Can an AP/IA person legally install and sign off a VFR Nav/Comm radio
in a certified aircraft, given that he has all the needed technical knowledge needed to do this, or is a 'certified radio shop' required somewhere in the paperwork process? How about an IFR installation? (not counting the transponder/encoder and altimeter cert. requrements) |
"xeM" wrote in message ... Can an AP/IA person legally install and sign off a VFR Nav/Comm radio in a certified aircraft, given that he has all the needed technical knowledge needed to do this, or is a 'certified radio shop' required somewhere in the paperwork process? A&P/IA is all you need. How about an IFR installation? An IFR GPS requires a radio shop. |
On Thu, 20 May 2004 16:50:43 -0600, "Newps"
wrote: "xeM" wrote in message .. . Can an AP/IA person legally install and sign off a VFR Nav/Comm radio in a certified aircraft, given that he has all the needed technical knowledge needed to do this, or is a 'certified radio shop' required somewhere in the paperwork process? A&P/IA is all you need. How about an IFR installation? An IFR GPS requires a radio shop. Would the new AC 20-138a change that requirement now? See http://www.aea.net/aeatodayDetail.asp?ID=256 |
Gene Kearns wrote:
:Would the new AC 20-138a change that requirement now? See :http://www.aea.net/aeatodayDetail.asp?ID=256 : : My understanding is.... it would.... as long as the installation was : not interfaced with another unit.... : Since GPS is no longer consider a "new technology" it's installation : is equivalent to old tech, like a radio... ..... unless you are under the jurisdiction of at least the Richmond FSDO. I'm working with my A&P/IA on installing a KLX-135 VFR GPS/COMM and the guy at the FSDO insists that it's still a major alteration. Funny thing is that apparently, the act of installing a placard saying "VFR use only" enters a whole new set of regulations (think field approval along with major alteration) than utilizing the on-screen message that reads "VFR use only." I don't understand it, but am rapidly concluding that rational thought has nothing to do with it. -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
[rant on]
What in the hell is WRONG with you people? How in the hell did a FSDO get involved with a logbook installation? I'll tell you how it happened. Either the owner or the IA was stupid enough to ask the FSDO their opinion. After that, you are in the paperwork mill, and woe betide you. You will never exit the other end unscathed. Just SHUT YOUR MOUTH, do a LOGBOOK ENTRY, and both you and the Feds are going to be mightily happy. [rant off] Jim shared these priceless pearls of wisdom: -.... unless you are under the jurisdiction of at least the Richmond FSDO. I'm working -with my A&P/IA on installing a KLX-135 VFR GPS/COMM and the guy at the FSDO insists -that it's still a major alteration. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
"Gene Kearns" wrote in message ... The best way to find out about the rationality of it all is to have the ASI to (1) show you in the regs where it says it is a major alteration and (2) explain to you what the purpose of AC 20-138A is and what it means. Oh no. Never ask an FAA person to explain the regs -- you most definitely won't like the answer. Do your own homework. In all my dealings with certifications, one thing is very clear: It is not the inspector's or ACO's job to tell you how to comply with the regulations. Their job is to determine whether you have presented proper evidence to show compliance. It is your job to show that you are complying with the regs. The only break you get is the AC. It describes "a means, but not the only means of showing compliance..." Read it. Understand it. Follow it. Document everything the way it says to. If you follow it, and submit the documentation to prove you did, they won't argue with you. There may be other ways to show compliance; but if you try them, you're on your own. The AC is the path of least resistance. Gerry |
On Fri, 21 May 2004 14:41:44 -0700, Jim Weir wrote:
[rant on] What in the hell is WRONG with you people? How in the hell did a FSDO get involved with a logbook installation? I'll tell you how it happened. Either the owner or the IA was stupid enough to ask the FSDO their opinion. After that, you are in the paperwork mill, and woe betide you. You will never exit the other end unscathed. Just SHUT YOUR MOUTH, do a LOGBOOK ENTRY, and both you and the Feds are going to be mightily happy. [rant off] Jim I agree Jim, The way I read AC-20-138a is: 1. Read and understand AC-20-138a 2. Install / Test GPS per AC-20-138a 3. Logbook signoff per minor mod. 4. FSDO dosen't need to be involved. |
*sigh*.... that would be my preferred course of action. Most of the IA's I've
talked with believe, "If in doubt, send it in and see what the FAA says about it." I suspect it's instilled fear to CYA. Nobody ever said the rules make sense. I find it tragically comic how arbitrary and capricious the rules are written and enforced. -Cory Jim Weir wrote: : [rant on] : What in the hell is WRONG with you people? How in the hell did a FSDO get : involved with a logbook installation? : I'll tell you how it happened. Either the owner or the IA was stupid enough to : ask the FSDO their opinion. After that, you are in the paperwork mill, and woe : betide you. You will never exit the other end unscathed. : Just SHUT YOUR MOUTH, do a LOGBOOK ENTRY, and both you and the Feds are going to : be mightily happy. : [rant off] : Jim : : shared these priceless pearls of wisdom: : -.... unless you are under the jurisdiction of at least the Richmond FSDO. I'm : working : -with my A&P/IA on installing a KLX-135 VFR GPS/COMM and the guy at the FSDO : insists : -that it's still a major alteration. : Jim Weir (A&P/IA, CFI, & other good alphabet soup) : VP Eng RST Pres. Cyberchapter EAA Tech. Counselor : http://www.rst-engr.com -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
Jim Weir wrote:
What in the hell is WRONG with you people? How in the hell did a FSDO get involved with a logbook installation? I'll tell you how it happened. Either the owner or the IA was stupid enough to ask the FSDO their opinion. After that, you are in the paperwork mill, and woe betide you. You will never exit the other end unscathed. Just SHUT YOUR MOUTH, do a LOGBOOK ENTRY, and both you and the Feds are going to be mightily happy. Jim, Obviously, if it was an IFR installation, he'd have to get a field approval, because it's specifically required. However, from what I've heard from a close friend, who owns an avionics shop, the FAA has dictated that all FSDOs require a field approval for ALL GPS installations, IFR or VFR. It's bull ****, but apparently, that's what they want. Don't ask me why. --- Jay (in Baltimore and/or Washington FSDO, depending on where I am) -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
Jay Masino wrote: However, from what I've heard from a close friend, who owns an avionics shop, the FAA has dictated that all FSDOs require a field approval for ALL GPS installations, IFR or VFR. The Teterboro FSDO is the same way. Not sure about Allentown. George Patterson I childproofed my house, but they *still* get in. |
| Thread Tools | |
| Display Modes | |
| General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Home Built | 3 | May 14th 04 12:55 PM |
| General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Aerobatics | 0 | May 11th 04 11:43 PM |
| General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Owning | 0 | May 11th 04 11:43 PM |
| General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Owning | 0 | May 11th 04 11:36 PM |
| Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 04:30 AM |
