molding plexiglas websites?
Old February 6th 05, 01:02 PM
Dick
George or Richard,
A little off the subject. A fellow at my airport had heard of a method to
remove scratches. It involved plastic, I think acrylic, figurines and a
propane torch heating slightly the scratches to "erase" them. I was
wondering if anyone had any such knowledge.
My yet-to-be installed, 20year old canopy
was lightly sanded with the wrong grit and scratched up both inside and
outside. After researching the methods available to sand/polish them out
and considering greatly differing opinions, I'd like to find another method
short of buying/making a new canopy.
Thanks, Dick
Old February 6th 05, 01:20 PM
George A. Graham
Well, You must know that you can sand out the scratches, and save the
canopy. However, it may be more work than it's worth.
So long as you are prepared to purchase another, and they are available,
why not experiment.
I've seen scratch remover sold for eyeglasses that I'd try first.
I cannot imagine the torch idea leaving a clear view through the
canopy, and removing the waves is as much work as removing the scratches.
George Graham
RX-7 Powered Graham-EZ, N4449E
Homepage http://bfn.org/~ca266
Old February 6th 05, 01:31 PM
George A. Graham
On Sun, 6 Feb 2005, Blueskies wrote:
Details about the oven?
That would depend on the size of the windows.
I made mine out of foil faced rigid insulation board, held into box shape
with duct tape, the handyman's secret weapon. The tape went soft and let
go when heated, so I had to use nails into wood corner strips.
It was four by three by two feet overall. A baseboard heater three feet
long was modified to eliminate the tip-over switch, so that it could
lay flat on it's back on the floor of the oven. I had a thermometer stuck
through the wall, and controlled the heater by unplugging it.
The lid was hinged so that I could peek inside to watch the window.
Certainly disposable.
George Graham
Old February 6th 05, 03:54 PM
Blueskies
"George A. Graham" wrote in message ...
George Graham
Thanks! I've been thinking about a 'curved' windshield for the BD-4...
Old February 6th 05, 07:06 PM
Ron Natalie
richard riley wrote:
On Sun, 06 Feb 2005 02:35:47 GMT, "Blueskies"
etails about the oven? Way back when I formed plexi after heating in a box with about 4 light bulbs...
I've been doing some vacuforming with 1/8" acrylic, using a machine
much like this one...
Years ago I was hanging out with Jackie Yoder and he was explaining how he bent the
lens for his "in the wing" landing lights. Just a plywood box with an old heating
element (I think he said he scrounged it out of a dryer). Takes a few practice
attempts to get it right, but acrylic is cheap.
For those who were arguing the materials: Most aircraft "glass" is acrylic (plexiglas
is a brandname for acrylic). It's not quite as strong, but is easier to work and can
be reheated (theroforming). Some people do use polycarbonate (lexan is a trade name
for that). It's much stronger (bulletproof even), but can scratch badly. It's harder
to work (thermosetting).
Old February 6th 05, 09:26 PM
Orval Fairbairn
"Dick" wrote:
George or Richard,
Thanks, Dick
I have an experiment:
1. Take a piece of Plexiglass scrap and cut it qith a bandsaw.
2. File the big scratches and gouges out of the sawed end.
3. Start wet sanding with #320, then #400, then #600, then #1200, then
#2000 grit, stepping up the grit as smoothness is reached. Wash between
sandings.
4. Take automotive rubbing compound to the edges worked and look for
polished areas.
5. When the whole desired area appears polished, apply automotive
polishing compound. (You can also use tooth powder.)
Use lots of water in all processes.
You can also start with a piece of scratched-up Plexiglass and work
through the same steps.
The end result is a piece of polished Plexiglass with no visible
scratches.
Old February 11th 05, 07:15 PM
Javier Henderson
Jon A. writes:
Who said that? Are you speaking of the legendary owner manufactured
parts myth that has been repeated so many times that folks are proving
it to be true?
What myth is this?
-jav
Old February 12th 05, 01:39 AM
RST Engineering
The myth that 21.302 (b)(2) has been rescinded, which it ain't.
"Javier Henderson" wrote in message
Jon A. writes:
it to be true?
What myth is this?
-jav
molding plexiglas websites? [email protected] Home Built 13 February 6th 05 09:26 PM
Would you like to write about your hobby for one of the UK's top websites? Steve Roche Home Built 0 February 13th 04 10:36 AM
Zenith Ch 701 Builder's info and websites?? DL152279546231 Home Built 1 February 10th 04 08:21 PM
homebuilder websites updated daily? Joa Home Built 6 December 28th 03 07:30 PM
