My Hertzile (?sp?) has almost 900 since its been torn down. I've heard
different things from different mechanics. I know the actual TBO on the prop is now something like 20,000 hours. However, I don't want to get stuck somewhere with a problem. How much time do most people here put on their props? BTW: I think the last overhaul was about 10 years ago. -Robert |
Robert M. Gary wrote:
My Hertzile (?sp?) has almost 900 since its been torn down. I've heard different things from different mechanics. I know the actual TBO on the prop is now something like 20,000 hours. However, I don't want to get stuck somewhere with a problem. How much time do most people here put on their props? BTW: I think the last overhaul was about 10 years ago. -Robert I'll echo Ron's response, and add the following. Our two-blade blade Hartzell CS prop TBO is 2000 hours or 5 years. That's pretty typical for props of this type. It is highly unlikely any prop would have a 20000 hr TBO. That sounds more like a life limit to me. Lower calendar TBOs are specified if the airplane is kept outside. Call the manufacturer or a good overhaul shop for more information. When we decided to overhaul our prop at our last annual, it had a bit under 1000 hours and 24 years (!) since OH. However, cosmetically, it was in remarkably good shape because the airplane had been hangared for over half that time. Cost us $1800 from Sensenich Propeller Services including shipping (our mechanic's airport is only about 50 miles away from their facility in Lancaster, PA, so they came out in their own truck). Incidentally, we also decided to have the propeller governor overhauled at the same time. The flyweight assembly was found to be out of tolerance and superceeded by a newer part. The governor OH cost $950 with the new assembly. Not sure whether it's because of the governor or the prop work, but the prop cycles a bit faster now. You can see the finished work on my site. Click through: Aviation-Articles-Maintenance-Annual 2003 -Doug -- -------------------- Doug Vetter, CFIMEIA http://www.dvcfi.com -------------------- |
Although 900 hours is less than the time in service for most of their
models, ten years is well in excess of the recommended time for most, which seems to be either five years or six years depending on various factors (at least for a hub inspection, and probably for the blades, too). I've heard the same thing - if your blades are OK, you may still want to have the hub re-sealed after more than ten years, that will prevent corrosion, etc. Its not terribly expensive to do that vs. full blown overhaul ($1000) and it takes care of the moving parts. If you do overhaul, shop carefuly, the Aviation Consumer had an article on this while back. Some shops are quite enthusiastic about rejecting perfectly good blades, apparently. |
Doug Vetter wrote in message et...
Robert M. Gary wrote: My Hertzile (?sp?) has almost 900 since its been torn down. I've heard different things from different mechanics. I know the actual TBO on the prop is now something like 20,000 hours. However, I don't want to get stuck somewhere with a problem. How much time do most people here put on their props? BTW: I think the last overhaul was about 10 years ago. -Robert I'll echo Ron's response, and add the following. Our two-blade blade Hartzell CS prop TBO is 2000 hours or 5 years. That's pretty typical for props of this type. It is highly unlikely any prop would have a 20000 hr TBO. That sounds more like a life limit to me. Lower calendar TBOs are specified if the airplane is kept outside. Call the manufacturer or a good overhaul shop for more information. Ok, it sounds like I should at least break open the hub and have it resealed at next year's annual. The Mooney shop told me that bumping the TBO to 20,000 really meant that there was no TBO specified for the prop. However, I'm not sure what problems I'd see before I needed work. For some things the "don't fix it if it ain't broke" works well. For others, you could get stuck at some crappy airport in the middle of no where. I don't want that. ![]() At my last annual I opted to have the mags broken open and inspected rather than overhauled. The mags ended up looking really good and we opted to not overhaul them. I only ended up spending a few hundred on the open/close. We did replace some inexpensive parts (like contacts). -Robert |
m... Doug Vetter wrote in message et... Robert M. Gary wrote: My Hertzile (?sp?) has almost 900 since its been torn down. I've heard different things from different mechanics. I know the actual TBO on the prop is now something like 20,000 hours. However, I don't want to get stuck somewhere with a problem. How much time do most people here put on their props? BTW: I think the last overhaul was about 10 years ago. -Robert I'll echo Ron's response, and add the following. Our two-blade blade Hartzell CS prop TBO is 2000 hours or 5 years. That's pretty typical for props of this type. It is highly unlikely any prop would have a 20000 hr TBO. That sounds more like a life limit to me. Lower calendar TBOs are specified if the airplane is kept outside. Call the manufacturer or a good overhaul shop for more information. Ok, it sounds like I should at least break open the hub and have it resealed at next year's annual. The Mooney shop told me that bumping the TBO to 20,000 really meant that there was no TBO specified for the prop. However, I'm not sure what problems I'd see before I needed work. For some things the "don't fix it if it ain't broke" works well. For others, you could get stuck at some crappy airport in the middle of no where. I don't want that. ![]() At my last annual I opted to have the mags broken open and inspected rather than overhauled. The mags ended up looking really good and we opted to not overhaul them. I only ended up spending a few hundred on the open/close. We did replace some inexpensive parts (like contacts). -Robert Of course then there's the recent thread in this group about the prop that came "unglued" right after takeoff. The owner was lucky to get back to the airport if I remember right. I sometimes think TBOs are a concept originally developed by an advertising department. |
| Thread Tools | |
| Display Modes | |
| Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 11:18 PM |
| Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 04:04 AM |
| Prop balancing and assorted observations - long | Dave Hyde | Home Built | 10 | June 27th 04 02:08 AM |
| IVO props... comments.. | Dave S | Home Built | 16 | December 7th 03 12:43 AM |
| Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 08:45 PM |
