Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aerobatics
Pitt wings
Old October 23rd 03, 06:40 PM
Al MacDonald
Default Pitt wings
Greetings,
I'm looking at purchasing a good used Pitts S-1D with "C" wings. I can't
imagine why anyone would make this combination but I'm thinking it will keep
me on the learning curve for quite some time anyway. I've read the
difference between the "C" and "D" wings are an extra set of ailerons, which
increases the roll rate from about 180 to 220 degrees/second, and so
theorized that the top wing could one day be modified to accept another set
of ailerons. Do any of the Pitts drivers know if this could be easily done?
Failing that idea I'm thinking perhaps I could build a set of "S" wings one
day if they would fit the "D" fuselage, and if so, would that make the Pitts
into an S-1S, or is this simplistic thinking? Fire away.
Allan MacDonald
Old October 24th 03, 06:03 PM
ShawnD2112
Just buy one with 4 ailerons. After about 20 hours the roll rate will seem
slow enough as it is...
Shawn
"Al MacDonald" wrote in message
news:FoUlb.39420$i92.467@clgrps13...
Greetings,
keep
which
set
done?
one
Pitts
Allan MacDonald
Old November 4th 03, 06:40 AM
Charon
I don't think you can modify C wings to extra ailerons. Seems the
span was different, etc. C wings aren't worth much, on the other hand
they're nice and light and the plane climbs well upright. If the
Pitts is only a 150 hp then it will be just a fun little plane the way
it is. if you really want an S1S, just buy one now. It will be far
cheaper than buying the S-1C now plus building another set of wings
later.
"ShawnD2112" wrote in message ...
Shawn
Greetings,
keep
which
set
done?
one
Pitts
Allan MacDonald
