#101
![]() Dave Butler wrote: Why "especially with all the accessories installed"? The injection system tends to be more complex and heavier than gasoline models or carburettors. This is because the injectors spray fuel directly into the cylinder rather than into a section of the intake manifold. Many diesels handle the higher CHTs by using water cooling systems, and those add weight (Lycoming was working on one of these a few years ago). On the other hand, the glow plug systems used for starting tend to be lighter than the magnetos used in gas engines. The main cause of the weight difference is still the fact that everything must be beefed up to handle the higher compression, though. Why is a 2-stroke cycle engine lighter than a 4-stroke? There are twice as many power pulses per minute with a 2-stroke. They usually are not as efficient as a 4-stroke, so you don't get twice as much power, but they will easily produce 1.6 times the power of a 4-stroke the same size, and most do better than that. So a 200hp 2-stroke engine is smaller than a 200hp 4-stroke engine. In addition, 2-strokes don't have a valve train, which saves some weight. George Patterson In Idaho, tossing a rattlesnake into a crowded room is felony assault. In Tennessee, it's evangelism. |
#102
![]() "Thomas Borchert" wrote in message ... Dude, Diamond has decided to offer Lycoming engines as an alternate for the Twin Star (which must really please Textron) Diamond has been bitten before when introducing a new engine to the US market, the Rotax. So they're careful. The US market is strongly in the grip of what I like to call "pilot inertia", as evident here in the group. "We've always done it that way, so we'll keep doing it that way" is strong in the pilot community. The US pilot community is that way for a reason. The performance of the Rotax was miserable. Embry-Riddle ended up getting rid of all their Katanas because of it. |
#103
![]() "Thomas Borchert" wrote in message ... Mike, I'm surprised there isn't more interest in the diesel version in the US. What percentage of DA40s sold in Europe are diesel vs. gas? It is not offered in the US. Simple as that. It is not certified here, either. |
#104
C,
The US pilot community is that way for a reason. Well, sometimes yes, sometimes no. The performance of the Rotax was miserable. Embry-Riddle ended up getting rid of all their Katanas because of it. Then it may have been miserable for their mission (Prescott, AZ, anyone?). But that doesn't mean it was unsuitable for others. -- Thomas Borchert (EDDH) |
#105
G.R.,
. Since some of the new diesel designs are 2-stroke, and most gas engines are 4-stroke, None of those certified or close to certification are 2-stroke. And all the Thielert engines are very close to the Avgas engines they replace, weightwise. -- Thomas Borchert (EDDH) |
#106
C,
It is not offered in the US. Simple as that. It is not certified here, either. Don't be a smarta.. Why certify something that isn't sold? -- Thomas Borchert (EDDH) |
#107
-heavier high-pressure fuel pumps, lines etc which are not needed on gas engines. -on two strokes you need a supercharger to get them started. Why is a 2-stroke cycle engine lighter than a 4-stroke? -less stuff: with twice the power strokes per piston, one needs fewer pistons and all associated stuff. For example the three cylinder Wilksch is as smooth as a six cyl gas engine http://www.wilksch.com/ If only they could be lighter :-) Cheers & blue skies, Pete Europa Builder A239 dual-wing http://europa.zutrasoft.com "Dave Butler" wrote in message ... G.R. Patterson III wrote: Aren't they also heavier, i.e., pound of engine weight per HP generated? Every one of which I've read is heavier than an equivalent gas engine, especially with all the accessories installed. Since some of the new diesel designs are 2-stroke, and most gas engines are 4-stroke, though, some of the newer ones may actually come in lighter than the equivalent gasoline engine (if they ever make it to production). Help me out here. Why "especially with all the accessories installed"? Why is a 2-stroke cycle engine lighter than a 4-stroke? Thanks. Dave |
#108
It is really frustrating, as a consumer, to see cars and planes sold abroad
with the latest technology, getting 30% better fuel economy, and the same products are not available here, because the manufacturers have the attitude that US consumers don't care about fuel efficiency. When you look at the increased range and payload possible with the DA40 with a diesel engine, due to its significantly lower fuel consumption, you'd be crazy to buy anything but a diesel, unless there are issues with the newness of the engine. Mike Schumann "Thomas Borchert" wrote in message ... Mike, I'm surprised there isn't more interest in the diesel version in the US. What percentage of DA40s sold in Europe are diesel vs. gas? It is not offered in the US. Simple as that. -- Thomas Borchert (EDDH) |
#109
Was it the performance, or the lack of any idea how to fix the things, or
the amount of scheduled and non scheduled downtime? "C J Campbell" wrote in message ... "Thomas Borchert" wrote in message ... Dude, Diamond has decided to offer Lycoming engines as an alternate for the Twin Star (which must really please Textron) Diamond has been bitten before when introducing a new engine to the US market, the Rotax. So they're careful. The US market is strongly in the grip of what I like to call "pilot inertia", as evident here in the group. "We've always done it that way, so we'll keep doing it that way" is strong in the pilot community. The US pilot community is that way for a reason. The performance of the Rotax was miserable. Embry-Riddle ended up getting rid of all their Katanas because of it. |
#110
with a diesel engine, due to its significantly lower fuel consumption, you'd be crazy to buy anything but a diesel, unless there are issues with the newness of the engine. Exactly, the problem. In addition , the American market has been less forgiving and experimental than the european market. I don't know why. But that seems to be the belief of the manufacturers. The margins are low, and the risks are high, and so less chances will be taken here than over there. |
Revisiting lapse rates (From: How high is that cloud?) | Icebound | Instrument Flight Rules | 5 | November 26th 04 09:41 PM |
Question, Diamond distance as unsuccessful triangle. | Roger | Aviation Marketplace | 1 | November 22nd 04 07:34 PM |
Cessna 182T w. G-1000 pirep | C J Campbell | Instrument Flight Rules | 63 | July 22nd 04 07:06 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
P-38 Exhaust | Stephen Harding | Military Aviation | 10 | April 19th 04 07:03 AM |
