#31
Al,
Wow! Since I haven't the slightest idea why that would matter, you need to explain to me why this should be done in this, a very unscientific and casual comparison. I did go back and check the data, the trip was 544NM. So I guess I'll restate that I was throttled waaaaaay back so as not to run ahead of the Mooney, he was firewall forward to keep up with me and on both legs I burned about 10 gallons less than he. He has the 200 hp engine and I the 250 hp engine. Extrapolating the memory, it took me about $25 less in fuel to make each trip than it did he. I probably could have used the same fuel and arrived about an hour before, so the potential owner needs to check his mission profile before making any decision. But for $45K, I would look hard at that Mooney. Al, strange thing if it was a M20E "flat out", "firewall forward" and with a "newly o/h'd engine". It should do about 150 TAS on ~23" and 2500 RPM on altitude and on a cruise setting, burning about 10.5 GpH. Sounds odd to me that you have to go "throttled waaaaay back" to let him keep up with you in your old Bo'. Obviously he was running with a less-than-ideal setting and burning much to much fuel, say: he has not pulled the mixture (re knob) to a setting giving something inbetween of max RPM or min SFC. Mooney's are know for their efficiency and this reputation is not based on a single event. ;-) Best Regards Kai P.S.: If you really are in the topic of measuring aircraft efficiency I would recommend using the "CAFE 400" equation to compare aircraft (look under http://www.cafefoundation.org/challenge.htm for more details) Speed^1.3 x Miles Per Gallon x Payload^0.6 Use a efficient yet safe (material and you) setting during your tests, consider running LOP (cause it's about efficiency) I'm looking forward hearing from your results... ;-) |
#32
In article gers.com,
David Megginson wrote: sense than driving or taking the InterCity train? From the regulations I've seen and heard about, the legislators in EU countries seem to view private aviation as strictly recreational, like driving speedboats in the Mediterranean or snowboarding in the Alps, and thus have little to hold them back from over-regulating it. I think it varies widely by country - and the trouble with harmonization, they all want to harmonize with the strictest (i.e. worst) rules. To compare British airspace with German airspace, the differences that directly affect me: 1. I have an FAA ticket. I can fly in Britain without needing to do any paperwork at all; in Germany you have to convert to a JAA license. 2. In Britain, flying IFR in class G airspace with no flight plan at all is routine. In Germany, you need IFR slots for everything. (Although US pilots might think flying IFR in class G is suicidal, it must be remembered over much of Britain, class G extends from SFC-FL245 and you can get Radar Advisory Service - think flight following where they will vector you around other traffic - over most of the country) 3. In Britain, all you need is the landowner's permission to land somewhere. In Germany (as the other poster pointed out) there has to be an official observer at even the tiniest airfield. There are probably many more differences. I sincerely hope that our much more liberal rules aren't harmonized with anywhere else in the EU. The most annoying thing after moving from the US is the higher fuel prices and most GA fields have landing fees. I don't fly anything nearly big enough to attract en-route IFR fees though. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
#33
In article , Dude wrote:
They are not that small at all. That's a big myth in many ways. Don't write them off as small without sitting in one to see how well it fits you. If you are long legged, it can be a good choice (Mooney's have LONG seat rails that can turn it into a 3 seater if the pilot is tall enough). My main beef with the Mooney (I've not got that many hours in them, and I've been in the older manual gear ones as well as a 1994 or thereabouts newer model) is that the forward visibility was terrible. The panel seems very high, and the windscreen very small. The older one felt almost 'tank slit' like. Although the physical width of the Mooney cabin is the same as a Bonanza, the Bonanza felt much bigger, probably because I could see out of it (I have long legs and a short body, maybe people with short legs and a long body don't have this problem). I'm not keen on Pipers for much the same reason (especially the Cherokee Six - the one I've been in may have just had an over inflated nose-strut, but that huge long nose combined with a slight nose up attitude on the ground meant that the view ahead was more like in a tailwheel plane than a nosedragger). The Lance has to be the worst though - with that huge long nose, not only is the forward visibility crap, but the plane looks ugly and misproportioned too. As with anything - the best thing to do is to try the plane on for size. I found the Mooney a great flying plane, but due to the rather poor outward visibility, if I had that kind of money I'd be buying a Bonanza instead. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
#34
Dylan Smith wrote:
There are probably many more differences. I sincerely hope that our much more liberal rules aren't harmonized with anywhere else in the EU. The most annoying thing after moving from the US is the higher fuel prices and most GA fields have landing fees. I don't fly anything nearly big enough to attract en-route IFR fees though. Thanks for the info. I'm hoping to do some flying in the UK some time when I'm over on business -- I'd especially like to fly along the SE coast past Hastings, where my spouse and I spent a big part of our honeymoon in the summer of 1988. If I recall correctly, isn't there also a restriction in the UK that you need prior permission to land at any field (vs. Canada or the U.S., where prior permission is required mainly at military or private fields)? All the best, David |
#35
In article , Newps wrote:
an annual either. A wood wing could be a disaster and you'd be foolish to buy a Mooney with one. Metal wings can be a disaster, too. If you've got an A&P who knows wood and can do you a pre-buy inspection, there's nothing wrong with a wood wing plane if the wood is in good condition. I fly a Schleicher Ka-8 glider (with a looong wood wing) that was built in the 1960s, and tow gliders with an Auster (with a rather shorter wood wing) that was built in 1946, and both are doing fine. If you don't have anyone nearby who knows wood, then I'd agree with staying with what can be supported locally. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
#36
![]() Dylan Smith wrote: My main beef with the Mooney (I've not got that many hours in them, and I've been in the older manual gear ones as well as a 1994 or thereabouts newer model) is that the forward visibility was terrible. The panel seems very high, and the windscreen very small. The older one felt almost 'tank slit' like. Did you have the seat pulled forward so you could press the rudder pedals to full deflection? I find pulling the seat forward gives you a great angle of vision because you're so close to the windscreen. OTOH, some people find it uncomfortable -because- they're so close to the windscreen. Claustrophobia, you know. if I had that kind of money I'd be buying a Bonanza instead. If I had Bonanza money, I'd fly a Bonanza, too. Mooney and Bonanza are not the same kind of money. Dave |
#37
What other plane does 160 knots on 10gal/hr?
Not the Mooney C model unless there is a good tailwind and running 2300 RPM. The individual that wrote the above was discussing a 'J' model Mooney. A 'J' model will run 160 kts on 10 GPH at 2500 RPM. I get 147 kts on less than 9 GPH at 2500 in my lowly, stock 'C' model. --- Ken Reed |
#38
On Wed, 11 Aug 2004 16:24:08 +0200, "Kai Glaesner"
wrote: Al, Wow! Since I haven't the slightest idea why that would matter, you need to explain to me why this should be done in this, a very unscientific and casual comparison. I did go back and check the data, the trip was 544NM. So I guess I'll restate that I was throttled waaaaaay back so as not to run ahead of the Mooney, he was firewall forward to keep up with me and on both legs I burned about 10 gallons less than he. He has the 200 hp engine and I the 250 hp engine. Extrapolating the memory, it took me about $25 less in fuel to make each trip than it did he. I probably could have used the same fuel and arrived about an hour before, so the potential owner needs to check his mission profile before making any decision. But for $45K, I would look hard at that Mooney. Al, strange thing if it was a M20E "flat out", "firewall forward" and with a "newly o/h'd engine". It should do about 150 TAS on ~23" and 2500 RPM on altitude and on a cruise setting, burning about 10.5 GpH. Sounds odd to me that you have to go "throttled waaaaay back" to let him keep up with you in your old Bo'. Obviously he was running with a less-than-ideal setting and burning much to much fuel, say: he has not pulled the mixture (re knob) to a setting giving something inbetween of max RPM or min SFC. Mooney's are know for their efficiency and this reputation is not based on a single event. ;-) Best Regards Kai P.S.: If you really are in the topic of measuring aircraft efficiency I would recommend using the "CAFE 400" equation to compare aircraft (look under http://www.cafefoundation.org/challenge.htm for more details) Speed^1.3 x Miles Per Gallon x Payload^0.6 Use a efficient yet safe (material and you) setting during your tests, consider running LOP (cause it's about efficiency) I'm looking forward hearing from your results... ;-) Well we could get scientific about it, then start citing facts such as top mounted antennas, gap seals, paint and other factors that may bring in a total 1 kph, but the comparison is real as well as consistent. If we want to speak about performance we need to keep everything in perspective and not compare a Mooney to a Bonanza of the same vintage. I worship in the House of GAMI. My JPI hymnal is always turned to page LOP. |
#39
In article ble.rogers.com, i
David Megginson wrote: If I recall correctly, isn't there also a restriction in the UK that you need prior permission to land at any field (vs. Canada or the U.S., where prior permission is required mainly at military or private fields)? No. However, most airfields are private and you'll need PPR at those, it's just a matter of making a phone call before you depart. (Some airports are PPR only some of the time, and 'just turn up' the rest - the ones that are sometimes PPR usually have some sort of activity like skydiving or gliding going on). The AIP (the equivalent of the A/FD + approach plates) is avaiable online at http://www.ais.org.uk and has information for any airfield with an ICAO airport identifier in Britain. You have to register, but it's free and the information is in PDF form (I usually print out the pages for an airfield I'm going to). This has the phone number of the airfield too, but unfortunately it doesn't tell you whether it's PPR or not. (It's best to just assume it is since many of them are and call them anyway). Some airfields (typically the larger ones) want you to wear 'high visibility' (orange vests) if you are out walking on the ramp. Funnily enough, although the risk of getting sued is an order of magnitude more likely in the States (and the settlement costs several orders of magnitude higher) people in Britain seem to be far more paranoid about lawsuits than people in the US. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
#40
In article , Thomas Borchert wrote:
Dylan, The panel seems very high, and the windscreen very small. Let me say this: If you ever fly a DA40, the Mooney will definitely become very much less attractive in that regard. I have flown a DA-40, and I agree. If I had the money I'd buy one tomorrow! -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
Mooney drops into my backyard | Dave Butler | Owning | 41 | May 11th 04 10:19 PM |
Advice request -- buying an airplane | Casey Wilson | Owning | 4 | April 19th 04 03:22 PM |
Mooney info | eddie | Owning | 13 | March 12th 04 06:42 PM |
Mooney to Offer Light Sport Airplane | Rick Pellicciotti | Home Built | 4 | September 24th 03 01:08 PM |
Cirrus vs Mooney | Charles Talleyrand | Owning | 6 | July 8th 03 11:35 PM |
