Lyc. O-360 cylinder question
Old November 25th 04, 09:15 AM
Scott Skylane
Newps wrote:
Mike Spera wrote:
Overhauling cylinders is a crap shoot, even more than new ones. Think
about this, if even ONE goes bad, your economics are shot. The delta
between new and overhauled cylinders is not big enough.
I don't know what your prices are but here an overhauled chromed
O-470/520/550 cylinder is $350 vs a new cost of approx $1100.
Newps,
I suspect you are comparing an overhauled "stud assembly" vs. a new
"complete assembly". Hardly "apples to apples".
Happy Flying!
Scott Skylane
N92054
Old November 27th 04, 09:32 PM
G.R. Patterson III
JB wrote:
Well there's my answer... no -R on the serial, it's a factory o/h
then. I'm still thinking about what to do with the jugs; I know the
prices of new ones have come down quite a bit, with jugs from ECI and
Superior going for around $900-1100 or so, but still... if these are
first run cylinders with 1660 hrs, and the engine was running great
when removed; there's probably lotsa life left in 'em after an
overhaul, and I'd get to save several hundred bucks per jug.
According to their ads, Lycoming replaces the cylinders with new when they
overhaul an engine.
George Patterson
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Compression loss on cylinder when rings line up Truth of fiction? test it Home Built 10 May 11th 04 08:11 PM
#5 cylinder not firing David R. Owning 13 February 27th 04 12:41 PM
'Hot' cylinder after overhaul? Tony Cox Owning 8 August 10th 03 07:25 PM
