http://www.garmin.com/support/download.jsp
Changes from version 2.07 to 3.00: --Limited the number of aircraft types that can be saved on the 'Aircraft' tab page to ten. --Corrected intermittent aviation database read error. --Corrected VNAV capture option. --Improved takeoff detection to correct the landings count in the automatic flight log. --Added tide support for European and Australian tides version 5.0. --Changed vertical speed display for better resolution when using meters/second. --Added the ability to display the next turn on the 'Turn Review' page by using the UP and DOWN cursor keys during autoroute navigation. --Added duplicate interstate name support for interstate exit searches. --Added the ability for the user to change the style of a saved track on the screen. Saved tracks may be displayed in one of 16 different line styles. --Improved WAAS/EGNOS satellite selection algorithm to select the satellite with the most beneficial corrections given the unit's current position. Units will not use a WAAS/EGNOS satellite if the unit's current position is outside of a given WAAS/EGNOS satellite's service volume. --Corrected problem that caused large routes to be truncated when loading from MapSource. --Corrected problem drawing the next route leg on the map when the route leg is sequenced. --Corrected problem that caused excessive delays drawing the map when using Atlantic BlueChart version 5. |
thanks for the info.
Triple Delta "Aloft" wrote in message ... http://www.garmin.com/support/download.jsp Changes from version 2.07 to 3.00: --Limited the number of aircraft types that can be saved on the 'Aircraft' tab page to ten. --Corrected intermittent aviation database read error. --Corrected VNAV capture option. --Improved takeoff detection to correct the landings count in the automatic flight log. --Added tide support for European and Australian tides version 5.0. --Changed vertical speed display for better resolution when using meters/second. --Added the ability to display the next turn on the 'Turn Review' page by using the UP and DOWN cursor keys during autoroute navigation. --Added duplicate interstate name support for interstate exit searches. --Added the ability for the user to change the style of a saved track on the screen. Saved tracks may be displayed in one of 16 different line styles. --Improved WAAS/EGNOS satellite selection algorithm to select the satellite with the most beneficial corrections given the unit's current position. Units will not use a WAAS/EGNOS satellite if the unit's current position is outside of a given WAAS/EGNOS satellite's service volume. --Corrected problem that caused large routes to be truncated when loading from MapSource. --Corrected problem drawing the next route leg on the map when the route leg is sequenced. --Corrected problem that caused excessive delays drawing the map when using Atlantic BlueChart version 5. |
| Garmin 296 worth the money? | Terry | Owning | 15 | June 22nd 04 10:03 AM |
| who moved SAV, forgot to tell Jepp? | Dave Butler | Instrument Flight Rules | 15 | November 9th 03 03:16 AM |
| Garmin DME arc weidnress | Dave Touretzky | Instrument Flight Rules | 5 | October 2nd 03 03:04 AM |
| Garmin 430/530 Questions | Steve Coleman | Instrument Flight Rules | 16 | August 28th 03 10:04 PM |
| Garmin 90 Database Updates Discontinued | Val Christian | Piloting | 14 | August 20th 03 10:32 PM |
