#31
"Bob Miller" wrote in message
m... Those numbers didn't sound right so I checked my 1965 M20C (short rudder) manual which lists a demonstrated crosswind of 15 kt (17 mph). I bet the M20J is higher than that. No I promise you, it's 11 knots (at least it was on our 1982 M20J). That doesn't necessarily mean that the M20J has less capability, just that Mooney didn't certify it to that capability. Julian Scarfe |
#32
On Mon, 06 Sep 2004 06:53:15 GMT, "Julian Scarfe"
wrote: I don't know what else you fly, Ron, but aircraft like the TB20, the PA28s and most light twins seem to handle crosswind take-offs with rather more comfort. "Ron Rosenfeld" wrote in message ... Sorry about that. I did some reinstallation and my signature got changed. But I've got over 2,500 hours in a Mooney M20E. And I presently fly out of a single runway airport with occasionally strong, gusty crosswinds. I've not had a problem with crosswind takeoffs, either. Just hold the nose down, aileron into the wind, and pop-off when ready to fly. Obviously on a paved strip. Well, I was looking to see if the M20J and M20E had any differences that would explain our difference in perception, but I'm not sure there is any. The M20J was cleaned up by Lo Presti to the tune of about 20 knots, but isn't it the same wing set at the same height above the ground? I've described the issue I had in other posts, so I won't repeat it. While I don't have your time on the aircraft, I did accumulate more than 500 hours. And if you are talking about a 2,000' (610m) runway with trees to the end, then yes, I would not want to be based there, given a choice. But, at least here in the US, I don't believe I've ever seen a paved, short runway where the 50' obstacle was at the beginning of the runway. Grass is another story. I've been into Lubec airport (65B) which is 2024' (617m), grass, with trees right to the end. Landing was not much of a problem. But takeoff was close to the trees, even at 150 lbs under MGW. I had a co-owner/partner in the Mooney group who is much braver than I was with shorter strips. I'll check to see what he regards as "short". ;-) Julian |
#33
On Mon, 6 Sep 2004 10:37:16 -0700, "Peter Duniho"
wrote: "Ron Rosenfeld" wrote in message .. . [...] And if you are talking about a 2,000' (610m) runway with trees to the end, then yes, I would not want to be based there, given a choice. But, at least here in the US, I don't believe I've ever seen a paved, short runway where the 50' obstacle was at the beginning of the runway. I'm struggling to think of one myself. However, I have seen many paved runways with 100-150' obstacles not very far from the runway (500-1000' perhaps). These are roughly equivalent to a 50' obstacle right at the runway. Here's one of the "easier" examples of the above: http://www.airnav.com/airport/W10 Pete Well they are certainly rare. Even the example you cite really doesn't cause a big problem, if I do the math correctly. It shows a 100' tree 800' from the end of one runway. But the runway is 2400 (732 m). So to touch down with 2000' remaining requires about a 6° glide slope -- something that is certainly doable, with practice, in a Mooney. Definitely not for a new owner, or even for an old owner that hasn't flown much recently :-). I note that despite the tree, there are 28 single and 2 twin engine aircraft based at that field, and 39 operations per day! Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
#34
On Mon, 06 Sep 2004 18:50:08 GMT, "Julian Scarfe"
wrote: Well, I was looking to see if the M20J and M20E had any differences that would explain our difference in perception, but I'm not sure there is any. The M20J was cleaned up by Lo Presti to the tune of about 20 knots, but isn't it the same wing set at the same height above the ground? I've described the issue I had in other posts, so I won't repeat it. While I don't have your time on the aircraft, I did accumulate more than 500 hours. Well, although the 'J' has the same wing, it has a longer body and a higher MGW. But I don't know what that plus the clean up mods do for take off and landing distances -- I don't have a POH for the 'J'. I think the stall speed may be a few knots higher, so that could make a difference at the margins. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
#35
#36
I can't understand that. With full
fuel in each plane, I can carry more payload than the 182. 84 gallons of fuel weigh more than 44 gallons. Seems like my 182 had a useful load of 587 pounds with full fuel. Not much useful but could go a long way. |
#37
I know a 'C' can handle a 25 kt direct crosswind.
I know a 150 with a student pilot in the dark that handled a 25 knot direct crosswind on Dec 24, 1980 in Canadian TX. Tried to kiss the ground but too many grassburrs. |
#38
Bob,
Let me emphasize, in case you aren't aware, that the "demonstrated" crosswind component in our a/c is NOT a limitation. It usually reflects ONLY the test flight done on the first day when the crosswind exceeded that required by the regulations (which is some percentage of the stall speed - I don't recall the exact number). I know a 'C' can handle a 25 kt direct crosswind. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) I'm aware of that. The previous poster seemed to imply that Mooney deliberately set the limitation low. Can any other J owners corroborate the 11 kt demonstrated x/w for a J?? My M20C demonstrated x/w: 15 kt My club PA32R300 demonstrated x/w: 17 kt The M20 definitely has less rudder. In 600 hrs I have not had the opportunity to land my C with more than 20kt of crosswind. 30 kts approaches my threshold speed of 65 kt, which to line-up would mean crabbing to nearly 30 deg. I'm saying that 30 kt would give me pause. Bob Miller |
#39
... [...] It shows a 100' tree 800' from the end of one runway. But the runway is 2400 (732 m). So to touch down with 2000' remaining requires about a 6° glide slope -- something that is certainly doable, with practice, in a Mooney. "With practice". No one should land at that airport without being confident in their short field techniques, and many pilots are not. If Julian said that the Mooney simply couldn't be landed on a 2000' runway with a 50' obstacle, then I missed it. IMHO, the point is that even though it's doable, it requires even more careful attention to technique than many other airplanes would. Definitely not for a new owner, or even for an old owner that hasn't flown much recently :-). Exactly. ![]() I note that despite the tree, there are 28 single and 2 twin engine aircraft based at that field, and 39 operations per day! Well, the word "tree" in the A/FD description is misleading. What there actually is, is an entire forest of mature Douglas Fir. I'm actually a bit skeptical of the 100' height, as mature Douglas Fir is generally at least that high, and the forest north of the airport is on a hill above the airport. Anyway, even with those caveats, I'm not saying you couldn't land a Mooney there. A person flying by the numbers, using proper technique, should be fine. It's just no place to be sloppy. Pete |
#40
Hey Jon...keep up the posts your buying adventure. I'll be
interested to see what you finally wind up with and what the journey was like. I'm hoping to eventually head down the ownership path. At this point, I'm only familiar flying Cessna hardware but am definitely interested in what you're leaning toward in the Mooney arena. Something about 160 kts and 10 gph that just sounds like something for nothing...er, sort of. Nice looking plane, by the way. -- Jack Allison PP-ASEL, IA Student "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
Any opinions on the Garmin GNS 480 ! ! ! | RonLee | Instrument Flight Rules | 18 | January 18th 05 12:33 PM |
Opinions on Cessna 340, 414 and 421 | john szpara | Owning | 55 | April 2nd 04 09:08 PM |
Opinions wanted | ArtKramr | Military Aviation | 65 | January 21st 04 04:15 AM |
OPINIONS: THE SOLUTION | ArtKramr | Military Aviation | 4 | January 7th 04 10:43 PM |
Rallye/Koliber AD's and opinions | R. Wubben | Owning | 2 | October 16th 03 05:39 AM |
