#21
![]() I've never heard of piston rings rotating. Kind of makes staggering the I had a Chevy pickup years ago that I changed the rings on one cylinder twice. (This was before I had enough money to do things right) All five grooves on the piston rings would be in a vertical row letting the oil get by and smoke. The machinest said that the one cylinder was way out of round and the rest were OK. He said that the rings rotated on the pistons so I believed him. Before that I wondered why a good mechanic cleaned the grooves and rotated the rings before He installed them. Now for the other side. I overhauled a 225 HP Johnson outboard (Never again, Too many pieces) The piston rings have keepers on them to keep them from rotating. The oil injection must keep them from scoring. The terminology Stuck Ring. I wonder if that means Rotation or Stuck in the ring land or groove? Like I say I am an amateur and the only way that I have learned is by doing it myself because I didn't have enough money to let someone else do it. Could a lifter have stuck open or closed? Had one stick on a 172 and knocked a hole in the rocker cover. |
It's a fouled plug, burned valve or broken ring.
Fouled plug, maybe as it could clean itself up, a burned valve or broken ring wouldn't fix themselves. |
Fouled plug, maybe as it could clean itself up, a burned valve or broken ring wouldn't fix themselves. I certainly doubt something like a broken ring as well since the problem has not yet re-appeared. As far as the fouled plug theory - could a plug really get fouled that quickly? Remember the plot looked like a sharp step function. Most of the EGT/CHT change occurred in the first 20 seconds of the event. So for now I think the injector theory, or the stuck valve or lifter theory is more likely. By the way I flew again yesterday for 2.5 hours and the problem still has not repeated. So it may be awhile (if ever) before we figure out the real cause. ~Paul |
I thought the values were only for cylinder #1 - hence the EGT1 and CHT1
headings. -- Jim Carter "tony roberts" wrote in message news:nospam-978501.00081830062004@shawnews... Hi Paul The original reply that I gave you was for one cylinder. Rereading your post, it seems that the readout was for all cylinders, which changes the cause to Timing out or bad magneto. (And no, I'm no expert on this stuff - I'm giving you these answers right out of the book for my own engine analyzer). HTH -- Tony Roberts PP-ASEL VFR OTT Night Almost Instrument ![]() Cessna 172H C-GICE In article nospam-1C6AA9.22284826062004@shawnews, tony roberts wrote: It's a fouled plug, burned valve or broken ring. And that is straight fom the book on my engine analyzer Tony C-GICE In article , "Paul Mennen" wrote: For the last 200 hours I've recorded all the data from my engine analyzer which makes it easy to look at such things. Anyway a week ago I was flying along steady at 12 thousand feet when I noticed an unusual shift in the engine bar graph display. Looking at the recorded data I see that all flight data is rock steady and all engine data (and fuel flow) is also rock steady except for EGT1 and CHT1. From the beginning of the event this is what it looked like: Time after event EGT1 CHT1 ---------------- --------- --------- t = 0 1355F 300F t + 20 seconds 77F rise 7F drop t + 80 seconds 100F rise 19F drop t + 3 minutes 114F rise 25F drop After that it was pretty much steady, but I reduced power after a few more minutes. (By the way, this is a Turbonormalized IO550.) So EGT1 which was the coolest (as usual), rose to the level of the warmest few cylinders. And CHT1 was the coolest (as usual) and dropped away even more below the average. Still the final temps do not seem that alarming, but when you look at the graph it looks really strange since I've never seen such step changes unless it was in response to some control input. In the few flights I have taken since that event, I haven't seen anything unusual like this happen again. So to those of you who understand internal combustion engines - what can cause a sudden drop in power in one cylinder like this? Could something have fallen into this cylinder or could a valve stick for a while or something? Or is this a sign that something is breaking? What would you do about it? - - Keep a close eye on it? - Do an oil analysis? - Ground it? - Have a mechanic look at it? Can a bad mag or spark plug cause such a thing? (BTW the engine is a factory remain with 300 hours on it). Thanks in advance for any insights you may have. ~Paul |
On re-reading it, you are correct.
Oh well - I already answered that one ![]() Tony I thought the values were only for cylinder #1 - hence the EGT1 and CHT1 headings. -- Jim Carter "tony roberts" wrote in message news:nospam-978501.00081830062004@shawnews... Hi Paul The original reply that I gave you was for one cylinder. Rereading your post, it seems that the readout was for all cylinders, which changes the cause to Timing out or bad magneto. (And no, I'm no expert on this stuff - I'm giving you these answers right out of the book for my own engine analyzer). HTH -- Tony Roberts PP-ASEL VFR OTT Night Almost Instrument ![]() Cessna 172H C-GICE In article nospam-1C6AA9.22284826062004@shawnews, tony roberts wrote: It's a fouled plug, burned valve or broken ring. And that is straight fom the book on my engine analyzer Tony C-GICE In article , "Paul Mennen" wrote: For the last 200 hours I've recorded all the data from my engine analyzer which makes it easy to look at such things. Anyway a week ago I was flying along steady at 12 thousand feet when I noticed an unusual shift in the engine bar graph display. Looking at the recorded data I see that all flight data is rock steady and all engine data (and fuel flow) is also rock steady except for EGT1 and CHT1. From the beginning of the event this is what it looked like: Time after event EGT1 CHT1 ---------------- --------- --------- t = 0 1355F 300F t + 20 seconds 77F rise 7F drop t + 80 seconds 100F rise 19F drop t + 3 minutes 114F rise 25F drop After that it was pretty much steady, but I reduced power after a few more minutes. (By the way, this is a Turbonormalized IO550.) So EGT1 which was the coolest (as usual), rose to the level of the warmest few cylinders. And CHT1 was the coolest (as usual) and dropped away even more below the average. Still the final temps do not seem that alarming, but when you look at the graph it looks really strange since I've never seen such step changes unless it was in response to some control input. In the few flights I have taken since that event, I haven't seen anything unusual like this happen again. So to those of you who understand internal combustion engines - what can cause a sudden drop in power in one cylinder like this? Could something have fallen into this cylinder or could a valve stick for a while or something? Or is this a sign that something is breaking? What would you do about it? - - Keep a close eye on it? - Do an oil analysis? - Ground it? - Have a mechanic look at it? Can a bad mag or spark plug cause such a thing? (BTW the engine is a factory remain with 300 hours on it). Thanks in advance for any insights you may have. ~Paul -- Tony Roberts PP-ASEL VFR OTT Night Almost Instrument ![]() Cessna 172H C-GICE |
#28
"Jim Carter" writes:
What causes the piston rings to rotate? Since the piston movement is perpendicular to the cylinder wall, there must be some other mechanism other than just piston movement causing them to rotate. Very Clever Design. I can't recall the details, but ISTM there are [automotive] patents on making 'em creep along. Also, why would the grooves on the rings have to be lined up to allow leakage through the groove? It does leak lots more; the gap between the rings is not all that far, I guess... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
#29
than just piston movement causing them to rotate. I just can't get it into my head how that a ring can be put in and when the engine is torn down all of the grooves will be in the same place as when installed. The keepers on a two cycle boat engine (not motor) are the only anti - Rotation device that I have seen. |
#30
Dave,
I've torn engines down before and the distance between the rings is relatively a lot more than the gap between the ends of the ring when compressed into the cylinder. It is such a big difference that I don't see how the intra-ring distance could be restrictive to the flow of gasses passing through the ring gap. I'd really like to see some information on the "Very Clever Design" you mentioned. Even if the cylinders were honed with a diagonal pattern, shouldn't the ring just reverse direction at the end of the stroke and follow the honing marks? -- Jim Carter "David Lesher" wrote in message ... "Jim Carter" writes: What causes the piston rings to rotate? Since the piston movement is perpendicular to the cylinder wall, there must be some other mechanism other than just piston movement causing them to rotate. Very Clever Design. I can't recall the details, but ISTM there are [automotive] patents on making 'em creep along. Also, why would the grooves on the rings have to be lined up to allow leakage through the groove? It does leak lots more; the gap between the rings is not all that far, I guess... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
My Engine Fire!! | embarased@host.com | Owning | 1 | March 31st 04 01:41 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
