#21
"Sydney Hoeltzli" wrote in message ... Arden Prinz wrote: I realize that it is my responsibility to remain clear or have two way communications. Well, I had two way communications with ATC -- I was in communications with Shaw Approach. Does that count? Normally I think Shaw Approach provides approach ATC functions for Mc Entire. Yes, it counts. Shaw approach is responsible to coordinate class D transitions if you are receiving radar services from them when you enter class D surface area. This is clearly spelled out in the controller's regulations (7110.65). The only complication in your case is that they terminated your radar services while you were in the Class D area, making it hard to "maintain continuous communication". In that case, I would call the tower before switching code, giving location and intentions and saying something like "I had radar services from Shaw, I assume they coordinated with you before I entered". There's no need to call the tower. Assuming the Shaw controller did his job properly the tower knows he's there and what he's doing. He was relieved of the requirements of FAR 91.129(c)(1) in accordance with FAR 91.129(a). § 91.129 Operations in Class D airspace. (a) General. Unless otherwise authorized or required by the ATC facility having jurisdiction over the Class D airspace area, each person operating an aircraft in Class D airspace must comply with the applicable provisions of this section. In addition, each person must comply with §§ 91.126 and 91.127. For the purpose of this section, the primary airport is the airport for which the Class D airspace area is designated. A satellite airport is any other airport within the Class D airspace area. Even facilities which normally don't coordinate (as they're supposed to) won't generally get in a p***ing match on freq with a pilot who politely makes it clear he knows how it's supposed to work. If it makes you feel better though, you can file an ASRS describing the quandry you were placed in, maybe someone will tweak some procedures at Shaw Approach. Cheers, Sydney |
... Maule Driver wrote: Interesting question. Without trying to look it up, I would say that it is your responsibility to remain clear or make contact with Mc Entire Tower when VFR. The bottom line is: It is NOT the responsibility of a pilot receiving radar services to coordinate with each surface area he flies through. (if he is landing in that surface area, ordinarily radar services would be terminated prior to entering it) The facility providing the radar services is supposed to coordinate, and maintaining contact with them counts under the communication requirement of the FARS. Makes sense and I stand corrected. Thanks. I was trying to think through the meaning of 'radar services' and 'flight following'. I was thinking that you are not bound to maintain a heading or an altitude while under FF (right?). So that would mean that you can deviate from your reported heading and altitude and enter Class D without necessarily notifying the controller. Or am I way off base here and need to do some reading? The particular situation described is problematic, because the facility providing radar services terminated them w/out a handoff. In that circumstance, I personally would probably contact the tower immediately, including in my call up something like "I had radar services from XXXX, I assume they coordinated with you". (because that's what's supposed to happen). Really puts the focus on situational awareness when that happens! |
Flying VFR, there are no direction of flight restrictions below 3000 AGL, so
a climb to an altitude, 2600 AGL in most cases, allows you to avoid Class D. If weather is a factor, circumnavigate the airspace or call the tower. For the controller, simply advise of your intentions (climb, or leaving freq.). In this case, I was crossing east-to-west, there was adverse weather to the south, a restricted area to the north, and a low ceiling preventing me from clearing this airspace above. In general, while it might be possible for me to circumnavigate controlled airspaces in order not to worry about additional regulations, I personally do not want to get into this habit. Where it is safe, legal, and convenient for me to fly through, I prefer to know and adhere to the applicable regulations and navigate "as the crow flies". Just a personal preference, I guess. Anyway, that's why I'm seeking clarification, for the future. thank-you Arden |
#24
Nathan Young wrote: If so, what action should I have taken? Take them up on their suggestion to call the next radar facility. You do not suddenly lose your transition rights because you got terminated. I have always assumed that VFR flight following does not provide transition services to facilities that aren't on their field. You're wrong, it does. Hence, I would have called McEntire's Class D. A courtesy call wouldn't hurt. I run into this getting flight following around the OHare Bravo, and crossing through DuPage's Class D. I always suggest to the approach controller that I get a freq change to call DuPage tower, and then give him/her a call on the other side. Total waste of time. |
#25
Interesting question. Without trying to look it up, I would say that it is your responsibility to remain clear or make contact with Mc Entire Tower when VFR. No. How can you remain clear when you are right in the middle of it? I realize that it is my responsibility to remain clear or have two way communications. Well, I had two way communications with ATC -- I was in communications with Shaw Approach. Does that count? Yes. You don't have a clearance of any sort so your path of flight as well as altitude is at your discretion. If you are in Class B,C Yes. ,D, No. then the controller can give you vectors and altitudes but doesn't necessarily have to under FF. What? In class B you are essentially IFR and will be separated from everyone else. In class C you may or may not be separated. Some class C facilities make their controllers separate all aircraft from all others, most don't. In class D you get nothing except a generic traffic call. An example would be where you have established flight following and announced that you are at 3,000ft. Then over Mc Entire, you decide to descend to 2,000 feet. Nothing prevents you from to doing so under FF but you would be compelled to contact the tower to enter the Class D. No, absolutely not. It is 100% the responsibility of approach to contact the tower. And your altitude isn't relavant. As an example at my tower/TRACON the TRACON owns the airspace up to 12,000. We let the tower have about 1500 feet AGL. That doesn't mean however that the TRACON can bring overflights right over the airport at 2000 AGL without coordinating with the tower. Any airplane that the TRACON is working that is going over the airport has to be coordinated with the tower, even if you are at 12,000, because the tower has automatic releases for all departures. Same thing if Salt Lake is working a VFR overflight at 12,500 or an IFR overflight at 13,000. He has to call me to point out that traffic to me. Now you would have to know what kind of agreement between the tower and its approach facility is in effect. Of course you have no way of knowing that. That's why overflights are coordinated with the tower from the approach controller. |
#26
"Newps" wrote in message news:1JeYa.55203$cF.19683@rwcrnsc53... No, absolutely not. It is 100% the responsibility of approach to contact the tower. And your altitude isn't relavant. As an example at my tower/TRACON the TRACON owns the airspace up to 12,000. We let the tower have about 1500 feet AGL. That doesn't mean however that the TRACON can bring overflights right over the airport at 2000 AGL without coordinating with the tower. Any airplane that the TRACON is working that is going over the airport has to be coordinated with the tower, even if you are at 12,000, because the tower has automatic releases for all departures. Same thing if Salt Lake is working a VFR overflight at 12,500 or an IFR overflight at 13,000. He has to call me to point out that traffic to me. No he doesn't. |
#27
"Sydney Hoeltzli" wrote in message ... Yes, it does. Why would you think it doesn't? [14CFR 91.129 does not specify that the pilot must establish or maintain communications with the control tower, simply with "the ATC facility providing air traffic services". ] 14CFR 91.126d as referenced in 14CFR 91.129a? A radar facility which provides approach services to a class D airport certainly counts. According to whom? I see several references to the "ATC facility having jurisdiction over the Class D airspace area." Can there be more than one facility with that authority? |
#28
"Newps" wrote in message news:GLeYa.55220$cF.19491@rwcrnsc53... Holy cow, I bet you listen to Art Bell. Who? I guess not. |
#29
"Vassilii Khachaturov" wrote in message om... Most likely he had already given a call to the class D tower and coordinated your transition as he would with IFR traffic. Remember, this is not an arrival, but a through flight. Would it be likely for through IFR traffic to be that low that the controller would normally provide such coordination for a through IFR flight. I'm thinking that would be quite unusual. "When in doubt, ask" Agree 100%. -- Bob PP-ASEL-IA, A/IGI |
#30
"Newps" wrote in message et... There are no classes of airspace that matter to an IFR pilot. Airspace classes were designed for VFR. As to does IFR traffic fly low so as to get into other classes of airspace where coordination would be required? Yes, all the time. But usually it's not the class that matters but whose airspace it actually is. If center is working an overflight that passes thru the top 2-3000 feet of my airspace they will often call me and ask if I want to talk to him or just take him as a point out. If I take it as a point out the pilot may never know he got into my airspace. Regarding the airspace classifications for IFR, understood. The original assertion that I responded to was : Most likely he had already given a call to the class D tower and coordinated your transition as he would with IFR traffic. The essence of my point is still valid. How often will a radar controller coordinate an IFR transition through Class D airspace? Based upon your additional explanation, I'd conclude almost never. Arrival/approach coordination happens all the time - it must - but transitions is wholly different. |
| For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 06:18 AM |
| Night of the bombers - the most daring special mission of Finnishbombers in WW2 | Jukka O. Kauppinen | Military Aviation | 4 | March 23rd 04 12:19 AM |
| Which post-WW2 combat aircraft have not been used in combat? | Kirk Stant | Military Aviation | 96 | December 10th 03 04:03 PM |
| Hispanic Hero Recalls Experiences | Otis Willie | Military Aviation | 0 | September 30th 03 11:02 PM |
| #1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 04:04 AM |
