What engine would you like?
Old January 20th 05, 06:13 PM
Default What engine would you like?
What would be the ideal configuration for an aircraft engine, given
contemporary technology?
1. Start at 0 degrees F with no fuss?
2. Water cooling for dependable cabin heat?
3. Automatic mixture control for altitude & power?
4. Automatic timing control?
5. Jet fuel (availability)?
6. Piston (for economy)?
7. Choice of RPM at cruise for same power?
I believe that delivering brand new airplanes with 1940s engines makes
no sense whatever.
Old January 20th 05, 06:30 PM
Steve C
Sounds like you are describing the Thielert turbo diesel.
Old January 20th 05, 07:05 PM
Colin W Kingsbury
no sense whatever.
Have you ever owned an airplane with an exotic engine that no one knows how
to repair and parts have to be ordered from the other side of the ocean?
-cwk.
Old January 20th 05, 07:57 PM
I like this one:
http://www.predatoraviation.com/
Old January 20th 05, 08:44 PM
Dave S
no sense whatever.
While my response is more appropriate to the homebuilders forum, I
would have to say that an engine based upon the rotary engine concept
would meet many of those goals:
There are dozens flying now with engines that are either wholly or
loosely based on the Mazda 13B and 20B rotary engine cores. Mistral (in
Europe) is bringing out a rotary engine/PSRU combination that will
support a dual alternator and a constant speed prop. All of these
engines are oil and water cooled. I say oil cooled only because the oil
takes on a larger cooling burden in relation to a typical "auto" conversion.
With the exception of the Mistral, however, there are not any
firewall-forward installations for sale out there YET. Again, this is
where the reponse it more tuned to the amatuer built owners, rather than
the certified crowd. I realize that the vast majority of pilots want
to fly, not build.. and either lack the time, funds or inclination to
take on a custom engine project, and the required tweaking that will ensue.
That being said, a friend and I are building a Velocity, with a
powerplant consisting of a Mazda 13B "turbo" core engine. The driveshaft
will develop in excess of 200 hp with an attached gearbox dropping the
prop speed to around 25-2700 rpm. Hot oil, rather than water, will be
the source of cabin heat (per plans from Velocity). The PSRU we are
using will be able to operate on autogas or 100LL, as well as any
forseable gasoline product that will be used in the near future. Inital
operations would use unleaded fuel during the fine tuning of the
electronic ignition/advance, since an oxygen sensor is used for those
trials.
Maintenance in the amatuer built arena tends to be the bastion of
owners, but since this engine is heavily based on the Mazda designed
engine, spare parts can be obtained from any mazda dealer in the US, as
well as from specialty shops in the US as well as abroad. I am forseeing
a "maintenance pack" that will consist of the required tools to
completely remove and tear down the motor in an unimproved locale - a
few metric sockets, a torque wrench, breaker bar, some picks, etc. These
engines in the race setting have literally been torn down and rebuilt on
a 5 gallon bucket at the track. This isn't a lot of weight, and in fact
may constitute some of the ballast our airframe may require.
Sorry for the ramble.. and.. by the way.. the wankle concept of rotary
engines is 40's technology too.. but no valves, no camshafts, 3 moving
parts (not counting seals/springs). Water cooled means you can have
tighter tolerances, better efficiency..
Dave
Old January 20th 05, 08:57 PM
Dave Stadt
no sense whatever.
It makes us with 1940s airplanes feel kinda spiffy.
Old January 20th 05, 09:10 PM
Darrel Toepfer
I like this one:
My mid '60's Cessna 4 seat airplane didn't cost that much...
Old January 21st 05, 10:00 AM
Thomas Borchert
Bob,
if it ain't broke...
Well, fly it for another 300 to 400 hours and it will be.
Thomas Borchert (EDDH)
Old January 21st 05, 12:20 PM
Bob Noel
I'm figuring to get a bit more than 300 to 400 hours on my engine.
Bob Noel
looking for a sig the lawyers will like
ROP masking of engine problems Roger Long Owning 4 September 27th 04 07:36 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 01:41 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
