my manifold pressure gauge is being really slow to respond - was just
wondering if there is something I should look at before just replacing it. we blew out the lines at the last inspection and also checked the lines for any leaks. Has the guage just gone bad ? also - would it be better to send it in for service or just replace it ? Steve |
Steve,
is the engine running normally? You may have a cracked line. There may be moisture in the line as well. Michelle Steve wrote: my manifold pressure gauge is being really slow to respond - was just wondering if there is something I should look at before just replacing it. we blew out the lines at the last inspection and also checked the lines for any leaks. Has the guage just gone bad ? also - would it be better to send it in for service or just replace it ? Steve -- Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P "Elisabeth" a Maule M-7-235B (no two are alike) Volunteer Pilot, Angel Flight Mid-Atlantic Volunteer Builder, Habitat for Humanity |
On Sun, 16 May 2004 19:25:34 GMT, "Steve" wrote:
my manifold pressure gauge is being really slow to respond - was just wondering if there is something I should look at before just replacing it. we blew out the lines at the last inspection and also checked the lines for any leaks. Has the guage just gone bad ? also - would it be better to send it in for service or just replace it ? Steve On a lot of 'em, removing the inlet fitting will expose an adjustment screw. This screw is turned in and out to vary the damping effect of the adjustable orifice. The screw can be carefully removed (counting the number of turns) and the crud cleaned off/out of it. TC |
| Thread Tools | |
| Display Modes | |
| Deployments Slow Fire Training For Military Pilots | Otis Willie | Military Aviation | 0 | July 8th 04 01:19 AM |
| Deployments Slow Fire Training For Military Pilots | Otis Willie | Naval Aviation | 0 | July 8th 04 01:19 AM |
| Why were the George and Jack so slow? | old hoodoo | Military Aviation | 3 | December 10th 03 03:01 AM |
| Posting problem-plese Respond | Nele_VII | Military Aviation | 2 | December 7th 03 07:26 AM |
| Refurbishing indicator guage faceplates | Merle Wagner | Home Built | 2 | August 20th 03 06:18 AM |
