I posted this question in the "Fuel dip tube for Piper Warrior?" thread, but
it seems to have gotten lost. Does anyone have dip tube data for the straight-wing PA-28's, or are the fuel tanks the same as the taper-wing versions? Thanks. -- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney to love America |
![]() "Bob Chilcoat" wrote in message ... I posted this question in the "Fuel dip tube for Piper Warrior?" thread, but it seems to have gotten lost. Does anyone have dip tube data for the straight-wing PA-28's, or are the fuel tanks the same as the taper-wing versions? Thanks. Pasted from the original thread: Here's the data I used to make my dipstick (wood paint stirring stick) for 24 gallon tanks: 4= 0" 5= 1" 10= 2 1/4" 15= 4" 20= 5 3/4" 24= 7 1/4" I use a smooth wooden dowel abut 1/4" diameter and fitted a soft elastic tube over the the end to stop any chance of damaging the tank. The top has a small string loop to ensure it's not dropped into the tank (one of our group had the pleasure of removing and refitting a tank after dropping a calibrated tube inside!). Calibration is with a fine 'permanent' marker pen. Occasionally it needs re-marking but works well. Both tanks were calibrated by adding fuel, in increments, to our PA28-161, Warrior II. There was a slight discrepancy between tanks but not sufficient to cause any serious errors. It's nice to see some similarity with the poster above. I use the following which is from fuel added, measured then interpolated from calibration in litres. It is not on a linear scale. Dipped with stick approx. in middle of filler hole and on level ground: Inches USG ============ 8.0 24.7 7.0 23.5 6.0 21.8 5.0 19.4 TAB 17.5 4.0 16.6 3.0 13.3 2.0 9.3 1.0 6.3 0.0 4.3 |
Thanks, but I'd already seen that. My concern was that the tanks on
straight-wing Cherokees might have a different x-section. Cory Pappenfuss replied on the other thread that the tanks are probably the same. I will ask our A&P if the tanks use the same part number. That would clinch it. -- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney to love America "John Kunkel" wrote in message news:Yidlc.11722$Ia6.1527811@attbi_s03... "Bob Chilcoat" wrote in message ... I posted this question in the "Fuel dip tube for Piper Warrior?" thread, but it seems to have gotten lost. Does anyone have dip tube data for the straight-wing PA-28's, or are the fuel tanks the same as the taper-wing versions? Thanks. Pasted from the original thread: Here's the data I used to make my dipstick (wood paint stirring stick) for 24 gallon tanks: 4= 0" 5= 1" 10= 2 1/4" 15= 4" 20= 5 3/4" 24= 7 1/4" I use a smooth wooden dowel abut 1/4" diameter and fitted a soft elastic tube over the the end to stop any chance of damaging the tank. The top has a small string loop to ensure it's not dropped into the tank (one of our group had the pleasure of removing and refitting a tank after dropping a calibrated tube inside!). Calibration is with a fine 'permanent' marker pen. Occasionally it needs re-marking but works well. Both tanks were calibrated by adding fuel, in increments, to our PA28-161, Warrior II. There was a slight discrepancy between tanks but not sufficient to cause any serious errors. It's nice to see some similarity with the poster above. I use the following which is from fuel added, measured then interpolated from calibration in litres. It is not on a linear scale. Dipped with stick approx. in middle of filler hole and on level ground: Inches USG ============ 8.0 24.7 7.0 23.5 6.0 21.8 5.0 19.4 TAB 17.5 4.0 16.6 3.0 13.3 2.0 9.3 1.0 6.3 0.0 4.3 |
![]() My parts catalog only covers the straight wings up to 1973. The models of PA-28-140, 160, 180, 235 and PA-28R-180, 200 all use the same part numbers for their fuel tanks. P/N 63998-16 for the left and 63998-17 for the right. Sandy Mustard Bob Chilcoat wrote: Thanks, but I'd already seen that. My concern was that the tanks on straight-wing Cherokees might have a different x-section. Cory Pappenfuss replied on the other thread that the tanks are probably the same. I will ask our A&P if the tanks use the same part number. That would clinch it. |
fuel tank plumbing | pwm | Home Built | 18 | January 27th 05 04:54 AM |
Fuel dip tube for Piper Warrior? | TTA Cherokee Driver | Owning | 16 | May 3rd 04 05:42 PM |
Canard planes swept wing outer VG's? | Paul Lee | Home Built | 8 | January 4th 04 08:10 PM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Hot weather and autogas? | Rich S. | Home Built | 33 | July 30th 03 11:25 PM |
