I am doing wet layup in a covoluted mold using "porous teflon coated glass
peel-ply" between the lamnate and the breather. The peel-ply material is not at all conformal and the pleats/overlaps are interfering with resin takeup. Is there any other POROUS peel-ply material that is more conformal, better drape? Is there some kind of porous coating that could be sprayed on the laminate to perform the same function that could later be removed with solvent? |
On Sat, 28 Feb 2004 08:51:32 -0500, "RKT" wrote:
:I am doing wet layup in a covoluted mold using "porous teflon coated glass eel-ply" between the lamnate and the breather. The peel-ply material is not:at all conformal and the pleats/overlaps are interfering with resin takeup. : :Is there any other POROUS peel-ply material that is more conformal, better :drape? Are you vacuum bagging the layup? If so, cut your teflon glass on the bias, 45 degrees to the threads. Then stretch it out one direction, then the other, to break the teflon. You'll find it conforms much better. Then use small pieces and overlap them, it will need to be able to expand along the overlaps as the bag pulls everything down. Do the same overlap with the bleeder. If not, don't bother with the peel ply at all. :Is there some kind of porous coating that could be sprayed on the :laminate to perform the same function that could later be removed with :solvent? No. |
On Sat, 28 Feb 2004 10:50:56 -0800, Richard Riley
wrote: On Sat, 28 Feb 2004 08:51:32 -0500, "RKT" wrote: :I am doing wet layup in a covoluted mold using "porous teflon coated glass eel-ply" between the lamnate and the breather. The peel-ply material is not:at all conformal and the pleats/overlaps are interfering with resin takeup. : :Is there any other POROUS peel-ply material that is more conformal, better :drape? I use plain old Dacron...I've tried various weaves from coarse to fine. Too coarse and it can be a bear to get off. Too fine and it may not be strong enough to pull off. I've also used Nylon with good success. (I'm using Dow Derakane Vinyl Ester Resin) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Are you vacuum bagging the layup? If so, cut your teflon glass on the bias, 45 degrees to the threads. Then stretch it out one direction, then the other, to break the teflon. You'll find it conforms much better. Then use small pieces and overlap them, it will need to be able to expand along the overlaps as the bag pulls everything down. Do the same overlap with the bleeder. If not, don't bother with the peel ply at all. :Is there some kind of porous coating that could be sprayed on the :laminate to perform the same function that could later be removed with :solvent? No. |
Have you tried cutting the peel ply on the bias?
"Roger Halstead" wrote in message ... On Sat, 28 Feb 2004 10:50:56 -0800, Richard Riley wrote: On Sat, 28 Feb 2004 08:51:32 -0500, "RKT" wrote: :I am doing wet layup in a covoluted mold using "porous teflon coated glass eel-ply" between the lamnate and the breather. The peel-ply material isnot :at all conformal and the pleats/overlaps are interfering with resin takeup. : :Is there any other POROUS peel-ply material that is more conformal, better :drape? I use plain old Dacron...I've tried various weaves from coarse to fine. Too coarse and it can be a bear to get off. Too fine and it may not be strong enough to pull off. I've also used Nylon with good success. (I'm using Dow Derakane Vinyl Ester Resin) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Are you vacuum bagging the layup? If so, cut your teflon glass on the bias, 45 degrees to the threads. Then stretch it out one direction, then the other, to break the teflon. You'll find it conforms much better. Then use small pieces and overlap them, it will need to be able to expand along the overlaps as the bag pulls everything down. Do the same overlap with the bleeder. If not, don't bother with the peel ply at all. :Is there some kind of porous coating that could be sprayed on the :laminate to perform the same function that could later be removed with :solvent? No. |
Yes, I am vacuum-bagging. No, I have not tried cutting on the bias and
stretching. Didn't even think of that... I will try your suggestions. Thank you all for the help. "Cy Galley" wrote in message news:fAm0c.422521$I06.4707963@attbi_s01... Have you tried cutting the peel ply on the bias? "Roger Halstead" wrote in message ... On Sat, 28 Feb 2004 10:50:56 -0800, Richard Riley wrote: On Sat, 28 Feb 2004 08:51:32 -0500, "RKT" wrote: :I am doing wet layup in a covoluted mold using "porous teflon coated glass eel-ply" between the lamnate and the breather. The peel-ply materialis not :at all conformal and the pleats/overlaps are interfering with resin takeup. : :Is there any other POROUS peel-ply material that is more conformal, better :drape? I use plain old Dacron...I've tried various weaves from coarse to fine. Too coarse and it can be a bear to get off. Too fine and it may not be strong enough to pull off. I've also used Nylon with good success. (I'm using Dow Derakane Vinyl Ester Resin) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Are you vacuum bagging the layup? If so, cut your teflon glass on the bias, 45 degrees to the threads. Then stretch it out one direction, then the other, to break the teflon. You'll find it conforms much better. Then use small pieces and overlap them, it will need to be able to expand along the overlaps as the bag pulls everything down. Do the same overlap with the bleeder. If not, don't bother with the peel ply at all. :Is there some kind of porous coating that could be sprayed on the :laminate to perform the same function that could later be removed with :solvent? No. |
| Thread Tools | |
| Display Modes | |
| Carbon fiber vs. antennas | Jim Weir | Home Built | 8 | January 2nd 04 02:40 PM |
| Foil antenna and carbon fiber | BD5ER | Home Built | 11 | August 6th 03 05:44 AM |
