On Tue, 04 Jan 2005 17:50:27 GMT, "Peter MacPherson"
wrote: Their website shows that at least the Baron, 210 and Caravan can be certified for known ice. There's probably others. http://www.flightice.com/contact.html Cool, thanks! |
Just out of curiosity, if the system works well, what is the added value of
being "known ice" certified? The only thing I can think of is, if you get into an accident, they could say "you flew into known icing without being equipped, blah blah." But if the scuttlebutt that TKS works better than boots is to be believed (plausible, certainly) then odds are that you would still have gotten into the accident with boots, and the FAA could still say, "you should have gotten out of there the minute you realized how bad the ice was" and ding you anyway. Now I can understand the downside of a system like that on the Cirrus which has only a 30-minute reservoir for the de-icing fluid, but if you have a 4-hour tank, then why should you really care? Up here in the Northeast in the winter everybody files to fly through areas of known ice in planes that can't be equipped for it (e.g. a Skyhawk) and unless you end up in an emergency nobody appears to care, it's caveat aviator all the way. And in any case, a non-known-ice TKS system would be a meaningful improvement over his old 310 with nothing, at least until you run out of juice. -cwk. "Peter MacPherson" wrote in message news HACd.848205$8_6.586133@attbi_s04...Their website shows that at least the Baron, 210 and Caravan can be certified for known ice. There's probably others. http://www.flightice.com/contact.html "Nathan Young" wrote in message ... On 4 Jan 2005 07:15:18 -0800, "Robert M. Gary" wrote: In general, I'd try to stick with TKS deicing system. Boots are always troublesome because they can leak and only protect a very small amount of the wing at the leading edge. The TKS system drips deicing fluid all the way down the wing. There are several known-ice certified TKS installations. Do any of the aftermarket TKS installs have K-Ice approval? Last time I checked (a while ago) they did not, which is a shame, because every pilot I have talked to that has flown with TKS says the ice buildup is non-existent and way better than boots. |
Nathan Young wrote: On 4 Jan 2005 07:15:18 -0800, "Robert M. Gary" wrote: In general, I'd try to stick with TKS deicing system. Boots are always troublesome because they can leak and only protect a very small amount of the wing at the leading edge. The TKS system drips deicing fluid all the way down the wing. There are several known-ice certified TKS installations. Do any of the aftermarket TKS installs have K-Ice approval? Last time I checked (a while ago) they did not, which is a shame, because every pilot I have talked to that has flown with TKS says the ice buildup is non-existent and way better than boots. Mooneys with the TKS system installed by Mooney in the factory are certified known ice. If you have TKS install the system later, its not known-ice. -Robert |
Colin W Kingsbury wrote: Just out of curiosity, if the system works well, what is the added value of being "known ice" certified? Legal is one reason. Another is that there is more to "Known Ice" than deicing equipment. Once classic example was a Mooney 201 with full TKS that crashed because its fuel vent froze over. The Mooney 231 (the first year of known-ice cert) has a different fuel vent system. Now I can understand the downside of a system like that on the Cirrus which has only a 30-minute reservoir for the de-icing fluid, but if you have a 4-hour tank, then why should you really care? Even the guys flying Citations don't hang around in the ice for 4 hours. Its just enough to get you through that altitude to another one. Many of the known-ice planes are turbo'd. The known-ice is just a good way to climb up through the ice into CAVU air above. The FAA send out a letter to ownes of known-ice planes a couple years ago telling them not to hang out in icing conditions. Many known-ice owners (like Richard Collins and Mac McMillon of "Flying" rag) though it was funny the FAA even mentioned that. -Robert |
How often do guys like us fly to airports that sell Jet-A though? The
article that "Pilot" wrote up mentioned that most U.S. orders were for the Cont. engine version. I guess in the E.U. jet-A is more common. -robert |
Non-known ice TKS does not nessesarily work better than a KI approved booted
system. The TKS covered portion of the airplane may be fine but there may be other problems like fuel vents icing up. Known ice certification is granted after testing not just installing a bunch of parts. The advantage of having a KI appoved system in addition to being tested is that you can take off into actual or forecast icing conditions legally. Mike MU-2 "Colin W Kingsbury" wrote in message k.net... Just out of curiosity, if the system works well, what is the added value of being "known ice" certified? The only thing I can think of is, if you get into an accident, they could say "you flew into known icing without being equipped, blah blah." But if the scuttlebutt that TKS works better than boots is to be believed (plausible, certainly) then odds are that you would still have gotten into the accident with boots, and the FAA could still say, "you should have gotten out of there the minute you realized how bad the ice was" and ding you anyway. Now I can understand the downside of a system like that on the Cirrus which has only a 30-minute reservoir for the de-icing fluid, but if you have a 4-hour tank, then why should you really care? Up here in the Northeast in the winter everybody files to fly through areas of known ice in planes that can't be equipped for it (e.g. a Skyhawk) and unless you end up in an emergency nobody appears to care, it's caveat aviator all the way. And in any case, a non-known-ice TKS system would be a meaningful improvement over his old 310 with nothing, at least until you run out of juice. -cwk. "Peter MacPherson" wrote in message news HACd.848205$8_6.586133@attbi_s04...Their website shows that at least the Baron, 210 and Caravan can be certified for known ice. There's probably others. http://www.flightice.com/contact.html "Nathan Young" wrote in message ... On 4 Jan 2005 07:15:18 -0800, "Robert M. Gary" wrote: In general, I'd try to stick with TKS deicing system. Boots are always troublesome because they can leak and only protect a very small amount of the wing at the leading edge. The TKS system drips deicing fluid all the way down the wing. There are several known-ice certified TKS installations. Do any of the aftermarket TKS installs have K-Ice approval? Last time I checked (a while ago) they did not, which is a shame, because every pilot I have talked to that has flown with TKS says the ice buildup is non-existent and way better than boots. |
I have a Baron with the known-ice TKS installation (non Known Ice
installation was not available as an option) The stuff works as advertised- you simply do not accumulate ice, although I had an encounter near Lake Michigan where the windshield iced over completely. Even with the spray bar and max defroster it still picked up ice and got covered. I was thinking about how to land the Baron like a tail dragger by using peripheral vision and looking out the sides, but the ice fell off and I was able to see fine. Without the deice equipment I would have been in big trouble. The known ice certification includes redundant pumps on the wings and windshield, and requires a heated pitot and stall warning vane, along with an ice light. It works great, but in my opinion is not a good reason to go droning along in icing conditions for hours at a time. Rather, it gives you more time to consider options like climbing, turning, descending, or otherwise leaving the icing conditions. Overall, it has really expanded the comfort level for using my plane in the winter, particularly living on Lake Michigan, which I would never cross unless I was in a twin or a kerosene burner and had ice protection. "Peter MacPherson" wrote in message news HACd.848205$8_6.586133@attbi_s04...Their website shows that at least the Baron, 210 and Caravan can be certified for known ice. There's probably others. http://www.flightice.com/contact.html "Nathan Young" wrote in message ... On 4 Jan 2005 07:15:18 -0800, "Robert M. Gary" wrote: In general, I'd try to stick with TKS deicing system. Boots are always troublesome because they can leak and only protect a very small amount of the wing at the leading edge. The TKS system drips deicing fluid all the way down the wing. There are several known-ice certified TKS installations. Do any of the aftermarket TKS installs have K-Ice approval? Last time I checked (a while ago) they did not, which is a shame, because every pilot I have talked to that has flown with TKS says the ice buildup is non-existent and way better than boots. |
But a KI TKS system is better than a KI booted system.
"Robert M. Gary" wrote in message ups.com... How often do guys like us fly to airports that sell Jet-A though? The article that "Pilot" wrote up mentioned that most U.S. orders were for the Cont. engine version. I guess in the E.U. jet-A is more common. -robert Virtually every airport I fly to has Jet-A. All the towered airports in the caribbean have it, and many non-towered have it as well. Besides, how far do you have to go to find Jet-A? And considering the price difference, it sure is worthwhile. |
Robert M. Gary wrote:
How often do guys like us fly to airports that sell Jet-A though? The article that "Pilot" wrote up mentioned that most U.S. orders were for the Cont. engine version. I guess in the E.U. jet-A is more common. -robert Considering that the vast majority of the non-training helecopter fleet is turbine, I would say that Jet-A is actually very common. Guys like us may not notice much though as we don't use it. -- Frank Stutzman Bonanza N494B "Hula Girl" Hood River, OR |
| CAAC in China had approved below 116kg aircraft sold in China without airworthiness cetificate | Luo Zheng | Home Built | 0 | June 27th 04 04:50 AM |
| Donald Campbell Bluebird helmet sold | Aerophotos | Military Aviation | 1 | May 3rd 04 06:11 PM |
| Japanese firm sold Libya uranium conversion plant | Dav1936531 | Military Aviation | 2 | March 17th 04 04:47 PM |
| Sold out by IFR | Mike Rapoport | Instrument Flight Rules | 129 | February 9th 04 11:47 PM |
| Sold out by IFR | Mike Rapoport | Owning | 126 | February 9th 04 11:47 PM |
