Preheat
Old November 11th 04, 08:36 PM
Fastglasair
Thanks for the update. What engine is this installed on?
IO-360-C1D6 Lycoming angle valve .
Old November 11th 04, 09:14 PM
On 10-Nov-2004, tony roberts wrote:
CHT's of 500/600 degrees? Definitely not.
I presume he meant Fahrenheit, since he made reference to atmospheric temps
in F. 350 C = 572 F.
-Elliott Drucker
Old November 11th 04, 10:15 PM
Ron Rosenfeld wrote in message . ..
A friend corroded the cylinders on his Cardinal from continuous
heating in just one winter. The water/acid boiled off the oil and
condensed in the cylinders on the bottom side. I understand Tanis
says that won't happen since they also have cylinder heat, but I'd be
more than a little scared of it still happening. If nothing else
minimize the preheat as much as convenient.
Lycomings especially need preheat to keep the cam from scoring. The
problem isn't bearings, it is all the expensive-to-repair surfaces
like cylinders and camshaft/lifter surfaces that depend on a fog of
oil for lubrication. Unfortunately if you push your luck on a cold
start, the fog isn't developed for some time as the oil that blows
over the relief valve has little access to the heat of the engine.
After it warms up and sprays from the bearings etc, it does.
Old November 11th 04, 10:48 PM
Jay Honeck
temps
Cylinder head temps in that range are not recommended.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 12th 04, 06:56 PM
Sounds like he had a defective heater. They shouldn't be gettings
things above 212F which would be needed to boil off water or acid.
Strictly speaking, as you point out, the term "boiled off" was probably in
error. However, the point that moisture will be released as oil is heated
is not. If water is being held in suspension, heating the oil and the air
in the sump will cause some of that water to evaporate, and it may then
condense on cold surfaces. It's like when you blow on cold glass. The
moisture in your breath will condense and fog the glass, but your body temp
is surely well below 212 F. The acid he speaks of is probably dissolved in
the suspended water.
-Elliott Drucker
Old November 12th 04, 10:40 PM
Matt
Water vapor will slowly come off at much lower temperatures. All it
needs is to condense on something cooler than the oil. I don't recall
if he had crankcase heating only, or if he had cylinder heat too. I
recall the jug sitting above his desk at work, very thoroughly
corroded on the bottom in one winter.
Old November 12th 04, 10:55 PM
Getting oil to flow easily is only one part of the problem. As you note,
this can be "solved" with a multi-viscosity oil.
But another important factor is the clearance between the pistons and
cylinders (or, more specifically, between the steel and aluminum parts of
the engine). Because of the differential expansion/contraction of the
different metals, at cold temperatures, clearance may be non-existent, so
there is markedly increased wear until the engine gets above some critical
temperature.
The differential expansion of aluminum vs steel is 6 microinches per
inch per degree F. Minimum bearing clearance is about .002 inch which
would take roughly 140 degrees of chilling to fully close up.
Probably even greater temps are needed for the cylinders to close up.
It is certainly a significant factor, but the reduced main and rod
bearing outflows (which goes as the cube of the clearance and
inversely as the viscosity) is also a reason there isn't much spray
inside a cold crankcase. All of these factors work against you,
especially on a new or fresh majored engine having minimum clearances.
Multi vis oils certainly help. Conversely having a summer weight oil
greatly increases the need for thorough preheating.
I use 32 degrees as a cutoff with 15W50, higher if it has been sitting
for more than a week. Below that I get an oil pump cavitation whine
on initial start on an O-320 E2D.
Preheat / Pre-Oiler Fastglasair Home Built 6 November 13th 04 05:40 AM
BRAC - The Preheat Mode Yofuri Naval Aviation 17 May 24th 04 12:47 PM
Cold Starts Viperdoc Owning 66 February 26th 04 08:51 PM
PIREP - Reiff Preheat Systems Joe Young Owning 19 December 14th 03 06:38 PM
