Altimeter experience
Old July 25th 03, 04:39 AM
HankC
Default Altimeter experience
Last weekend I had an interesting experience at a samll airport...
I was inbound, 15 miles out and above pattern altitude and descending.
I dialed the field to get runway in use and wind. He also gave me
altimeter, which I started to dial in, and in and in...
I slowly realized this was not right by a long shot.
I vaguely remembered the previous setting and altitude, set it back
and managed to land.
Turns out that someone had set the field altimeter to field elevation
(600 feet) but had dialed it in BACWARDS past zero to basically -400
feet! The reading was a historically hurricane low pressure, perhaps
only seen before in Death Valley.
At least for the next couple of flights, when changing altimeter
settings, I'll think to myself 'off of 2992 for ????'...
Cheers,
HankC
Old July 25th 03, 09:08 PM
Icebound
100 feet error is basically 0.1 inch of mercury. He misread a
digit...his own handwriting or a poor printer... like: instead of 30.22
he read 30.32... or maybe you HEARD 30.32??
Cheers,
HankC
"The Final 20 percent of the Project... requires 80 percent of the Effort"
---- paraphrased from Vilfredo Pareto (1848-1923)
Old July 25th 03, 10:43 PM
Icebound
Oh, my miskate... .... a thousand feet error, not a hundred.... so the
digit he screwed up was in the next position, .... 29.xx vs 28.xx...
Cheers,
HankC
Local altimeter at BFM Dan Luke Instrument Flight Rules 3 June 15th 04 03:01 PM
So Who Has More Military Command Experience, Bush Or Kerry? W. D. Allen Sr. Military Aviation 11 April 22nd 04 02:27 AM
Why not use the F-22 to replace the F/A-18 and F-14? Tony Naval Aviation 290 March 7th 04 08:58 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 10:28 AM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 01:39 AM
