intergrandular corrosion of wing spar
Old January 15th 05, 10:24 PM
ChrisH
Default intergrandular corrosion of wing spar
My A&P has dignosed this condition on my 1964 (Piper)PA28-140. Has
anyone dealt with this? Can the wings be repaired or rebuilt? Is there
a good source for spare wings? I'm in North Carolina.
Thanks,
Chris Hight
N6414W
JQF
Old January 16th 05, 01:29 AM
kage
It will be far less expensive to purchase a set of used servicable wings,
than to re-build yours. Subscribe to Trade-A-Plane:
http://www.trade-a-plane.com/index.shtml
Karl
"ChrisH" wrote in message
Thanks,
Chris Hight
N6414W
JQF
Old January 16th 05, 05:29 PM
Nathan Young
Thanks,
What does intergrandular corrosion mean? Sounds like a medical
condition.
You should check with Wentworth Aircraft on spare wings. I have also
seen them on eBay.
-Nathan
Old January 16th 05, 06:11 PM
jls
"Nathan Young" wrote in message
Thanks,
condition.
seen them on eBay.
-Nathan
It's some pretty bad stuff. But it's 'intergranular.' No 'd' in it if
you want to google and read about it, it means that the corrosion involves
the grain boundaries of the aluminum alloy.
Old January 16th 05, 07:19 PM
Orval Fairbairn
Thanks,
condition.
seen them on eBay.
-Nathan
In worst case, you can crumble the aluminum with your bare fingers. The
most prone alloys are 7075 and (non-clad) 2024, due to their high
magnesium content. Moisture is the big enemy here, as it promouet
surface corrosion, which then attacks the grain structure of the
aluminum alloy.
The only solution is to replace the offending part.
Old January 17th 05, 02:07 AM
Robert M. Gary
Does stuff like Corrosion X help prevent it?
Old January 17th 05, 04:16 AM
Jay Honeck
A good friend of mine went through this exact problem with his 140. It is
not a good deal.
As others have pointed out, it is a non-repairable problem -- the wing spars
cannot be replaced economically. The only fix is to replace the wings, and
that is not cheap.
My friend's experience was a long series of nightmarish problems with
unforeseen consequences (One example: The first set of replacement wings he
found were crushed in shipping, and the shippers refused to pay to replace
them.), and the plane was "down" for well over a year.
You've really only got two choices: Part the plane out, or fix it. If you
want to fix it, call Wentworth, bite the bullet, and pay their ridiculous
price for serviceable wings. Have them ship the wings directly to your A&P,
and get it done as quickly as possible. Having watched this ordeal from
afar, it seems that attempts to find alternate sources for wings will end up
taking far longer, and cost far more, than you expect, and the aggravation
factor is not to be underestimated.
Good luck.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 17th 05, 05:53 AM
Stealth Pilot
On 16 Jan 2005 18:07:39 -0800, "Robert M. Gary"
no
because the corrosion is actually occuring between the metallic
components of the alloy deep below the surface.
in 2024 the copper and aluminium can react together.
anticorrosives applied to the surface cant get near it so they are
ineffective.
dont feel too special even boeing airliners have had expensive spar
repairs because of it. piper cherokee flap ribs are quite susceptible
to it.
if you ever take a little tap hammer and tap along a spar web surface
and hear the sound change for no apparent reason you've probably found
intergranular corrosion. (thats how the boeing corrosion was found)
Stealth Pilot
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 08:40 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
FS: Wing spar angle extrusions Bob Kuykendall Home Built 0 September 25th 03 08:23 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
Wing Extensions Jay Home Built 22 July 27th 03 12:23 PM
