I read them almost everyday. I have not
read the first report of an engine needing major work at 700 hours and
your statement about the interconnection between the prop and throttle
being problematic to the engine is so ridiculous as to be humorous. I
also have a very good relationship with my Service Center and we have
had a lot of conversations about various Cirrus issues, major engine
work at 700 hours has never been mentioned. And shock cooling
problems??!! Huh? I have never had this problem even once.
As far as slowing the plane down, I have never had a problem with THAT
either. I have had to start slowing down a little sooner BECAUSE I
WAS GOING FASTER TO START WITH! I have flown an ILS down to the
middle marker at 120kts (faster than the cruise speed of a 172) and
dropped flaps to land in the normal touchdown zone. It's just not a
problem and I have never wished I had speed brakes. By the way, THAT
is the correct way to spell "speed brakes".
And ANOTHER thing, if anybody thinks they are going to recover from an
inadvertent spin in less than 1,000' in any common four place or six
place airplane without hitting terra firma first, they are living a
fantasy. You just might barely make it if you are well practiced in
spins in the aircraft you are flying and perform spins on a regular
basis and you are at a very light weight. However, it will not happen
like that. It will happen unexpectedly, probably when you are heavy
with an aft CG, while you are doing something else like changing to
departure control frequency. You look up from the radio to see the
world spinning. You have less than five seconds to figure out what
happened and determine the correct control inputs. You must execute
them perfectly, or you die. Depending on the plane, loading, and
pilot proficiency in spin recovery, I would not expect many scenarios
like this to end favorably with less than 2,000' for an average pilot.
Geez, this thread has the worst signal to noise ratio I have seen in a
long time. You know, it started out with just some guy asking for a
little information, I don't think he wanted an earful of crap from
someone with an agenda. Until you fly a Cirrus for more than a
demonstration flight, you would do well to stick to verifiable facts.
Greg
"Dude" wrote in message ...
"Thomas Borchert" wrote in message
Dude,
This could reduce the stalls, at least on approach.
Oh? So how many have stalled on approach again? Right, none.
Yet.
Don't get so frigging defensive. My point is that the Cirrus can be hard to
slow to approach speed. It takes more care than many other planes because
it is slick, and you cannot control the pitch of the prop to add drag. If
you had speed breaks you would allow the pilot more options to control
descent given that right now the system that governs the RPM/MP has limited
ability to slow the plane without cutting the throttle.
Bottom line is that if a person has speed breaks, he is less likely to fly
slow because he can shed speed whenever needed.
It would also reduce
the severe shock cooling they are seeing due to their engine control
system.
So you can prove damage through shock cooling? Wow! I know no one else who
can. And where is the connection to the "engine control system"?
Presently, according to some COPA members, there are many people having
excessive engine wear and needing lots of cylinder work early. One
suspected reason is shock cooling due to pilots cutting throttle to get the
plane down without gaining too much speed. The cirrus design simply adds
more penalty to poor vertical planning than most planes, and so the engine
is often asked to pay the price.
Another theory is that the engines are constanlty being run at set rpm's
that may not be the best rpm's or the smoothest. The pilot cannot control
it.
Bottom line, the phony Fadec system isn't really all that good.
Thomas Borchert (EDDH)
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
New Cirrus SR22 Lead Time Lenny Sawyer Owning 4 March 6th 04 09:22 AM
Fractional Ownership - Cirrus SR22 Rich Raine Owning 3 December 24th 03 05:36 AM
New Cessna panel C J Campbell Owning 48 October 24th 03 04:43 PM
