#41
On Tue, 24 Feb 2004 11:46:41 GMT, "Blueskies" wrote:
Corky, Do you have any details available about your engine test stand, such as how you restrain it, instrumentation, cooling? Also, a buddy of mine was talking about an engine build he did, and how he used water to match each header tube volume, old news I'm sure... -- Dan D. I fabricated the engine stand using a lot of OTLAR measurements. I pulled some 1 1/4" tubing out of the pile (I bought a pile of tubing for a Skybolt kit years ago and still have at least half of it left. I always seem to find enough of what I need for projects like this. I think the cost for the tubing worked out to something like 10 cents on the dollar.) and welded a large rectangle. Then I welded plates on each of the corners and scrounged up four casters from around my shop and drilled bolt holes in the plates and bolted them on. It has two swiveling and two that don't. They are largish,solid rubber commercial casters and I have no idea where I found them originally but I've had them in the shop for years. I didn't pay anything for them, I remember that. Then I duplicated the engine mount rails and bolted them to the engine. I suspended the engine over the base and fitted and welded support legs from the rails to each corner of the base. Removed the engine and welded everything. Then I added 3/4" diagonal tubing fore and aft between the support legs so that the engine could not shift or sway. That REALLY solidified things. What I'd **like** to do is remove the instrument panel from the cockpit and mount it on the stand and use what instruments are necessary to monitor engine performance. That way I don't have to fabricate two instrument panels. I have not cut any holes for instruments yet so that's in the near future. Actually buying some instruments is also in the near future. ;-) I'll need: Oil pressure, oil temperature, tachometer, water pressure, water temperature and an EGT guage. It probably wouldn't hurt to have a cylinderhead temperature guage too. I'm leaning towards digital for the tach and possibly the temps as well but have not made up my mind on which of the numerous choices to use. Or I could just use some scrap plywood since I only need the instruments that monitor engine performance so the test stand panel could be smallish. Or I could cut up some of the 1/8" sheet aluminum from the huge panel I scored for free. Using that stuff takes a lot more work than using plywood though. The radiator is sitting below the engine at present, but I think I'm going to have to move it a bit so that the exhaust system can clear it. The plan is for the exhaust to wrap under and behind the engine and tuck right behind the Griffin radiator, when I get it. But for now, the radiator I picked up from the auto parts place will do the job. It's a Ford Taurus radiator so I know it's adaquate for the task. If I pick up the custom radiator before all is installed back on the airframe, I'll likely fabricate the entire cooling duct system, including the exhaust augmentation, just to make sure the system cools properly. I will leave the engine installed in the fuselage for the moment, so I can fabricate the exhaust and make sure that it fits the airframe properly, then the exhaust will be removed from the engine and the engine transferred to the test stand and the exhaust system re-installed. I'll route hoses to the radiator as necessary and weld on a pan to hold the battery. I'll also have a "gas tank" somewhere on the base of the stand and will have to use a fuel pump to get the gas up to the carburetor, probably a submerged type, or something that goes in-line and I'll just bond on a fuel line out of the gas tank. I've built the stand tall enough that the prop can be mounted to the engine. When I get ready to fire it up, I'll literally have to chain the stand down so that it does not try to hurtle off into the woods like some demented woods buggy run amuck. I may lift the whole thing into the back of the pickup and drive up into the woods to do the extended running so that the neighbors don't complain. I'll strap it down for the trip, and for running it, of course. I'll probably pitch the prop so that the engine can run to it's maximum rpm while on the test stand. This will be necessary because I'll need to make sure the engine can manage full power for extended periods, plus there may be some tuning and adjustments required that show up only at full power. The test stand is roughly patterned after the engine test stands I worked with while training as an auto mechanic at the Rhode Island Trades Shops. Those engines did not have props bolted to them though. If anyone would like to see what the test stand looks like, send me an e-mail and I'll enclose a picture and send it to you. It's in rough form right now, not completed, but I have some shots of the engine bolted in place so you'll get a good idea of what I'm trying to accomplish. Plus, since it's in the unpainted stage, I can still make lots of modifications to it, should anyone have any ideas. Corky Scott |
#42
Bravo! Professor Lamb...
Well done! Well done indeed... Even a simple layman Like myself can understand. Bryan Richard Lamb wrote in message ... Dave Covert wrote: I notice that most auto engine conversions use a gear box between the engine and the prop. Why is that? Is it because an auto engine's peak HP is too high for a prop to swing? Is it because auto engines weren't designed to be pulled around by their crankshafts and don't have proper thrust bearings? Both? Are there any auto/motorcycle conversions that don't require gear boxes? Dave Some people think aircraft engines are "old fashioned technology" and have not kept up with developments in auto engine field. They point out that aircraft engines haven't changed much in over 50 years. Some people feel that auto engines can be used to power airplanes. To some extent, all three of these ideas are true. Aircraft engine do not run like car motors. Aircraft engines run at much higher sustained power settings and constant rpm for long periods of time. And then there is the propeller... Turning the propeller is what it's all about. The propeller converts the engine's power into thrust. As always, when energy is converted, there are losses. Moving through the air at very high speeds, the propeller makes lift (thrust, which is power successfully converted into forward motion) and drag (pure conversion losses). So, propeller efficiency is extremely important. If the propeller is only 50% efficient, half of the power generated by the engine is wasted in losses. Yes, literally. Only one hard rule for propellers - longer is better. But longer blades mean lower RPM because the tips of the propeller blades MUST stay below the speed of sound (yep, Mach 1, really) for any efficiency at all. Part of the reason for this is the huge increase in drag as the tip enters the transonic (speed) region. It takes TORQUE to turn that propeller - not horsepower. A given propeller needs to turn at a given RPM, which will require a given amount of torque. If the engine makes enough torque to turn the propeller at that RPM, a direct drive set up may be possible. There are a lot of other minor details that may get in the way - Harmonic Resonance is a big one. But, it may be possible to run this combination direct drive. If the engine needs to turn at a higher RPM to make adequate power, some kind of gearing would be necessary to reduce engine RPM to propeller RPM. Notice that reducing RPM will increase torque proportionally. Seems like a nice trade off. Now the engine should be running at an RPM near the peak of its' torque curve. This is for best engine operating economy. And the (longer) propeller is running at a comfortable (lower) RPM for good efficiency. Life is wonderful. Except for the weight. Auto engines are seldom as light as possible. Then we add more weight in the form of a gearbox and such. Radiators full of heavy (hot!) fluids. External oil sump? Mounting? Propeller gyroscopic forces operating on the crankshaft? Weight is critical to any flying machine. (Go back and look at how birds are built) So... Think of it as evolution in action. The reason our old antique Lycosourus engines are the way they are is that they evolved into a very narrow niche. They turn propellers to pull airplanes. They make very high torque at very low RPM, and are as light as possible. They are tremendously reliable and fairly efficient. Prices are high because of limited production and high demand. Simple economics. But the economics of engine development (and risk assesment) are anything but simple. I have a big bore VW (2180cc) on my parasol. That's a converted car motor. There is a weatlh of prior art using VW engines for small airplanes (if one is inclined to use it). What works, and what doesn't. (eg: breaking cast crankshafts) Mine is a very simple conversion, using high quality (GPAS) parts built by a little German perfectinist. I trust it - so far. I also don't push it beyond conservative limits. All VW engines are 40 hp engine (IMHO). Some can make more power than that - for a while. This one is _rated_ at 70 hp. But will reach thermal limits of the fin area and overheat if not throttled back (to roughly 40?) It's a fairly expensive motor. The jugs and pistons are standard parts, but the crank (!) and accessories and machine work are all specialty items. A new 2180 can easily go over $5000 with a few bells and whistles. But the weight, power, reliability, and operating cost are all within reason for this particular airplane. The airplane itself can land slowly, around 35 mph. The chances of getting down safely if the engine quits are a lot better at 35 than they are at 53. To me, it seems like a reasonable risk for the potential rewards. But... Your milage may vary. Richard http://www.flash.net/~lamb01 PS: I've read of a Curtiss Hawk replica that uses a direct drive Chevy 350. It's supposed to make roughly 190 hp? It would obviously be a heavy motor. Not something you'd hang on a glass slipper. But on a big old biplane with a looong prop it seems to be just the ticket. |
#44
Maybe we can ask Jim to design a pi detector. That's a tough one, A lot harder than the BS detector... I've got a pie detector! It's right below my eyes. I can smell pies from at least a football field away, UP WIND! Oh... You're talking math aren't you? Damn, all you college boys make me feel unedumacated. Bryan "the monk" Chaisone http://www.alexisparkinn.com/rogue's_gallery_a-h.htm#C |
#45
bryan chaisone wrote:
Bravo! Professor Lamb... Well done! Well done indeed... Even a simple layman Like myself can understand. Bryan Golly! Thanks. I didn't mean to know that much, but I came by it honestly. ![]() Richard |
#46
#47
Corky Scott wrote:
On 20 Feb 2004 14:19:16 -0600, Barry S. wrote: On Fri, 20 Feb 2004 18:08:35 GMT, (Corky Scott) wrote: Auto engines are tiny when compared to direct drive airplane engines. Take a 180 hp Lycoming. It's cubic inch displacement is 360. They turn the prop at around 2600 to 2700. The Ford V-6 in airplane trim, puts out 180 hp also. It displaces 232 inches and makes it's power at 4800 rpm. No prop will work at that rpm. To harness the power, it needs to be turned slower. Enter the prop speed reduction unit. Speaking of Fords! How's your project coming? __________________ Note: To reply, replace the word 'spam' embedded in return address with 'mail'. N38.6 W121.4 Slowly. I have the engine assembled and is currently mounted in the airframe. But there's everything else to do. The airframe has yet to be blasted and painted. I think that can happen this summer. On the other hand, we are planning some major kitchen redo's and trust me, ALL of my attention had better be on that. I've built an engine test stand that will allow me to wheel the engine outside and run it, with the prop installed. I'd like to get some 30 or so hours on the engine before it gets it's final installation onto the airframe. I decided this after listening to a crusty old DAR speak at a local EAA meeting. It sounded to me like he'd be REALLY unhappy with such an engine unless I could show him that it had been thoroughly tested. At this point, I'm being educated about headers. I was going to just bend up a bunch of tubes, weld them to be what I need, get them jet coated and call it good. Then I started doing some research. It turns out that the diameter of header tubing is critical to the performance of the engine. Larger diameter is not necessarily better. In fact in almost all aircraft type applications, bigger is virtually for sure not better. The exhaust header flange has openings that are 1.75" in diameter. This matches the exhaust port opening in the head. But the tubing diameter should be 1.5", or possibly even 1 3/8" in diameter. Also, the length of the runners should be at least over 30 inches, and 36 would be better. In addition, each tube should be as close in length to each other as possible. Finally, the collector needs to be about 1 78" diameter and it should be 18" long. Reality is rearing it's ugly head. The lengths I mentioned literally won't fit without welding the headers into loops. Not going to happen. I think the best I can do is get the runners as long as I can make them and make sure they are of equal length, and get the proper collector as that also has a huge affect on engine operation. Why is it so important to have the runners be the same length? Because different length runners cause different scavenging effects within the combustion chamber. You will end up with an engine that does not respond to ignition adjustments nor mixture adjustments as some combustion chambers will run rich and some lean. "A series of single cylinder engines flying loosely in formation." Quote from John Deakin. Many builders of the Ford V6 have complained that their engine ran rough at maximum power. Huge effort was made to modify the intake manifold to correct the problem. But I have not seen a single picture of an exhaust manifold where the effort was made to create equal length exhaust headers of the proper diameter. I talked with a header manufacturer who told me he had heard of Dave Blanton because a bunch of builders had asked him about headers. He told me they all wanted to ignor his advice about tubing diameter. They all wanted to use bigger tubing than was dictated, because they all thought bigger was better. It's not. Why is it so important to have the proper diameter tubing? Because the bigger the diameter the slower the velocity of the gasses inside it, and visa versa, up to a point. Eventually you can have exhaust tubing in a diameter too small such that exhaust flow is restricted. Large diameter tubing tends to cause the engine's power to peak at extreme rpms. The smaller the diameter of the tubing, the more low to midrange power you have. But everyone wanted to use 1.75" tubing because that's what the exhaust port was. 1.75" tubing would be what you would use if you wanted flash horsepower from the engine at 8,000 rpm, like at the dragstrip. The header manufacturer also had a lot to say about "Zoomie" type headers. These are headers without collectors, basically straight pipes. Not only are these tubes also usually too large a diameter, they leave off the collector which is crucial to the proper design of the header system. So with all this information, I'm taking my time with the header design. Obviously something so important to the proper running of the engine is not something I'm going to throw together without using proper design criteria. Corky Scott Another trick that was popular on cars years ago, to bring a broad band of peak torque into the "mid range" of 2500 to 4000 rpm; was to bring the shortest practical header pipes which could be long enough to converge at a reasonable included angle into collectors in groups of 3 which would fire 240 degrees apart on six and twelve cylinder engines, or in pairs which would fire 360 degrees apart on 4 and 8 cylinder engines. On a V6, that would be be end of the story, and a collector having about the same diameter as the header pipes should continue the same inertial effect out to the exit or muffler. On V8 and in-line 4 cylinder engines, the resulting initial collectors were about as long as the header pipes before converging into a final collector. My expectation is that "tubing headers" made this way for V8 engines with 90 degree cranks should be only marginally useful. However, they should work well for all V6 engines, as well as V8 engines with single plane cranks. I am still (at a minimum) a couple of years away from testing this recollection on any project. My own goal would be to achieve the desired torque curve with an exhaust system length of 4 feet or less. However, it appears from your post that you have found a competent exhaust fabricator who can give you some additional guidance. Peter |
#48
Tim Ward wrote:
"Norman Yarvin" wrote in message ... In article , Badwater Bill wrote: When I was the test pilot on the OMABP RV-6A project, we used the Chevy Vortec V-6 engine, the PSRU was specifically designed to turn the prop at tip speed below 80% the speed of sound. Jess Meyers also used a reduction ratio number that was about equal to the square root of 2 to eliminate harmonics that could have resulted in reversed torque pulses reflecting back into the engine. By using a reduction ratio of 1.41 (or close to it) he eliminated many sympathetic harmonics that may have occured. What, in order to have the ratio between the two be an irrational number? That's not actually going to help eliminate resonances, unless you get lucky -- and you are about equally likely to get lucky with any number of about the same size, irrational or not. -- Norman Yarvin http://yarchive.net Just out of curiosity, how would you get any ratio to be an irrational number? Tim Ward There is another word I don't recall. Basically, the idea is to even out the wear in the gearbox--especially if it is a spur gear system--to give dramatically longer life to the psru. Peter |
#49
![]() "Peter Dohm" -KNOW wrote in message -KNOW... Tim Ward wrote: "Norman Yarvin" wrote in message ... In article , Badwater Bill wrote: When I was the test pilot on the OMABP RV-6A project, we used the Chevy Vortec V-6 engine, the PSRU was specifically designed to turn the prop at tip speed below 80% the speed of sound. Jess Meyers also used a reduction ratio number that was about equal to the square root of 2 to eliminate harmonics that could have resulted in reversed torque pulses reflecting back into the engine. By using a reduction ratio of 1.41 (or close to it) he eliminated many sympathetic harmonics that may have occured. What, in order to have the ratio between the two be an irrational number? That's not actually going to help eliminate resonances, unless you get lucky -- and you are about equally likely to get lucky with any number of about the same size, irrational or not. -- Norman Yarvin http://yarchive.net Just out of curiosity, how would you get any ratio to be an irrational number? Tim Ward There is another word I don't recall. Basically, the idea is to even out the wear in the gearbox--especially if it is a spur gear system--to give dramatically longer life to the psru. Peter I can see how having the numerator and denominator of the ratio relatively prime might be a benefit. Then the same configuration would only turn up once every product of the two numbers revolutions. That's kind of a convoluted sentence, but I don't know how else to put it. Tim Ward |
#50
Tim Ward wrote:
"Peter Dohm" -KNOW wrote in message -KNOW... Tim Ward wrote: "Norman Yarvin" wrote in message ... In article , Badwater Bill wrote: When I was the test pilot on the OMABP RV-6A project, we used the Chevy Vortec V-6 engine, the PSRU was specifically designed to turn the prop at tip speed below 80% the speed of sound. Jess Meyers also used a reduction ratio number that was about equal to the square root of 2 to eliminate harmonics that could have resulted in reversed torque pulses reflecting back into the engine. By using a reduction ratio of 1.41 (or close to it) he eliminated many sympathetic harmonics that may have occured. What, in order to have the ratio between the two be an irrational number? That's not actually going to help eliminate resonances, unless you get lucky -- and you are about equally likely to get lucky with any number of about the same size, irrational or not. -- Norman Yarvin http://yarchive.net Just out of curiosity, how would you get any ratio to be an irrational number? Tim Ward There is another word I don't recall. Basically, the idea is to even out the wear in the gearbox--especially if it is a spur gear system--to give dramatically longer life to the psru. Peter I can see how having the numerator and denominator of the ratio relatively prime might be a benefit. Then the same configuration would only turn up once every product of the two numbers revolutions. That's kind of a convoluted sentence, but I don't know how else to put it. Tim Ward You are exactly right. The remaining problem with spur gear reduction units is that the same portions of the crankshaft pulley will always take the power pulses--unless there is also a clutch, fluid coupling, etc. Therefore, planetary or epicyclic drives are usually preferred unless an offset is also needed. Supposedly, the problems are mitigated by a hi-vo chain drive for engines of six or more cylinders, or by a cog belt drive. Both have the advantage of spanning approximately half of the teeth on each pulley. Unfortunately, I doubt that some of the belt drive designers know much more than I do. At the moment, the Geshwender drive (which is back in production despite Mr G's death) looks like the most reliable scheme for much more than 100 horsepower, any may still be the best value in the long run. |
Auto Alternator on an O-320-E2D | Ebby | Home Built | 8 | November 26th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
