Engine Preheater - any good?
Old January 30th 05, 02:02 AM
Matt Barrow
"Rosspilot" wrote in message
. After 3 hours, it's ready
to go.
3 Hours? Way too long.
I still use (and love) my trusty Red Dragon.
Last Friday it was 6 degrees when I had to do a shoot . . . preheated for
an
hour and ready to go . . . warm as toast.
I believe such products (this thing, Reiff, Tanis) are for over-night warm
ups, not spur of the moment.
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Old January 30th 05, 02:37 AM
Jon
Bob,
I'm not sure why you wouldn't want to install a preheat system on the
airframe.. Our shop has installed 15 or 20 in the last few years with
7 or so being Reiff's. We have never had one go bad (Except the one we
installed wrong!). For the $100 or so dollar more it cost you get a
great product without ANY hassle. Just plug it in.
I have read the notes about the Wal-mart and Kmart heaters but what do
you do one the ramp away from home? With the wind up above 20kts or so
I would like it's hard to use something you have to setup each time you
wish to use it.
If you choose to have something installed let your shop order it they
can make a little money and you pay the same price. It should take
about 2.5 hours to install and do the paper work.
Jon
Old January 30th 05, 04:12 AM
George Patterson
Jim Rosinski wrote:
The item in question appears to be an electric space heater you could
buy at Kmart, Target, etc. for $20, with a couple of hoses attached to
fit in the cowling of an airplane.
If it's really putting out air at 190 degrees, it's not any heater you can buy
at a retail outlet. A claim is also made that it has a thermostat that will
regulate the unit. The thermostats on typical heaters designed for home use
measure the ambient temperature of the air in the room, not the temperature of
the air flowing through the unit. This is, of course, a function of the location
of the thermostat, but someone had to do some design work here.
Seems to me to be somewhat more effort involved than just putting together a few
off-the-shelf parts.
George Patterson
He who marries for money earns every penny of it.
Old January 30th 05, 05:53 AM
Jim Rosinski
Matt Barrow wrote:
THEN DON'T BUY IT. Rather, why don't you buy some space heaters from
Wal-Mart and some ducted hoses and sell them for $50? Come on...why
don't you?
Because I don't want to.
Oh, the Rube Goldberg's of the world!!
Rube Goldberg's what?
The only rip-off is the prices for parts/equipment mandated by
the FAA standards (i.e., seat belts that cost ten times more than
for automobiles, even though they are the exact same thing.
So NOTHING in aviation outside of FAA mandates is a ripoff? You
might want to rethink, or rephrase, those words.
You might want to think of the word "voluntary".
What does that non-answer have to do with anything I said?
Jim Rosinski
Old January 30th 05, 06:29 AM
Jim Rosinski
you can buy at a retail outlet.
It puts out 500, 1000, or 1500 watts, which oddly enough are the same
power settings as on my Kmart "preheater". A weaker fan will result in
a higher temperature, a stronger fan a lower one. The temperature
itself is meaningless to someone trying to figure out how well this
thing is going to work. Marketing hype.
home use measure the ambient temperature of the air in the room, not
the temperature of the air flowing through the unit. This is, of
course, a function of the location of the thermostat, but someone
Not convincing. The temperature of the air is irrelevant. What matters
is the temperature of the engine and the oil.
together a few off-the-shelf parts.
Maybe you're not cynical enough. Then again, maybe I'm too cynical.
Considering the other options available though (e.g. my cheap-ass
solution, or Red Dragon), $299 is a chunk of change for something like
this.
Jim Rosinski
Old January 30th 05, 12:59 PM
Matt Whiting
don't you?
Because you know that you couldn't make any money selling at that price,
which is the reason that nobody else does it either.
Matt
Old January 30th 05, 01:07 PM
Matt Whiting
Yes, the temperature is meaningless up to a point. If it moves so much
air that the temperature never gets more than 5 degrees above ambient,
then it won't be a very good preheater. However, if the temperature of
the output air is at least as high as what you wish your engine
temperature to be, then it is heat output that matters rather than
temperature of the air.
Yes, but the temperature of the air has an affect on that of the engine
and oil. The air temp has to be AT LEAST as high as what you wish for
your engine.
this.
Yes, it is a chunk of change, so better to build your own. I did that
with a "milk house" heater, some aluminum roof flashing and some
flexible dryer duct. It wasn't pretty, but it did the job for probably
$50 in parts. However, I also probably spent 3 hours of time so when
you factor that in, the commercial units don't look quite so overpriced.
Matt
Old January 30th 05, 01:23 PM
Matt Barrow
"Jim Rosinski" wrote in message
don't you?
No, it's sooooo much easier to **** & moan and throw stones.
A BMW costs $60,000 and doesn't cost that much more to produce than a Honda
Accord: is that a rip-off?
A "rip-off" is something you can't so without or something involving theft,
not something you acquire voluntarily.
Matt
Matthew W. Barrow
Montrose, CO
Old January 30th 05, 03:37 PM
PaulaJay1
In article , "Matt Barrow"
writes:
Why so? I find that my Tannis does a pretty good job after and hour or two.
After all, you don't have to get the engine up to operating temp. If I have
raised the engine temp 20 or 30 deg I have done a lot of good.
Chuck
Old January 30th 05, 06:37 PM
Jim Rosinski
from
on...why
don't you?
I'm neither ****ing nor moaning. For whatever reason I don't know, but
you seem to want to turn a civil discussion into a flame war. The
original poster asked for input on a pre-heater he was considering.
Unfortunately, no one in this forum had any experience with the
specific item he pointed us to. Next best thing is to analyze the
vendor's claims and come up with an analysis. Mine says the item is
probably a ripoff. Others can, and have, disagreed with that
conclusion. I have no problem with that.
Honda Accord: is that a rip-off?
For the moment taking your assertion (implying that profit margins on
BMWs are vastly greater than those on Accords) as fact, I would say yes
the BMW is a ripoff. But then again I'd claim that any item with a
markup due to "yuppie appeal factor" is a ripoff. Just MHO.
theft, not something you acquire voluntarily.
After puzzling over this statement and finally getting it to make some
sense by changing "so" to "do", it says something remarkable. You think
that anyone who purchases anything voluntarily has by definition not
been ripped off. Interesting definition.
Jim Rosinski
Mooney Engine Problem in Flight - Advise Paul Smedshammer Owning 17 December 21st 04 06:39 AM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
