Garmin 430 wierd issues
Old November 7th 04, 07:24 PM
Jon Kraus
Default Garmin 430 wierd issues
My partner and I just bought a '79 Mooney M20J with a 2 year old Garmin
430 Comm/Nav as the Comm # 1 adn a Bendix 170B as the Comm/Nav # 2. (yes
we had a pre-buy and everything "seemed" fine") I have some strange
issues with the 430 that I am sure you can help guide me thru. Issues:
1.) On the ground if you set the 430 to our UNICOM freq TYQ 123.05 and
do a radio check they can not hear you. TYQ has an AWOS and you can hear
that fine on the ground (120.725).
2.) On the ground if you set the 170B (nav/com # 2) and do a radio check
they come back as "loud and clear" (and yes they are at the station when
I try the radio check on comm 1) :-)
3.) One time we were on the ground set up on the Comm 1 and trying to
get the UNICOM operator to hear us when a Piper over the airport said we
were "loud and clear".
4.) Our local UNICOM is 123.05. UMP an airport 15 miles away's UNICOM
is 123.00. While airborn we kept picking up their transmissions.
I was going to try swapping antenna connections between Comm 1 and Comm
2 but as I peered under the dash looking for the antenna leads I said
"I'll screw more up then I'll ever fix so I left it alone)
Any suggestions or advise? Is this going to cost a fortune to fix?
Thanks in advance for your help!!
Jon Kraus
PP-ASEL-IA
Student Mooney Owner
4443H @ TYQ
Old November 7th 04, 08:16 PM
Bill Denton
You might double-check the settings on your audio panel to make sure you are
sending the mic to the proper radio.
"Jon Kraus" wrote in message
Jon Kraus
PP-ASEL-IA
4443H @ TYQ
Old November 8th 04, 01:11 AM
iflyatiger
Jon
I do not have access to my 530 right now to confirm what I will tell you
but..
It sound sounds to me like you might not be tuned to the correct exact
frequency.
There is a setting in the setup 2 page of the 430 called COM configuration
were you can set the channel spacing I wonder if this could be set wrong.
Hope it help..
Jon
Jon Kraus
PP-ASEL-IA
4443H @ TYQ
Old November 8th 04, 02:06 AM
Mike Rapoport
First check that the TX annunciator comes on the 430 when you transmit. It
is right there with the COM frequencies in the upper left corner. If the
annunciator is coming on then check the antenna. I assume that you can hear
on 123.05?
Mike
MU-2
we had a pre-buy and everything "seemed" fine") I have some strange issues
1.) On the ground if you set the 430 to our UNICOM freq TYQ 123.05 and do
a radio check they can not hear you. TYQ has an AWOS and you can hear that
they come back as "loud and clear" (and yes they are at the station when I
3.) One time we were on the ground set up on the Comm 1 and trying to get
the UNICOM operator to hear us when a Piper over the airport said we were
"loud and clear".
4.) Our local UNICOM is 123.05. UMP an airport 15 miles away's UNICOM is
I was going to try swapping antenna connections between Comm 1 and Comm 2
but as I peered under the dash looking for the antenna leads I said "I'll
Any suggestions or advise? Is this going to cost a fortune to fix? Thanks
Jon Kraus
PP-ASEL-IA
4443H @ TYQ
Old November 8th 04, 01:10 PM
Jon Kraus
Yes I can receive (hear) on 123.05 and the "TX" shows up as I push the
"press to talk" switch. Just UNICOM can not hear me from the ground.
Unfortunatly the only freq on this airport is the UNICOM 123.05 and the
AWOS which is 120.725.
on 123.05?
Mike
MU-2
"loud and clear".
Jon Kraus
PP-ASEL-IA
4443H @ TYQ
Old November 12th 04, 12:50 AM
Marty from Sunny Florida
If you hit the PTT and your antenna is not correctly connected to the 430,
you can damage the 430. I'd have a radio guy look at it before messing
around too much. On occasion, just looking can do some damage.
Just a thought ...
Marty from Sunny South Florida
It
hear
on 123.05?
Mike
MU-2
issues
do
that
I
get
were
"loud and clear".
is
2
"I'll
Thanks
Jon Kraus
PP-ASEL-IA
4443H @ TYQ
Old November 12th 04, 03:07 AM
Jon Kraus
The Avionics shop discovered that the comm side board is bad. It has to
go back to Garmin for the $600.00 refurb.... JK
Just a thought ...
It
hear
on 123.05?
Mike
MU-2
issues
do
that
I
get
were
"loud and clear".
is
2
"I'll
Thanks
Jon Kraus
PP-ASEL-IA
4443H @ TYQ
Garmin 430 Reception Jon Kraus Owning 16 November 7th 04 04:17 AM
Garmin 296 worth the money? Terry Owning 15 June 22nd 04 10:03 AM
How much could I get for these back issues? Aaron Smith Home Built 8 December 15th 03 01:07 PM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 03:04 AM
Garmin 430/530 Questions Steve Coleman Instrument Flight Rules 16 August 28th 03 10:04 PM
