First 100 hours
Old November 22nd 04, 04:41 PM
Jim Burns
Default First 100 hours
We've put our first 100 hours on our Aztec since buying it mid-August and
this weekend we had the 50hr and 100hour AD's complied with. Fuel leak
inspection (50hrs, pilot can do this one), Fuel valve/cable inspection,
Engine mount inspection, Exhaust system inspection. Everything looked good.
Since we bought it, we've upgraded the KLN 89B to a KLN 94 and had it IFR
certified, replaced one vacuum pump and installed vacuum pump cooling
shrouds via a FAA field approval, braced the oil coolers and fixed the leaky
baffles, re-insulated the nose and heater compartments, installed the Piper
elevator bungee kit, replaced the occasional old vent or drain hose,
replaced a bad pitot heat switch, replaced the cabin door lock, and bought a
set of new 8 ply main gear tires.
We had to pull the pitch control computer from our STec 60-2 due to run away
trim in altitude hold mode, it's still out for repairs.
The next project on our list is a new one piece windshield, maybe a vertical
card compass and electric OAT.
On short hops of 1 hour or less we're seeing fuel burns of 20 gallons per
hour, longer hops we see 24 gallons at 24 squared and 155kts true. Push
everything forward and we see 175 knots true at around 6000 ft and fuel
burns of 27 gallons per hour. Surprisingly close to book numbers for a 38
year old airplane.
So far we're pretty happy with our bird.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.799 / Virus Database: 543 - Release Date: 11/19/2004
Old November 23rd 04, 04:26 AM
Jay Honeck
Congrats, Jim. Sounds like a great plane!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 23rd 04, 05:16 PM
year old airplane.
So, at the high end of the power/fuel consumption curve you are gaining 20
kts TAS for only 3 gph? That's incredible! In my relatively efficient
Arrow I gain only about 6 kts TAS for about 2 GPH going from 65% to 75%
power. How do you do it?
-Elliott Drucker
Old November 24th 04, 03:00 PM
Mike Rapoport
news:nfKod.2604$6m2.1574@trnddc04...
38
year old airplane.
-Elliott Drucker
27GPH-20GPH=7GPH
Old November 24th 04, 03:24 PM
Matt Whiting
38
year old airplane.
-Elliott Drucker
27GPH-20GPH=7GPH
No, the 20 GPH was on short hops and no speed is given. 24 GPH is
listed along with the 155 speed vs. 27 for 175. I'm with Elliott, this
defies physics. This is almost exactly a linear increase, but we all
know that drag is not linear with airspeed.
Matt
Old November 24th 04, 03:49 PM
Scott Skylane
38
year old airplane.
-Elliott Drucker
27GPH-20GPH=7GPH
Huh!?! Are my eyes funny, or doesn't his original post reference *24*
GPH at 155 kts vs. 27 GPH at 175 kts?
inquiring minds...
Scott Skylane
Old November 24th 04, 04:00 PM
Mike Rapoport
"Scott Skylane" wrote in message
per
38
year old airplane.
20
-Elliott Drucker
27GPH-20GPH=7GPH
Huh!?! Are my eyes funny, or doesn't his original post reference *24* GPH
inquiring minds...
Scott Skylane
You're right. I guess it is my eyes which are out of whack. They saw
20GPH which is the "short hop" number. Now the numbers make even less sense
since I would normally expect to see "short hop" fuel flow higher than the
"longer trip" fuel flow and he is also claiming a 13% increase in speed with
a 13% increase in fuel flow. I suspect that he uses the mxture lever on
some flights but not others
Mike
MU-2
Old November 24th 04, 04:44 PM
Jim Burns
You're right. I guess my numbers are out of whack!
I ran though them from memory, which is normally good, but sometimes very
short.
They saw
This is what we are seeing on 1 hour flights with only one take off and
landing. Multiple take offs and landings, then numbers get lower due to
more time at reduced power. We've actually seen numbers down around 16 for
pattern only work.
I looked up a round robin flight of 2.1 hours each way, power settings I
recorded were 24/24 and fuel tickets showed 90 gallons, so I had one too
many 24's in my head, that figures out to 21.4 gallons at 155 True.
Longer trips we've been flight planning at 25gph and it's hardly ever that
high at normal cruise settings. Speed runs at 175 kts burns 27.
So, I believe that we are getting a 13% increase in speed for a 26% increase
in fuel burn.
Thanks for makeing me look that up and correcting it. One problem we have
is the old fuel flow meters are wayyyyyyyy off towards the high side, which
I guess may be on the safe side.
Old November 24th 04, 07:25 PM
Mike Rapoport
"Jim Burns" wrote in message
short.
They saw
for
pattern only work.
increase
in fuel burn.
which
That is because the "fuel flow" guage in a Piper is really measuring fuel
pressure and displaying it in GPH. It is not a true fuel flow system. On
my Turbo Lance, I had a Shadin fuel flow system and it was dead accurate
while the stock guage always showed much higher numbers.
Mike
MU-2
Old November 24th 04, 08:11 PM
Newps
year old airplane.
I have a friend who until a month ago had a turbo Aztec. Biggest toilet
I have ever seen. Numerous engine failures in icing conditions, turbos
that break down with regularity, heaters that don't work, gear that
won't go down, or up; the list is endless. I asked him why he didn't
buy a Baron in the first place and he said he couldn't afford it. I
told him you've already bought a new Baron that came in the shape of an
Aztec. He finally did the math and came home with an Aerostar the other
day. Now some poor sap has this Aztec to deal with.
fighter pilot hours? Cub Driver Military Aviation 26 September 15th 05 02:39 AM
D-DAY: START ENGINES 0412 HOURS ArtKramr Military Aviation 5 June 7th 04 05:08 PM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 02:54 AM
