Diamond DA-40
Old April 29th 04, 10:09 PM
Aaron Coolidge
TTA Cherokee Driver wrote:
: Aaron Coolidge wrote:
: Do check the range, as the fuel tanks seem to be rather small.
: All the better to improve the full-fuel payload number! (ducking)
I think that's the reason they limited it to 41 gal. At the claimed 145 knots,
you can go 435 nm with a 1-hour reserve. In my Cherokee 180, at 118 knots,
you can go 4 hours or 472 nm with a 1-hour reserve. Granted, it takes one
more hour in the Cherokee. If the Diamond had 80 gal of fuel capacity, or
even 60 gal, it would really be something nice.
Aaron Coolidge (N9376J)
Old April 30th 04, 04:11 AM
Dude
Uh, no.
If you want to compare it to your cherokee, then you can use the Diamond at
the same speed. At 118 you will only use about 6.5 gph in the Diamond.
That gives you the same 472 NM on only 26 gallons.
OR
You can go 5 hours for 608nm with a 1 hour reserve.
Slicker plane wins.
Still need bigger tanks? The Diamond has an option for an extra 10 gallons.
If you want to make a case for how great the older technology is, you better
go for a bigger engine plane and claim a high tolerance for fuel bills. You
are going to be hard pressed to beat the Diamond without going up to 200 hp.
Mooney's can win, but they are retracts, Tigers are the closest thing, but
they will lose slightly. Diamond has them both whipped pretty hard on
safety.
In my book, its all about how far you can get with 3 hour legs and still
have adequate reserves. I don't want to sit that long, and I would just as
soon not go that much longer anyway. So I don't need bigger tanks.
I know some of you like to fly 5 hour legs, but my butt and bladder aren't
rated for that long.
"Aaron Coolidge" wrote in message
knots,
Old April 30th 04, 04:21 AM
Aaron Coolidge
Dude wrote:
: Still need bigger tanks? The Diamond has an option for an extra 10 gallons.
I didn't realize this.
: If you want to make a case for how great the older technology is, you better
I wasn't doing this. I was merely stating that the Diamond only carries 41
gal of fuel, when having more fuel vs. payload tradeoffs can be useful. See
also the above.
I have no problem flying 4, 5, 6, or even 8 hour legs, when I am flying
alone on a trip. I will probably get a Mooney 231/252 with extended range
tanks for my next airplane.
PS, I can't fit in the DA40, anyway, as my knees hit the bottom of the
instrument panel. Too bad, because they're nice flying airplanes.
Aaron Coolidge
Old April 30th 04, 12:15 PM
Dylan Smith
In article , Chuck wrote:
Hi, all,
Does anyone have any experience with the Daimond DA-40-180? We saw one
at Sun 'n Fun and we're thinking of buying it.
Only had a short flight in it (I flew both as PIC and as a back seat
passenger) in a 2001 model.
I found it to be better performing in all respects compared to a 200-hp
Piper Arrow. The visibility from the left seat was great. Being able to
get in the back door as a rear seat passenger was helpful. It flies very
nicely. Pity I can't afford one!
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
Old April 30th 04, 04:35 PM
Gil Brice
Why is this?
Lastly, if you are the type whose head is not always 100% in the cockpit -
buy the Diamond!
Old April 30th 04, 05:45 PM
RevDMV
In my personal search for a best new plane I've done demo flights in
all the new single engine aircraft available.
The DA-40 was hands down the most fun to fly. It made a fairly low
time pilot like me look good, it didn't seem to have any bad habbits.
Great visibility, good performance and nice looking.
I flew an early version which had some issues that have been addressed
and some the havn't in the latest upgrades.
Those that have include the new extended bagage area. The original
just didn't have any space at all. With little kids it had the useful
load, but I would need more room for all the kid supplies.
Another upgrade is the panel which has been moved up to give more leg
room. It was a little tight and I'm a normal sized guy.
One that won't ever change is the non-adjustable seats. One size never
fits all, and although I found the seating position to be ok, I know
that somewhere some time I would ant to move it and would hate that I
couldn't. The rudder pedal adjust instead. Granted this is a YMMV kind
of issue.
The control stick is great for a pilot, but with a non-flying
signifigant other could be an issue.
Someone already linked Phillip Greenspun's web site. Its a good read
and I think will give some honest info on long term ownership. One
thing I noticed from reading it was teh problem with the MT prop
spewing grease. I don't think he's had a complet resolution to the
problem and I believe that smoehwere he notes that this is an issue he
has seen on the DA40 pilots forum as well. It would seem that Diamond
has opted to use a new prop in the latest version.
All in all a good plane.
Old April 30th 04, 08:57 PM
Dude
The stall performance is nothing short of amazing. The plane is even more
forgiving than a 172. The Cirrus on the other hand can roll over pretty
easy, and the stall performance is the subject of many heated discussions.
Bottom line, there are less fatalaties in the Diamonds. There were some
recent discussions on reading too much into statistics, but if you talk to
the Diamond owners or reps, you hear some very reassuring stuff.
My prejudice is that if you are a really serious pilot (you enjoy the
minutiae of every bit of flight planning, engine management, constant
navigational checks while flying, fly IFR all the time, etc...), then you
are likely to be able to judge well your risk in any given plane. You also
likely fly enough to stay really cuurent and on top of things.
On the other hand, if you are more relaxed like the average pilot ( you do a
basic weather check, electronic flight plan if any, lean your engine "close
enough", start enjoying the view or thinking about business, fly IFR only
when necessary, etc.) then you would do best to buy with an eye more towards
safety. You are likely flying under 70 hours a year, and staying in top
shape with your skills is a constant exercise in relearning things you
already knew before.
Just from the posts you read on this group, you would hop in a clipped wing
experimental with some of these guys. On the other hand, I wouldn't buy one
for myself. Different planes for different folks.
"Gil Brice" wrote in message
m...
Why is this?
cockpit -
buy the Diamond!
Question, Diamond distance as unsuccessful triangle. Roger Aviation Marketplace 1 November 22nd 04 07:34 PM
Cessna 182T w. G-1000 pirep C J Campbell Instrument Flight Rules 63 July 22nd 04 07:06 PM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Jabiru and Rotax engines Marco Rispoli Home Built 14 July 16th 04 07:23 AM
Diamond/Thielert news Thomas Borchert Owning 2 September 14th 03 09:33 AM
