CNX-80 -> GNS-480 upgrade: no longer resets to 1200?
Old February 4th 05, 01:21 AM
Ron Rosenfeld
On Wed, 02 Feb 2005 23:31:04 -0700, Scott D. wrote:
Thanks for the Info. I haven't really checked into the differences
between the two softwares. Is it really a must or is it something
that I can be without?
The upgrade does a number of things. There's a Garmin newsletter regarding
all the changes.
The biggest thing for me is that it enables the CNX80 to output vertical
guidance signals. This will occur not only for LPV and LNAV/VNAV
approaches, but also for LNAV approaches with published advisory vertical
guidance.
In addition, if you use the set outside of reliable WAAS coverage, there is
the facility for disabling WAAS. This would be useful in Europe, according
to Garmin.
There is an additional NAV page which gives an HSI like display.
There is an interface with TIS if you have the appropriate transponder.
Also, there was a SB published a few months ago regarding a potential
problem with overheating and messing with the display. When your box goes
to Garmin for the software upgrade, the appropriate parts will be replaced
to comply with that SB.
There have probably been some other changes, too.
Jepp no longer in the GA business...? John Harper Instrument Flight Rules 30 June 17th 04 10:49 PM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
Some airmen facing longer deployments Otis Willie Military Aviation 0 January 16th 04 08:34 PM
Beech F-33/B-55 panel upgrade or STC Gordon Rich-Phillips Owning 2 January 14th 04 01:28 PM
FS: Upgrade Compaq iPaq H3650 Juan Jimenez Aviation Marketplace 1 October 3rd 03 09:39 PM
