Use a bar to mechanically join the three breakers so they all trip together
or get a three phase breaker from your local electrical wholesale outlet. The cost of the proper ones is not high. Peter |
That is what the original poster said, "GANG them together!"
"Bushy" wrote in message ... Use a bar to mechanically join the three breakers so they all trip together or get a three phase breaker from your local electrical wholesale outlet. The cost of the proper ones is not high. Peter |
Actually a three phase motor runs just fine most of the time with one
phase missing...just at reduced power. It certainly won't start, but once spinning there is no problem. That is actually the way one can make a cheap rotating three phase converter from another three phase motor. I have seen it done many times.(done it myself several times..have seen small machine shops get all their three phase power this way)) The power is connected to two leads of a three phase motor and the motor is started with a kick to spin the pulley or a rope is wrapped on the shaft and used like a lawnmower starting cord. Once the three phase is "kick" started the third lead generates the third phase. Those three phases connections will then power another smaller three phase motor...producing near full hp on the second motor. John Ammeter wrote: I'll second this advice!!! A three phase motor with one phase tripped out or dead is going to burn out very soon. It's called "single-phasing"..... John -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| |
Kathryn & Stuart Fields wrote: BTW your post Blanton and carb sizing had an equation that I had never seen before. Thanks.. Stu Fields You sure that was my post? If you still have it around shoot it back at me.(my email) I infrequently post formulas or equations. Maybe I'll learn something. -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| |
Going back to the fact that in home use one will not likely have three
phase and the power for a three phase circuit will be generated by a static or rotating phase converter running off of the household 220v system. You will be breakering the system via the two throw or ganged breaker running your stove, dryer or air conditioner. Cy Galley wrote: That is what the original poster said, "GANG them together!" "Bushy" wrote in message ... Use a bar to mechanically join the three breakers so they all trip together or get a three phase breaker from your local electrical wholesale outlet. The cost of the proper ones is not high. Peter -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| *------------------------------**----* \(-o-)/ AIRCRAFT PROJECTS CO. \___/ Manufacturing parts & pieces / \ for homebuilt aircraft, 0 0 TIG welding While trying to find the time to finish mine. |
