The fellow who did my annual asked me to order a jack screw because he can
see a little wiggle between the screw and the cable drum. He wasn't sure which part was worn, but suggested we start by replacing the screw and then also replace the drum if the problem persists. I would like to survey the experiece of the group before ordering the jack screw. Is the screw more likely to wear than the cable drum, or do they both tend to add equally to a loose fit? -- Regards, Mike http://mywebpage.netscape.com/amountainaero/fspic1.html |
In article , "Mike Noel"
wrote: The fellow who did my annual asked me to order a jack screw because he can see a little wiggle between the screw and the cable drum. He wasn't sure which part was worn, but suggested we start by replacing the screw and then also replace the drum if the problem persists. I would like to survey the experiece of the group before ordering the jack screw. Is the screw more likely to wear than the cable drum, or do they both tend to add equally to a loose fit? the screw is steel. The bushing is a softer metal. Guess which one is worn. -- Bob Noel |
![]() Mike Noel wrote: The fellow who did my annual asked me to order a jack screw because he can see a little wiggle between the screw and the cable drum. He wasn't sure which part was worn, but suggested we start by replacing the screw and then also replace the drum if the problem persists. I would do one of two things. If I could tolerate the down time, I would take the assembly apart, find out what's wrong, order the correct part, and reassemble the unit when the part arrives. If I could not wait that long, I would order both parts. When the parts came in, I would disassemble the unit, replace whatever is worn, and try to get a refund on the unused piece (or sell it). Sounds like this guy wants to get paid for taking the thing apart twice. George Patterson None of us is as dumb as all of us. |
Mike Noel wrote:
: The fellow who did my annual asked me to order a jack screw because he can : see a little wiggle between the screw and the cable drum. He wasn't sure : which part was worn, but suggested we start by replacing the screw and then : also replace the drum if the problem persists. : I would like to survey the experiece of the group before ordering the jack : screw. Is the screw more likely to wear than the cable drum, or do they : both tend to add equally to a loose fit? Be very sure that the 'wiggle' is between the jack screw & trim drum. It's usually between the trim drum and the supporting plates because the bushings in the supporting plates are worn. PS, when mine wore out after 5700 hours it was the trim drum. The new trim drums don't look like the old trim drums, but they work the same. Oh, and some mechanics don't seem to be able to follow the procedure for properly winding the trim drum. Check the trim from full nose-up to full nose-down after it's replaced. My guy wound one too few turns on the drum, and the cable came off and jammed the trim full nose down (during my post- maintenance checks). -- Aaron Coolidge (N9376J) |
Mike Noel wrote:
I would like to survey the experiece of the group before ordering the jack screw. Is the screw more likely to wear than the cable drum, or do they both tend to add equally to a loose fit? I just did mine at the last annual. Mine had been wiggling for a while, and my mechanic felt it had gotten too severe. I can't honestly remember which parts had the most wear. I think everything had some. We basically replaced everything, because my mechanic happened to have everthing in stock. We even had to replace one of the steel plates that the bushing is pressed into. It's a good feeling to know everything's perfect, now. --- Jay (67 Cherokee) -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
Last week while changing the oil (owner maintenance) we took the upper tail
cone off to examine ours more carefully, since I had noticed some significant looseness during preflight a few weeks ago. It had not been changed at annual a couple of months ago, but now has major play. Once we had the tailcone open, we could see that the jackscrew moves at least an eighth of an inch fore and aft, changing its angle relative to the tail by several degrees. On addition, you can move the screw laterally inside the drum almost half of the thread depth. When we saw that it was not just a bit of axial play, we decided to change it ASAP. We were a bit cross that it wasn't caught at annual, but the A&P said that if they had seen that much play, they would have replaced it. He speculated that it might have been in a "tight" point in its travel when they checked it. I'm not convinced, but it's not worth arguing about. We might try and get some relief on the labor to put it in. I understand that the replacement comes as a kit with drum, screw, and new cables. If they had done it at the annual, the floor would already have been up. We haven't had a price yet, but I don't expect it to be cheap. -- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney (Or Kerry, for that matter) to love America "Jay Masino" wrote in message ... Mike Noel wrote: I would like to survey the experiece of the group before ordering the jack screw. Is the screw more likely to wear than the cable drum, or do they both tend to add equally to a loose fit? I just did mine at the last annual. Mine had been wiggling for a while, and my mechanic felt it had gotten too severe. I can't honestly remember which parts had the most wear. I think everything had some. We basically replaced everything, because my mechanic happened to have everthing in stock. We even had to replace one of the steel plates that the bushing is pressed into. It's a good feeling to know everything's perfect, now. --- Jay (67 Cherokee) -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
Mike Noel wrote:
The fellow who did my annual asked me to order a jack screw because he can see a little wiggle between the screw and the cable drum. He wasn't sure which part was worn, but suggested we start by replacing the screw and then also replace the drum if the problem persists. I would like to survey the experiece of the group before ordering the jack screw. Is the screw more likely to wear than the cable drum, or do they both tend to add equally to a loose fit? I just went through this with my PA22/20. There are flat washers (used as thrust washers) above and below the block though which the jackscrew shaft runs. We were able to get the play out by the replacing worn washers... Google Groups it! MikeM Pacer '00Z Skylane '1MM |
On Tue, 1 Jun 2004 09:46:14 -0400, "Bob Chilcoat"
wrote: snip play, they would have replaced it. He speculated that it might have been in a "tight" point in its travel when they checked it. I'm not convinced, but it's not worth arguing about. We might try and get some relief on the labor to put it in. I understand that the replacement comes as a kit with drum, screw, and new cables. If they had done it at the annual, the floor would already have been up. We haven't had a price yet, but I don't expect it to be cheap. How does "missing" it during annual translate into a discount for repair? Taking the tailcone off to access it for inspection or repair takes about 5 minutes. Popping the rear seats and yanking the "floor" could also be accomplished in about 5 minutes, but there is no reason to remove it to change out the trim drum or screw. Have never heard of a "kit" to replace a trim drum, doesn't mean it doesn't exist, tho. The oilite bushings that the drum rotates in/on are cheap, with the drum out, I'd change 'em. Unless the cable is frayed, I'd leave it. Very seldom is the steel screw worn, but it is quite common for the aluminum drum to be worn both internally and where the aforementioned bushings ride. It takes about ten minutes to yank the screw and try it in a new drum. Somebody that knows how to do it could swap out the drum and the upper and lower bushings in about two hours. As others have pointed out, somebody that doesn't know to do it is likely to screw it up. TC |
Screw hold repair in fabric? | Brian Huffaker | Home Built | 11 | May 29th 04 02:07 AM |
How much play in Archer Trim Jackscrew? | Bob Chilcoat | Owning | 1 | April 20th 04 12:42 AM |
1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 10:57 PM |
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore | Otis Willie | Military Aviation | 2 | February 22nd 04 03:33 AM |
Bothersome Phillips Head Screws | Larry Smith | Home Built | 48 | January 10th 04 04:26 AM |
