In article
, Orval Fairbairn wrote: This past Monday, a couple of my friends took off in a Bonanza with a 3-blade McCauley prop installed. At about 1000 feet, on power reduction, one of the blades came unhooked from its pitch change mechanism and went into "free pitch" mode. It apparently made a lot of racket and bad vibrations right away; they were able to make a 180 and land downwind safely. They even had a hard time taxiing, but all are safe. Both McCauley and the FAA are really interested in this one -- to make sure that proper overhaul procedures were followed and to ascertain whether or not bogus parts were used. The insurance company is paying for the engine teardown/rebuild, as there is a possibility that the front bearing was damaged, due to asymmetric thrust. The fortunate thing is that it happened at 1000 feet, after takeoff from a 4800 ft runway, lightly loaded. Watch this space for possible AD and other stuff hitting the fan. Followup: I talked to the owner of the plane today -- he was present when they opened up the prop hub. The pin at the base of the blade had sheared off. This is about 1/2" diameter and keeps the blade synchronized with the other blades. The pin went off for metallurgical analysis -- it was either too brittle or had improper heat treatment done, so there may be no joy in Mudville after this one is done. I wonder how many accidents have happened where the pin had broken and was dismissed as accident damage, rather than accident cause. |
Why do I smell an expensive AD coming?
-- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney (Or Kerry, for that matter) to love America "Orval Fairbairn" wrote in message news ![]() In article , Orval Fairbairn wrote: This past Monday, a couple of my friends took off in a Bonanza with a 3-blade McCauley prop installed. At about 1000 feet, on power reduction, one of the blades came unhooked from its pitch change mechanism and went into "free pitch" mode. It apparently made a lot of racket and bad vibrations right away; they were able to make a 180 and land downwind safely. They even had a hard time taxiing, but all are safe. Both McCauley and the FAA are really interested in this one -- to make sure that proper overhaul procedures were followed and to ascertain whether or not bogus parts were used. The insurance company is paying for the engine teardown/rebuild, as there is a possibility that the front bearing was damaged, due to asymmetric thrust. The fortunate thing is that it happened at 1000 feet, after takeoff from a 4800 ft runway, lightly loaded. Watch this space for possible AD and other stuff hitting the fan. Followup: I talked to the owner of the plane today -- he was present when they opened up the prop hub. The pin at the base of the blade had sheared off. This is about 1/2" diameter and keeps the blade synchronized with the other blades. The pin went off for metallurgical analysis -- it was either too brittle or had improper heat treatment done, so there may be no joy in Mudville after this one is done. I wonder how many accidents have happened where the pin had broken and was dismissed as accident damage, rather than accident cause. |
Orval Fairbairn wrote in message .. .
This past Monday, a couple of my friends took off in a Bonanza with a 3-blade McCauley prop installed. At about 1000 feet, on power reduction, one of the blades came unhooked from its pitch change mechanism and went into "free pitch" mode. There is a composite material link between the pitch change mechanism and the blade acutator pin, which is on the circumference of the blade shank. It's about 2" long. This is a reason that McCauley specifically warns against pulling the airplane with the prop while on the ground. If you pull on the back edge of the blade, you can put enough torque on it to threaten the links. Ond does wonder how they were cared for because this is a very rare failure. It would be like a terrible mistrack on a helicopter rotor. Bill Hale BPPP Instructor |
McCauley prop blages | Cy Galley | Aviation Marketplace | 0 | January 25th 04 09:24 PM |
gpa a factor after graduation? | sibersmith | Military Aviation | 28 | November 26th 03 05:06 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Shortened McCauley Propeller on an O-300 | Larry Smith | Home Built | 12 | September 10th 03 01:40 AM |
