Fans thought Rod Serling invented the term "Twilight Zone." As a matter of
fact, so did Serling. He'd not heard anyone use it before, so he assumed he'd created it. However, after the hit TV show debuted in 1959, Serling was informed that Air Force pilots used the phrase to describe "a moment when a plane is coming down on approach and it cannot see the horizon." http://www.bigwacko.com/tvfacts.html Don't know if this has come up before? I ran across this "fact" looking for something else. -- Montblack "I like to watch" |
On Thu, 17 Jul 2003 21:40:47 -0400, Peter R.
wrote: Don Tuite wrote: .. . . What do you reckon the phase means? How about: "A moment when a plane is coming down on approach and it cannot see the horizon." But then again, I could be totally wrong. ;-) No, you're probably on to something there, but with a few exceptions around big bodies of water I haven't been able to see the horizon on *any* approach I've ever made. Why would I want to? Why would military pilots make such a big deal about it that they'd give it a spooky name? Don |
(Don Tuite wrote)
Why would military pilots make such a big deal about it that they'd give it a spooky name? Maybe The Twilight Zone was a fanciful and pretty name, until 1959 when Rod Serling made it spooky. -- Montblack "I like to watch" |
Don Tuite ) wrote:
On Thu, 17 Jul 2003 21:40:47 -0400, Peter R. wrote: Don Tuite wrote: . . . What do you reckon the phase means? How about: "A moment when a plane is coming down on approach and it cannot see the horizon." But then again, I could be totally wrong. ;-) No, you're probably on to something there, but with a few exceptions around big bodies of water I haven't been able to see the horizon on *any* approach I've ever made. Why would I want to? Why would military pilots make such a big deal about it that they'd give it a spooky name? Sorry, Don, I was joking with you. You had asked for the definition of the phrase when in reality it was included in the original post to which you were first replying. I simply cut-n-pasted the definition from the original post. ![]() -- Peter |
On Fri, 18 Jul 2003 09:57:59 -0400, Peter R.
wrote: Sorry, Don, I was joking with you. You had asked for the definition of the phrase when in reality it was included in the original post to which you were first replying. I simply cut-n-pasted the definition from the original post. ![]() 'S ok, there was an implied smiley in my response. But in case you were answering seriously, I figured I owed you a serious reply. Don |
How 'bout this:
The Twilight Zone: In flying across a radio range beacon beam , an airplane flies from an "A" or "N" zone toward and through the beam. As the plane approaches the beam or equisignal zone, the pilot begins to hear along with the zone and identifying signal of his zone, a faint beam signal and a faint identifying signal from the opposite zone. As the plane continues to move into the equisignal zone, those faint signals increase in intensity until, when the aircraft is within the beam, the "A" and "N" signals interlock to form a continuous monotone beam signal, and the "A" and "N" zone identifying signals will be of equal intensity. Crossing through the equisignal zone and entering the new quadrant, the new zone signal and identifying signal will be heard with increasing volume along with the weakening beam signal. As the aircraft proceeds out of the equisignal zone into the new zone, the beam signal will fade away and disappear, and only the new zone signal and its identifying signal will be heard. These areas of fading signals where both beam and zone signals are heard together, located on each side of the equisignal zone, are termed twilight zones. A pilot flying the radio range beacons has several uses for the twilight zones. A Department of Commerce airway regulation requires aircraft to fly on the right hand side of an established airway or radio range. While flying on instruments on the radio range, a pilot may comply with this regulation by following the outer edge of the twilight zone on the right hand side of the range, keeping well clear of the beam. In orientating himself over a radio beacon, a pilot recognizes that he is approaching a beam when he enters the twilight zone. This is from "Instrument Flying" by Weems and Zweng, 1940. Tom Pappano, PP-ASEL-IA "Montblack" wrote in message .. . Fans thought Rod Serling invented the term "Twilight Zone." As a matter of fact, so did Serling. He'd not heard anyone use it before, so he assumed he'd created it. However, after the hit TV show debuted in 1959, Serling was informed that Air Force pilots used the phrase to describe "a moment when a plane is coming down on approach and it cannot see the horizon." http://www.bigwacko.com/tvfacts.html Don't know if this has come up before? I ran across this "fact" looking for something else. -- Montblack "I like to watch" "Montblack" wrote in message .. . Fans thought Rod Serling invented the term "Twilight Zone." As a matter of fact, so did Serling. He'd not heard anyone use it before, so he assumed he'd created it. However, after the hit TV show debuted in 1959, Serling was informed that Air Force pilots used the phrase to describe "a moment when a plane is coming down on approach and it cannot see the horizon." http://www.bigwacko.com/tvfacts.html Don't know if this has come up before? I ran across this "fact" looking for something else. -- Montblack "I like to watch" |
On Fri, 18 Jul 2003 18:40:30 GMT, "Tom Pappano"
wrote: How 'bout this: [snip] This is from "Instrument Flying" by Weems and Zweng, 1940. Tom Pappano, PP-ASEL-IA With that provenance I'll buy it. Don |
Tom
Say what??? Big John On Fri, 18 Jul 2003 18:40:30 GMT, "Tom Pappano" wrote: How 'bout this: The Twilight Zone: In flying across a radio range beacon beam , an airplane flies from an "A" or "N" zone toward and through the beam. As the plane approaches the beam or equisignal zone, the pilot begins to hear along with the zone and identifying signal of his zone, a faint beam signal and a faint identifying signal from the opposite zone. As the plane continues to move into the equisignal zone, those faint signals increase in intensity until, when the aircraft is within the beam, the "A" and "N" signals interlock to form a continuous monotone beam signal, and the "A" and "N" zone identifying signals will be of equal intensity. Crossing through the equisignal zone and entering the new quadrant, the new zone signal and identifying signal will be heard with increasing volume along with the weakening beam signal. As the aircraft proceeds out of the equisignal zone into the new zone, the beam signal will fade away and disappear, and only the new zone signal and its identifying signal will be heard. These areas of fading signals where both beam and zone signals are heard together, located on each side of the equisignal zone, are termed twilight zones. A pilot flying the radio range beacons has several uses for the twilight zones. A Department of Commerce airway regulation requires aircraft to fly on the right hand side of an established airway or radio range. While flying on instruments on the radio range, a pilot may comply with this regulation by following the outer edge of the twilight zone on the right hand side of the range, keeping well clear of the beam. In orientating himself over a radio beacon, a pilot recognizes that he is approaching a beam when he enters the twilight zone. This is from "Instrument Flying" by Weems and Zweng, 1940. Tom Pappano, PP-ASEL-IA "Montblack" wrote in message . .. Fans thought Rod Serling invented the term "Twilight Zone." As a matter of fact, so did Serling. He'd not heard anyone use it before, so he assumed he'd created it. However, after the hit TV show debuted in 1959, Serling was informed that Air Force pilots used the phrase to describe "a moment when a plane is coming down on approach and it cannot see the horizon." http://www.bigwacko.com/tvfacts.html Don't know if this has come up before? I ran across this "fact" looking for something else. -- Montblack "I like to watch" "Montblack" wrote in message . .. Fans thought Rod Serling invented the term "Twilight Zone." As a matter of fact, so did Serling. He'd not heard anyone use it before, so he assumed he'd created it. However, after the hit TV show debuted in 1959, Serling was informed that Air Force pilots used the phrase to describe "a moment when a plane is coming down on approach and it cannot see the horizon." http://www.bigwacko.com/tvfacts.html Don't know if this has come up before? I ran across this "fact" looking for something else. -- Montblack "I like to watch" |
Big John wrote
Say what??? Tom Pappano" wrote: How 'bout this: The Twilight Zone: This is from "Instrument Flying" by Weems and Zweng, 1940. Seems as if Weems and Zweng would have fit right in with a lot of today's usenet posters. :-) Bob Moore |
Come on, Guys, A/N navigation? History of aviation. It's pre VOR, and it
worked when we had nothing better. There was a thread about a year ago about a transmitter kicking around still supporting that technique, just to preserve history, but my server doesn't keep anything older than a year ago (history loses on USENET too, I guess). "Robert Moore" wrote in message . 6... | Big John wrote | Say what??? | | Tom Pappano" wrote: | How 'bout this: The Twilight Zone: | This is from "Instrument Flying" by Weems and Zweng, 1940. | | Seems as if Weems and Zweng would have fit right in with | a lot of today's usenet posters. :-) | | Bob Moore |
| homebuilt safety | anonymous coward | Home Built | 96 | June 3rd 04 05:34 AM |
| spin zone | Ralph Griffith | Aviation Marketplace | 0 | August 14th 03 08:10 AM |
| Twilight Zone origins | Montblack | Owning | 6 | July 18th 03 09:09 PM |
