I just bought a Helio Courier and the fuel guages (actually one guage with a
four position switch) don't work very well. Since different tanks seem to work differently I assume that the problem is in the sender or the wiring. Where should I start? does anybody know what the resistance range should be on the senders? Thanks Mike MU-2 Helio Courier |
Mike Rapoport wrote:
I just bought a Helio Courier and the fuel guages (actually one guage with a four position switch) don't work very well. Since different tanks seem to work differently I assume that the problem is in the sender or the wiring. Where should I start? does anybody know what the resistance range should be on the senders? Don't rule out the switch itself... Fix'n to get into the same issue on 6 EGTs... |
"Mike Rapoport" wrote in message
hlink.net... I just bought a Helio Courier and the fuel guages (actually one guage with a four position switch) don't work very well. Welcome to our world! :-) Paul |
Thanks, good point.
Mike MU-2 "Darrel Toepfer" wrote in message ... Mike Rapoport wrote: I just bought a Helio Courier and the fuel guages (actually one guage with a four position switch) don't work very well. Since different tanks seem to work differently I assume that the problem is in the sender or the wiring. Where should I start? does anybody know what the resistance range should be on the senders? Don't rule out the switch itself... Fix'n to get into the same issue on 6 EGTs... |
| Thread Tools | |
| Display Modes | |
| spaceship one | Pianome | Home Built | 169 | June 30th 04 06:47 AM |
| Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Home Built | 0 | January 26th 04 08:48 AM |
| Jet A / JP-4 ?? | CVBreard | General Aviation | 7 | December 8th 03 04:44 PM |
| Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 03:57 AM |
| Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 08:09 PM |
