"Speed" tape?
Old September 29th 04, 03:45 PM
Jay Honeck
Default "Speed" tape?
At Reno, all the Formula One and Sport class racers had every single
non-aerodynamic gap covered with clear tape.
Which got me to thinking, there are LOTS of non-aerodynamic gaps on my
Pathfinder.
The stuff looks like basic, clear packing tape. Anyone used this stuff? Is
there any benefit at all, or is it one of those "over 200 mph" things, like
the spoiler on my Mustang?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old September 29th 04, 05:36 PM
G.R. Patterson III
I had a popped fabric tape on my Maule last year. I had clear packing tape over it
for a while until I could get it repaired. A very short while, as it turned out.
Whatever they're using, it *isn't* clear packing tape.
George Patterson
If a man gets into a fight 3,000 miles away from home, he *had* to have
been looking for it.
Old September 29th 04, 08:16 PM
ShawnD2112
It gets even more arcane than that. During a rebuild or major work, they'll
also tape up every opening and lightening hole INSIDE the aircraft as well.
Air moving into the airplane will always find a way out, apparently, thereby
causing drag. Since you can't close up every gap on the outside, they block
up as many gaps inside thereby causing a dead end and no more drag.
Shawn
"Jay Honeck" wrote in message
news:5Uz6d.131331$MQ5.70054@attbi_s52...
Pathfinder.
Is
like
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old September 30th 04, 12:27 AM
Vaughn
Pathfinder.
Since gap taping is commonly done on gliders, I guess it is not just one of
those "over 200 mph" things. I am not familar with the clear stuff though.
Vaughn
Old September 30th 04, 01:31 PM
john smith
I believe you can access the IAC listserve archives from landings.com
A couple years ago this topic was discussed and discribed, including
manufacturer and model number of the tape used.
Pathfinder.
Old September 30th 04, 09:42 PM
Brian Sponcil
Art Matteson of AMR&D uses tape for his gap seals. It's 3M Scotch #8672 one
inch wide polyurethane tape which you can buy for like $30 a roll. Of
course for those of us with certified planes it would be "illegal" to put
the stuff on without a 337 or STC. As far as I can tell it works about as
well as aluminum gap seals it's just cheaper and easier to install.
-Brian
N33431
"john smith" wrote in message
Pathfinder.
Is
like
Old September 30th 04, 11:42 PM
Jay Honeck
one
I know it's illegal to put tape on control surfaces without an STC -- but
what's the group-think on putting it on other aerodynamic problem areas?
For example, on a gap between two clamshell halves of a wheel pant? Does
putting speed tape on a non-structural member require an STC?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old October 1st 04, 04:19 AM
kage
The high performance sailplanes use "turbulator tape" right on the wings.
Could also be used on powered aircraft.
http://www.google.com/search?sourcei...urbulator+tape
Karl
newsZ%6d.84254$wV.12775@attbi_s54...
one
as
Does
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old October 1st 04, 05:14 AM
Mike Noel
I used to fly gliders quite a bit and gap sealing cloth tape is commonly
used on the control surfaces. One day one of the club members landed in the
Grob 2 place and practically kissed the ground when he got out. Part of the
aileron gap sealing tape had started to peal up and it had such an adverse
effect on the handling that the guy thought he was going to die.
Regards,
Mike
http://mywebpage.netscape.com/amountainaero/fspic1.html
Pathfinder.
Is
like
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old October 1st 04, 04:43 PM
G.R. Patterson III
The IA at Aircraft Mods & Repair told me that it does not require an STC. The part in
question was the vertical stabilizer.
George Patterson
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
BrandNew-Vector Heavy Duty Plastic Construction Tape Dispenser 13 Peaces Left [email protected] Aviation Marketplace 0 April 29th 04 11:43 PM
Va and turbulent air penetration speed. Doug Instrument Flight Rules 70 January 11th 04 08:35 PM
Va and turbulent air penetration speed. Doug Owning 69 January 11th 04 08:35 PM
New Film: The Need For Speed - Going to war on drugs Phil Carpenter Military Aviation 0 July 23rd 03 07:43 AM
