Painting rivet heads
Old February 5th 05, 08:05 PM
Jay Honeck
Default Painting rivet heads
We just installed the Skycraft landing lights, which meant drilling a
few dozen holes into my beautiful paint job.
Is there ANY way to touch those rivets up with paint that will yield
satisfactory results? I've tried using automotive touch-up paint in
the past, with limited success. I'd like to find something that
actually looks half-way decent.
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 5th 05, 09:15 PM
Orval Fairbairn
In article . com,
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Try masking them off and using an airbrush. I have found that my Badger
woeks quit well with Imron -- and -- you can mix only a teaspoonful at a
time!
Old February 5th 05, 10:58 PM
Jon A.
That's great advice. Will it last? Should it be primed and
everything else that goes along with a good paint job?
On Sat, 05 Feb 2005 21:15:34 GMT, Orval Fairbairn
In article . com,
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
time!
Old February 5th 05, 11:21 PM
Kyle Boatright
For something like a rivet head, I'd just scuff the area immediately around
it with scotchbrite (and we're talking close... 1/8" if you can do it), wipe
it down with a degreaser, mask to your scuff line, then shoot the paint.
Immediately after shooting the paint, remove the masking so the ridge left
by the masking tape will blend in much better.
KB
"Jon A." wrote in message
In article . com,
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
time!
Old February 6th 05, 05:10 AM
Orval Fairbairn
Treat the rivet head just like a piece of bigger aluminum:
1. Clean it with lacquer thinner.
2. Prime with a good 2-part epoxy primer (I like PPG DP-series)
3. Paint with top coat.
The airbrush has several sizes of tip which can give you a good
selection.
It should last as well as the original paint.
In article . com,
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
time!
Old February 6th 05, 02:14 PM
Jay Honeck
selection.
I know nothing about airbrushes. Any recommendations? What do these things
cost?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old February 6th 05, 03:10 PM
Carl Ellis
selection.
cost?
Go to your local hobby store. They should have a small airbrush that costs
around $50-75. You can use commercial "canned air" (available at the hobby
shop) or buy an extra hose to attach to your own recharable source. The
paint jar on these things is pretty small, about the size of a bottle of
model paint.
You can actually do a lot with these brushes. My friend repainted the
struts on his Tcraft with his. Because it's so small you have a lot of
control and won't have much overspray. Practice first!
- Carl -
Old February 6th 05, 07:03 PM
Ron Natalie
selection.
cost?
You can get a decent airbrush for well under $100. I have a little Pasche VL
that comes with three different needle sizes and an assortment of cups (and I
think it even came with a can of gas, which is a pain in the butt for real use
and I normally drive it from an air compresser). I think it runs $65 for the
whole set at a hobby store.
Just be real careful with IMRON (I think we went through this before) especially
when spraying it. Frankly, if you have a steady hand, a small paint brush on
just the heads might work as well.
Old February 6th 05, 08:39 PM
Jay Honeck
Jay Honeck
Iowa City, IA
Pathfinder N56993
m...
selection.
things cost?
Pasche VL
(and I
use
especially
brush on
Old February 6th 05, 09:34 PM
Orval Fairbairn
In article LCpNd.52822$eT5.29890@attbi_s51,
selection.
cost?
You can buy one from Harbor Freight for about $20.
You will also need a good regulator (I have one at the end of the
airbrush hose.)
I have found the airbrush to be perfect for touching up striping and
even painting striping, as you have a lot of control over your work.
As others ahve said, hobby stores also sell them. Badger is a good brand
-- others may prefer different brands.
Who knows -- you may end up painting your own nose art on the plane!
B-17G Original aviation heritage painting [email protected] Aviation Marketplace 1 December 21st 04 12:27 PM
B-17G Original aviation heritage painting jfkuna Owning 0 December 21st 04 06:33 AM
Blasting and painting [email protected] Home Built 7 June 3rd 04 03:14 PM
painting Vicky Stephen N Mills Owning 2 February 3rd 04 12:51 AM
aircraft painting southeast US Dave Butler Owning 7 October 8th 03 04:50 PM
