oil change on my Tripacer
Old June 19th 04, 11:42 PM
mike regish
Default oil change on my Tripacer
Did an oil change on my Tripacer. I've done them before and they're pretty
easy. This one though, it looks like my oil screen cover is leaking like
crazy.
I actually changed the oil last month right before it went into annual. They
flew it (looks like a couple of hours worth) with no leaks apparent. I flew
it for the first time last week and when I was parked to gas up noticed oil
dripping. Went up today and checked the torque on the oil screen housing and
they were all tight. Came back after 20 minutes or so and found I had left a
trail of oil. Lost a good part of a quart. I'm thinking I may not have
torqued them down evenly and I'm going to try replacing the gasket and going
around the bolts a little at a time. I usually retorque them after I run for
a while after an oil change because the gasket tends to crush some.
Any ides or suggestions on why this is happening? The surfaces are (were)
clean. I'll check better when I replace the gasket.
TIA.
mike regish
'53 Tripacer
Old June 21st 04, 10:12 PM
Bill Hale
"mike regish" wrote in message news:Dj3Bc.81904$Sw.45236@attbi_s51...
Does the oil screen have a crush washer?
Did you use a new one? Bill Hale
crazy.
TIA.
mike regish
'53 Tripacer
Old June 22nd 04, 12:20 AM
mike regish
It's a paper washer. It was new.
Today I found that the bolt flanges were cracked. Fortunately, a fellow TP
owner has installed the soin on filter on his and had his cover.
mike regish
"Bill Hale" wrote in message
om...
pretty
crazy.
They
flew
oil
and
left a
going
for
(were)
TIA.
mike regish
'53 Tripacer
A310 engine change Andy General Aviation 0 October 25th 04 07:48 AM
oil change on my Tripacer mike regish Owning 0 June 19th 04 07:00 PM
change of name. M. H. Greaves Military Aviation 6 April 10th 04 04:49 PM
Time to change the air in your tires Rich S. Home Built 18 March 22nd 04 06:47 PM
Updated information on Tripacer for sale in Durham NC, USA Lori Fields General Aviation 0 December 9th 03 04:05 PM
