Folks, I have a C-182 with an auto-fuel STC, which I've been operating on Mogas (along with an occasional fill of 100LL) for several years. Mogas being unavailable at my home airport, I use a pair of 6 gallon Gerry cans (plastic) to transport the fuel from a local gas station to the airplane. I've taken the usual precautions to keep dirt and moisture out of the Gerry cans but lately encountered something a bit unexpected: as I was preparing to fill the cans, I happened to glance inside one and noticed several patches of what appeared to be mold or fungus. These were dark brown in color, from 1/8 to 1/2 inches in diameter; there were 4 to 7 or so of these on the bottom inside surface of each can. Has anyone else encountered this, and have any ideas on how such contamination can be prevented? Beyond the obvious concern of fuel line blockage from this stuff (I've since started filtering the fuel when I transfer it the cans to the airplane), I'm worried the plane's entire fuel system may be contaminated. (I peered inside my Bladders with a flashlight but can't see enough to tell anything.) Is there any sort of anti-microbial additive that can be used with Mogas, that can "disinfect" my Gerry cans and/or fuel system? Does this problem exist with metal containers, or just peculiar to the plastic cans? I've heard that 100LL doesn't have this problem, due to the toxicity of Tetraethyl Lead. Perhaps occasional use in the Gerry cans would disinfect 'em? Any advice much appreciated! Thanks in advance... EGM |
Economic Girly Man wrote:
: I've taken the usual precautions to keep dirt and moisture out of the : Gerry cans but lately encountered something a bit unexpected: as I was : preparing to fill the cans, I happened to glance inside one and noticed : several patches of what appeared to be mold or fungus. These were dark : brown in color, from 1/8 to 1/2 inches in diameter; there were 4 to 7 or : so of these on the bottom inside surface of each can. I'm not sure what to think about your "diagnosis," but I know I felt a lot better running mogas after rigging a water-absorbing filter into the pour-spout of the cans I use. I found just a a bit of water, rust particles, in the fuel sample before I did this. Now, with the spin-on filter ($25 + some clever engineering to make it into a pour spout), I never see anything. I don't care what crap is in the can (I see some particles/water/etc on the bottom).... it never makes it into the tank. I'm not sure how to deal with the fuel bladders, but I drained and redrained my Cherokee tanks a few times after I found a bit of contamination in it. If you truly have slugs of growth, that could be hard to get out (for the same reason it's bad to leave it it... it'll plug holes/lines). If I had to guess, I'd say your cans got their growth while sitting empty for awhile with some water in the bottom. I wouldn't think it would grow in the airplane's bladders (but I could be wrong). -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
I've never heard of anything being able to live in gasoline.
Mike MU-2 "Economic Girly Man" wrote in message ... Folks, I have a C-182 with an auto-fuel STC, which I've been operating on Mogas (along with an occasional fill of 100LL) for several years. Mogas being unavailable at my home airport, I use a pair of 6 gallon Gerry cans (plastic) to transport the fuel from a local gas station to the airplane. I've taken the usual precautions to keep dirt and moisture out of the Gerry cans but lately encountered something a bit unexpected: as I was preparing to fill the cans, I happened to glance inside one and noticed several patches of what appeared to be mold or fungus. These were dark brown in color, from 1/8 to 1/2 inches in diameter; there were 4 to 7 or so of these on the bottom inside surface of each can. Has anyone else encountered this, and have any ideas on how such contamination can be prevented? Beyond the obvious concern of fuel line blockage from this stuff (I've since started filtering the fuel when I transfer it the cans to the airplane), I'm worried the plane's entire fuel system may be contaminated. (I peered inside my Bladders with a flashlight but can't see enough to tell anything.) Is there any sort of anti-microbial additive that can be used with Mogas, that can "disinfect" my Gerry cans and/or fuel system? Does this problem exist with metal containers, or just peculiar to the plastic cans? I've heard that 100LL doesn't have this problem, due to the toxicity of Tetraethyl Lead. Perhaps occasional use in the Gerry cans would disinfect 'em? Any advice much appreciated! Thanks in advance... EGM |
I've used autofuel for about 15 years now & have never seen any
contamination in it, or from it, at all. There is lots of gasahol around here so I have to check each load with the water absorption test to detect if there is any alcohol present, unless I can buy it at an FBO. I assume MTBE can be smelled. It is almost universal here in the midwest. I have metal tanks though. |
Folks, I have a C-182 with an auto-fuel STC, which I've been operating on Mogas (along with an occasional fill of 100LL) for several years. Mogas being unavailable at my home airport, I use a pair of 6 gallon Gerry cans (plastic) to transport the fuel from a local gas station to the airplane. I've taken the usual precautions to keep dirt and moisture out of the Gerry cans but lately encountered something a bit unexpected: as I was preparing to fill the cans, I happened to glance inside one and noticed several patches of what appeared to be mold or fungus. These were dark brown in color, from 1/8 to 1/2 inches in diameter; there were 4 to 7 or so of these on the bottom inside surface of each can. Has anyone else encountered this, and have any ideas on how such contamination can be prevented? Beyond the obvious concern of fuel line blockage from this stuff (I've since started filtering the fuel when I transfer it the cans to the airplane), I'm worried the plane's entire fuel system may be contaminated. (I peered inside my Bladders with a flashlight but can't see enough to tell anything.) Is there any sort of anti-microbial additive that can be used with Mogas, that can "disinfect" my Gerry cans and/or fuel system? Does this problem exist with metal containers, or just peculiar to the plastic cans? Yes, I had green slime grow all over the inside of the carburetors on my motorcycle one time when I stored it for 18 months and forgot to drain the carbs. The best way to prevent this is to not store gas for along periods of time (6 months or so). The next best thing is to use a gasoline preservative such as Stabil. However, I don't know if Stabil is approved for airplane use. I've used it for years in my motorcycles, lawmowers, chainsaw, snowblower, etc., with great results, but that doesn't mean it is OK for aviation use. Matt |
Okay, since no one really could say, he is correct, mogas can support
a fungus. You need to filter, filter and more filter. On Wed, 10 Nov 2004 09:34:54 GMT, Economic Girly Man wrote: Folks, I have a C-182 with an auto-fuel STC, which I've been operating on Mogas (along with an occasional fill of 100LL) for several years. Mogas being unavailable at my home airport, I use a pair of 6 gallon Gerry cans (plastic) to transport the fuel from a local gas station to the airplane. I've taken the usual precautions to keep dirt and moisture out of the Gerry cans but lately encountered something a bit unexpected: as I was preparing to fill the cans, I happened to glance inside one and noticed several patches of what appeared to be mold or fungus. These were dark brown in color, from 1/8 to 1/2 inches in diameter; there were 4 to 7 or so of these on the bottom inside surface of each can. Has anyone else encountered this, and have any ideas on how such contamination can be prevented? Beyond the obvious concern of fuel line blockage from this stuff (I've since started filtering the fuel when I transfer it the cans to the airplane), I'm worried the plane's entire fuel system may be contaminated. (I peered inside my Bladders with a flashlight but can't see enough to tell anything.) Is there any sort of anti-microbial additive that can be used with Mogas, that can "disinfect" my Gerry cans and/or fuel system? Does this problem exist with metal containers, or just peculiar to the plastic cans? I've heard that 100LL doesn't have this problem, due to the toxicity of Tetraethyl Lead. Perhaps occasional use in the Gerry cans would disinfect 'em? Any advice much appreciated! Thanks in advance... EGM |
Mike Rapoport wrote: I've never heard of anything being able to live in gasoline. I wouldn't have thought so either, but apparently it *is* possible: http://www.chevron.com/prodserv/fuel...tm#cleanliness At any rate, thanks to all who responded to this thread. Got some good ideas to help solve this particular problem. Good flyin'... EGM |
