Does anyone have any insight as to my problem.
I just some work done on my Arrow which included removing the engine mount for repairs. On my second flight the transponder went out and would not reset. After appox. 2 minutes it came back on and has been working flawlessly for the past 4 hours of flight. The DME however is not working. The display will come on, you can enter freq. but nothing shows but dashes other than the freq. I looked under the dash and no wires seem to be pulled away and the antenna connections look good. I believe the transponder and the DME operate on the same antenna. Could the splitter be bad or the antenna if both leads connect to it? Any ideas before I take it to the avionics shop. Thank you, Larry |
Been there done that. The connector on the back of the radio is held into
the bracket with a small snap clip. If that clip has slipped off then the antenna connector is loose and would cause this kind of problem. I suggest carefully removing the unit and inspecting the back of the bracket. Make sure all the plugs are tight and attached to the bracket correctly. |
Yes, the antennas are still there and in contact.
When the engine mount was removed and replaced, they had to get under the panel an to the firewall to secure the nuts on the throughbolts. |
..Make sure all the plugs are tight and attached to the bracket correctly.
Thank you I will give that a try |
| GEM 1200 Problem | Jim Kaufeld | Owning | 11 | March 22nd 04 04:54 AM |
| A problem in the Military ? | Nick Jade | Military Aviation | 54 | March 15th 04 08:59 PM |
| Garmin fixes moving waypoint problem -- almost | Jon Woellhaf | Instrument Flight Rules | 6 | November 28th 03 06:29 PM |
| EGT Problem | Dennis O'Connor | Owning | 4 | August 27th 03 05:25 PM |
| Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 01:35 AM |
