Recommendations on Lycoming Overhauled/Rebuilt/Remanufacturered?
Old February 10th 05, 11:27 PM
Bob Chilcoat
Default Recommendations on Lycoming Overhauled/Rebuilt/Remanufacturered?
We're beginning to converge on TBO in our '74 Archer. At the rate we're all
flying (four partners) we'll hit 2000 hours next year sometime. Plane uses
a bit of oil, but compressions were OK at last annual (new one is this
month, so we'll see). Engine runs very well at the moment.
At any rate, I'm beginning to collect data on overhaul options. The options
seem to be that we can consider a local shop overhaul, a Lycoming or
national center overhaul, or a "factory reman" from Lycoming or perhaps
Mattituck, Superior or similar. I've heard good things about Penn Yan. Any
hard data out there? Anyone to scrupulously avoid? Strong recommendations?
Thanks. Thoughts on the relative merits of overhaul vs. remanufacture?
Bob (Chief Pilot, White Knuckle Airways)
Old February 11th 05, 12:26 AM
Bob Chilcoat wrote:
snip
options
perhaps
Yan. Any
recommendations?
remanufacture?
I was planning on going for a factory overhaul on my O-360 this
month. While researching this for a few months I found an alarming
number of folks who'd had recent factory overhauls and were slapped
with $3K core charges. In most cases, Lyc. could not supply any
documentation for the charge, but since they already had the customers
money, it was an uphill battle. If you google the rec.aviation groups
for Lycoming and overhaul, I think you'll find a few recent examples.
I kept shopping around and finally decided to go with a Millenium
overhaul from Superior. They have authorized shops scattered around
the country and there just happened to be one at my home base (no
shipping charges!). The kicker in my decision to go with Superior was
their Warranty. 5 years flat out. None of that "prorate to TBO at
40hrs/month" business. One of the larger local flight schools has
bought several of these engines and they are very happy with them.
I'm getting the work done in about 3 weeks, so I'll let you all know
how it turns out.
Old February 11th 05, 12:52 AM
Bob Noel
I was(am) happy with Penn Yan - they did the overhaul of my O-320
in the summer of 2002. Lots of nice touches wrt log entries, complying
with ADs, extra gaskets, good quality leads, etc. The A&Ps that worked
on my airplane were used to a different overhaul company that the
aeroclub used - let's just say their overhauls were a step below the
Penn Yan one. btw - I went with Penn Yan rather than Mattituck because
if the crankshaft had failed the SB inspection, Mattituck would have charged
me several thousand dollars more than Penn Yan.
A friend was perfectly happy with Mattituck when his '75 Archer needed
an overhaul - he went with a swap since Mattituck had one sitting on
the shelf.
good luck.
Bob Noel
looking for a sig the lawyers will like
Old February 11th 05, 01:02 AM
Bob Chilcoat wrote:
snip
options
perhaps
Yan. Any
recommendations?
remanufacture?
I was planning on going for a factory overhaul on my O-360 this month.
While researching this for a few months I found an alarming number of
folks who'd had recent factory overhauls and were slapped with $3K core
charges. In most cases, Lyc. could not supply any documentation for
the charge, but since they already had the customers money, it was an
uphill battle. If you google the rec.aviation groups for Lycoming and
how it turns out.
Old February 11th 05, 01:03 PM
Denny
Just be aware guys that he majority of these shops, local or national,
buy their overhaul parts from Lycoming and the core deposit money is
dependent upon Lycoming accepting your core in exchange... So Lycoming
policy controls whether you get your core deposit back when dealing
with them... Our local FBO found that out the hard way to the tune of
$3000 within the past few weeks... Don't assume anything, get it in
writing from the field overhaul company that their acceptance of your
core is not depepndent upon Lycoming policy...
The exceptions will be a PMA manufacturer like Superior or ECI
accepting your core in exchange for their manufactured parts without
reference to Lycoming policy, but again get it in writing before you
ship the engine...
The other exception will be the factory zero time engine from Lycoming,
where (AFAIK) your core is accepted as is... (yup, get it in writing
first) - and of course a brand new engine which does not require a core
exchange...
Denny
Old February 11th 05, 03:55 PM
Dave Butler
[broken record]
Find a shop that does engine overhauls every day, day after day.
Find a shop that's nearby, so warranty resolution is made easier. The nationally
advertised name-brand shops are fine if they're right next door, but don't ship
your engine far away. Warranty issues are also made more complicated if one shop
does the remove and reinstall, and another does the actual overhaul. Fly your
plane to the overhaul shop and let them do the R&R.
Replace, don't repair cylinder assemblies. The price of a new Lyc cylinder is
very close to the cost to overhaul.
Ask nearby FBOs with rental fleets where they have their overhauls done.
Find a copy of the out-of-print "The Major Overhaul" by Kas Thomas.
Old February 11th 05, 04:38 PM
Doug
Unfortunately there is no "hard" data. No one really knows which type
of rebuild is most reliable or who is the most reliable rebuilder.
From a fundamental principles line of thought, the more parts you
replace the better off you will be. As for warranty, we would all
prefer not to need it.
My take is this, the more you pay the better you get. If you have the
money, get Lycoming new, if not, work your way down from there.
The best cost/benefit seems to be a local rebuild shop (one that
specializes in rebuilds) using your own core. You wont get a zero time
engine, and the warranty will probably not be that great, but your odds
of the engine making it to TBO are pretty good and you have some local
personal contact to work out problems, if they should occur.
Old February 11th 05, 06:13 PM
Ross Richardson
Two years ago I purchased a Lycoming Factory Overhauled O-360-A1A. The
engine is running fine and there was no problems with the core charge. I
believe mine was $4000.00 and it was quickly returned.
Ross
" wrote:
Bob Chilcoat wrote:
snip
options
perhaps
Yan. Any
recommendations?
remanufacture?
how it turns out.
Old February 11th 05, 06:21 PM
Dave Butler
Lyc has started enforcing its core charge policy within the last year or so. If
you have (for example) a cracked case that has been welded, no core credit.
Old February 11th 05, 07:57 PM
George Patterson
There was a thread here recently to the effect that Lycoming no longer refunds
the core charge if the last previous overhaul was not done by Lycoming.
George Patterson
He who would distinguish what is true from what is false must have an
adequate understanding of truth and falsehood.
Lycoming 0-360 factory overhaul core charges - Does Air Powertell the truth ? Mike Spera Owning 6 December 13th 04 01:13 AM
Lycoming remote oil filter Evan Carew Home Built 0 November 5th 04 10:09 PM
IO-360 break-in and oil recommendations? [email protected] Owning 7 August 24th 04 04:54 AM
Lycoming Sued jls Home Built 0 February 13th 04 02:01 PM
Lycoming 320 and EAA Light Sport Aircraft ? Dave Jackson Home Built 29 October 20th 03 01:20 AM
